Offline fhp2
#1 Posted : 21 July 2013 12:22:29(UTC)
fhp2
I am adding some feedback sections on my "already installed layout".
In order not to destroy my landscape, i cannot solder the feedback wire below the track... So, i am creating small section (shorter than a piece of track in order to have not connected rails) by cutting one rail in the middle of a track piece.
My problem is to solder on the rail. It seems that the metal used for Marklin C-track is difficult to solder...
Does anyone knows about this ? Any solutions ?
Thank you in advance, Francois.
#2 Posted : 21 July 2013 23:55:50(UTC)
Try using Ortho-Phorosphoric Acid as the flux. make sure it is cleaned after use.
NN
Offline tulit
#3 Posted : 22 July 2013 01:43:50(UTC)
tulit
NN
Phosphoric Fluxes are a bad choice for any electronics work since they're so corrosive.
I've used superior no515 for stainless soldering with decent success. It still needs thorough cleaning (hot water seems to work the best).
It helps as well to have a wide tip to promote better heat transfer.
Offline fhp2
#4 Posted : 22 July 2013 12:09:40(UTC)
fhp2
Thank you, I will try this !
Offline efel
#5 Posted : 22 July 2013 13:10:59(UTC)
efel
You may also consider screwing a screw in the ballast in such a way that its head is in contact with the rail, and solder a wire on the screw.
A conductive glue may also be considered for sticking the wire on the rail, for the S88 current is quite low, and the contact resistance can be rather large.
(seen on other forum, but I don't know the reliability!)
Fred
thanks 1 user liked this useful post by efel
Offline fhp2
#6 Posted : 24 July 2013 11:12:30(UTC)
fhp2
Great tip, thank you !
This page was generated in 0.411 seconds.
