Offline Christian.Zaefferer
#1 Posted : 21 February 2008 23:18:28(UTC)
Christian.Zaefferer
I have been trying to comprehend the Block Operations, but the very last example doesn't seem to make sense to me.
What i don't understand is the third (and last) example "how to enter a block controlled line", connection for "e":
e: S3 r , if S1 g then S4 g else S2 g , if S3 g then S4 g
First S3 is set to r, and then there is a check if S3 is g... I think "S3 r" could be "S5 r", which would make more sense. But even then this rule doesn't seem to work, a second train through S1-S2-S5 would stop at S2 and not continue because S2 would not be reset to g.
Could it be that the last part "if S3 g then S4 g" is wrong aswell and it should be "if S3 g then S2 g"?
That would make the rule:
e: S5 r , if S1 g then S4 g else S2 g , if S3 g then S2 g
Or am i just missing something here?
Greetings, Christian
Offline stephenbb
#2 Posted : 22 February 2008 17:42:31(UTC)
stephenbb
Welcome to the forum Christian.
Sorry I can't answer your question as I don't use any blocks on my layout. I operate everything manually. I'm sure that you will get a response
Stephen(USA)
ETE,NMRA,MEA
#3 Posted : 22 February 2008 21:32:07(UTC)
Welcome to the forum, Christian.
#4 Posted : 22 February 2008 22:41:04(UTC)
Lars, could you explain - since you wrote that article?
#5 Posted : 22 February 2008 22:51:22(UTC)
Welcome to this great forum, Christian.
Offline Caplin
#6 Posted : 22 February 2008 23:28:37(UTC)
Caplin
Also welcome from me.
Please add your country to your profile.wink
Benny - Outsider and MFDWPL
This page was generated in 0.333 seconds.
