Offline Rinus
#1 Posted : 29 July 2013 22:52:55(UTC)
Rinus
Few months ago I purchased a Roco Taurus (78451) with sound. Its equiped with a Zimo Sound decoder (plux 22).
Problem is it drives awfull. Especially on the main level which is ballasted. It stops around every few meters, and then starting the start up procedure from A-Z including the start up melody and slow acceleration. In the hidden yards its better but far from perfect. It remains a train you have to attend and monitor.
This is what I allready tried:
  • clean the track again
  • run in the other direction
  • clean pickup shoe
  • searched the manual for a 'ahlzheimer CV' which there is not
  • contacted Zimo who advised me after a month to install 'Elkos' capacitators
  • install capacitators
However it still drives pretty bad.
Most of my other trains runn very well. Most are Roco with Uhlenbrock or ESU decoders.
This is my only 'Zimo equiped Roco'. Personally I'm thinking about replacing it with a propper ESU Locsound decoder.
What else can I do?
How are your experiences with this particular train or other Roco Taurus trains in general?
Hope one can help me.
Rinus
#2 Posted : 30 July 2013 06:33:05(UTC)
I have a couple of Roco Tauri, but both have no sound, and most likely ESU decoders. One in particular used to run OK around my M track layout, but once I expanded the layout (with C track), it now runs quite badly, stuttering its way around the track. The other (later) loco runs fine. I haven't as yet got to the bottom of the issue - all my Marklin locos run fine.
#3 Posted : 30 July 2013 11:46:31(UTC)
The 2 locos are Roco 69685 and Roco 68362 - 69685 has the stutter.
Offline Rinus
#4 Posted : 30 July 2013 12:22:45(UTC)
Rinus
Thanks for your reply.
The 69685 has a Roco-Decoder 10738 decoder. Do you know if thats a zimo?
I might try cleaning the inner sides of the wheels. As it has 4 traction tires it leaves only 4 wheels to transfer the current. But as its brand new I d not expect much from that either.
Rinus
#5 Posted : 30 July 2013 13:14:13(UTC)
A quick Google search for Roco 10738 returns this Stummi thread - http://www.stummiforum.d...opic.php?f=5&t=65309 , and from that I deduce that the 10738 is an OEM version of the ESU Lokpilot 3.
#6 Posted : 30 July 2013 16:55:00(UTC)
Rinus,
Roco locos sometimes play up.
track connections: you should have 4 connections to each bogie but sometimes they get dirt on them, being a brand new locon it doesn't sound like it this is the problem but sometimes they do not touch the wheel.
being an AC loco all wheel connection wires should be connected back to the circuit board. the slider also can cause problems, take the slider off and see if the spring leaves are clean and make sure the slider sits properly and level.
make sure the inside track is also clean and all the studs.
regards.,
#7 Posted : 30 July 2013 17:01:23(UTC)
Dave,
this is a bit outdated and since than Roco uses the same decoder number but it comes now from the Zimo factory.
all depends how old the Taurus loco is if it is from a late production it will be a Zimo decoder.
the person who wrote the article didn't know that Roco uses Faulhaber motors and its listed as such.
#8 Posted : 31 July 2013 00:17:18(UTC)
Are you sure? They used a different number when they switched to Uhlenbrock decoders and I would be surprised to find they use the same old number for new Zimo decoders.
Try to read CV 8 under DCC - it's ESU if you get 151.
Some early 10738 do not support DCC. Some very early 10738 are Lenz decoders.
#9 Posted : 31 July 2013 01:01:09(UTC)
Thanks Tom, yes I had thought about doing that with the locprogrammer, will maybe try later tonight.
John, my 69685 is about 4 or 5 years old, so I would expect it to have the older decoder. A read of CV8 will confirm or deny that!
#10 Posted : 31 July 2013 04:41:18(UTC)
I just bought a Roco ÖBB Rh 1245 e-loco and it has a Zimo decoder in it and I've looked at the spare part list and it says 10738
#11 Posted : 31 July 2013 04:48:12(UTC)
Dave,
Roco does mention changes have taken place since 2000 but they don't say what they are or give the brand name of the decoders.
most probably it is the new series of multi protocol decoders whereas they can recognize which system your locos run on.
#12 Posted : 31 July 2013 05:31:09(UTC)
The 78XXX models are equipped with Zimo decoders. However, I don't think that the issue is with the fact that it is Zimo. I think you would likely have a similar issue with an ESU or other decoder. If you can adjust the parameters for braking and acceleration, the lok might keep rolling long enough to avoid stopping over a spot where it loses contact.
If I remember the model correctly, it has four powered axles with two axles with rubber tires, one on each bogie. It is possible that this results in a situation where there is insufficient contact between wheels and rail to ensure a good ground contact. Make sure that the wheel contacts are properly contacting the wheels, so that the ground can be transmitted from each wheel to the common ground.
The other thing that I would try to do is to remove and reverse the direction of the whisper slider, which should eliminate the possibility of a contact issue with the center rail. I replaced the slider on one of my loks that was problematic and the operation improved with the new one. If the tongues on the slider feet are not making good contact with the slider itself, this can cause poor contact.
#13 Posted : 31 July 2013 08:05:22(UTC)
Well, spare parts lists can be outdated - we know that from Märklin ...
Did the loco come with a 10738 decoder manual? Or another decoder manual?
What is the ref. number of the loco?
10732 is the Roco ref. number for Uhlenbrock decoders.
#14 Posted : 31 July 2013 08:08:48(UTC)
This cannot be: model 78563 is announced with mfx - and Zimo do not make mfx decoders.
So it seems the Roco number scheme does not allow to tell the decoder brand from the ref. number.
The Taurus should have three powered axles. The acceleration and braking delay set in the decoder does not affect the brake time in case of a power loss.
#15 Posted : 31 July 2013 09:34:00(UTC)
Tom, here are copies of the instruction booklets
#16 Posted : 31 July 2013 12:14:31(UTC)
CV8 on the 69685 reads 151, ESU.
On 68362 CV8 reads 85, which is Uhlenbrock. The part number for that decoder is 10732.
So, CV8 on that loco reads 145 then?
#17 Posted : 31 July 2013 18:35:42(UTC)
The spare parts list they have on their site gives the decoder as 10732.
http://www.roco.cc/doc/ET/1/DE/68651_11119.pdf
#18 Posted : 31 July 2013 19:41:02(UTC)
The 78563 is likely merely a repainted shell on an older model, so it is possible that it comes with the same circuit board and decoder as the original model of the class 140 that it is based on.
When Roco dropped ESU as supplier for it's OEM decoders and adopted Zimo as it's new supplier, it is likely that they still had a number of ESU decoders in stock. New models are designed with Zimo decoders/PluX22 while older models might still have 21 pin ESU connections and receive the OEM ESU decoder.
#19 Posted : 31 July 2013 20:55:16(UTC)
When Roco dropped ESU as supplier for it's OEM decoders and adopted Zimo as it's new supplier [...]
It seems they never dropped ESU.
They switched from ESU decoders to Uhlenbrock decoders, but for a while still used ESU for locos with digital couplers (until Uhlenbrock could also handle that). They use(d) PluX decoders from both Uhlenbrock (10880, 10881) and Zimo (10882, 10883).
I don't think they dropped Uhlenbrock either (but I could be wrong here).
The newly constructed BR 218 came with ESU decoders. It seems Roco are testing if mfx will give them extra profit in the three-rail market. They never used mfx before they switched to Uhlenbrock, so these can't be old supplies they still have in stock.
That's the advantage of NEM sockets: they have three suppliers for suitable decoders - this might help them in price negotiations.
#20 Posted : 01 August 2013 15:07:27(UTC)
it may help them in negotiating a better price but its not an advantage for us who use the ECoS or lokprogrammer
Offline Rinus
#21 Posted : 02 August 2013 00:21:31(UTC)
Rinus
Hello all,
Thanks for the many replies! I got home late so I'll try them tomorow morning.
Personally I don't think the (de-)acceleration settings have got anything to do with it. But I'll try it any how.
I think altering the pick-up shoe, checking the contacts between bogie and wheel and cleaning the innerside of the track will have the most effect.
I also found something about changing the 'Anfahrspannung' and analogue mode.
Last, I'll check if I got the rearangements for enable the additional ELKO capacitators right. The ZIMO manual is not very clear here.
I'll let you know the results.
Rinus
Offline Rinus
#22 Posted : 02 August 2013 00:26:10(UTC)
Rinus
Absolutely my idea too. Its difficult enough allready to get to know one type of decoders well.
Why offer the selection of a decoder by choice of the customer? Its very usual in other branches as well to upgrade your purchase as one desires (for instance mountainbikes, cars etc...) ?
#23 Posted : 02 August 2013 07:58:02(UTC)
All three-rail locos (at least those I know) come ready to run, which means with pre-installed decoder.
Without decoder they would not run out of the box.
As a beginner I was quite happy to have the decoder pre-installed (21MTC did not yet exist then).
Nowadays I'd prefer to buy locos without decoder. Dealers can change wheel sets on cars and coaches, they also should be able to install decoders on demand.
Maybe we should stop buying locos with pre-installed El Cheapo decoders - and let the manufacturers know about it.
Guest (14)
This page was generated in 0.651 seconds.
