Offline Janne75
#1 Posted : 20 June 2013 14:53:45(UTC)
Janne75
Hello all,
I have a question about connecting CS2 version 60214 and analog AC transformer 6647 grounds together. Is this safe and possible?
The only reason for doing this is that I would like to run my analog electric locos from AC powered catenary with my analog 6647 white transformer. All my digital steam, diesel and electric locos will run at the same time from track power with CS2 60214. So I need to connect my analog 6647 transformers ground to track ground as otherwise it is not possible to run any analog electric locos at the same tracks as digital locos.
But is this safe or is my CS2 getting damaged if grounds are connected at tracks? Confused If not possible, then catenary will only be for looks and not operating/electrified. It would be great if this kind of connection between the grounds would be possible. Then I could remove also sliders/pick-up shoes from my analog electric locos and have less noise. Only analog locos wheels would "see" the common ground and not to worry about central studs getting any electric to loco or loco disturbing Digital track signals if it's motor somehow would send electricity through the slider back to center track. I'm not an electric engineer so I don't understand much of this. Safest to remove sliders anyway if this is otherwise possible to connect grounds?
I read from my powered catenary mast instructions that with Märklin Systems (CS and MS) it is not possible to make this kind of connection. There is a warning about this. The reason why I want to still ask is that does it have something to do with how CS2 60214 and 6647 AC transformer are shielded or isolated? Was it so that this newer 6647 white transformer is better protected than previous AC transformers? Also CS2 60214 and 60215 have better shielding or isolation than the earlier versions.
I will have catenary at my outer main line. It will cost me around 600 euro when I do it ready. Now I have only two 144 cm test catenary sections at my outer bridges and I would like to test the one with powered mast. It would be great to get my older electric locos powered with real powered catenary. It feels then more like "worth the moneys" if this is possible.
Many thanks in advance from answers again! RollEyes
Janne
#2 Posted : 20 June 2013 15:00:31(UTC)
Hi, Janne!
It's possible. A connection between catenary and centre rail could kill your CS2, so the safety depends on how you use it.
Always set the analogue transformer to 0 before handling trains (modern plastic coaches should be no problem, but old tin-plate coaches could make a connection).
Better remove the centre rail slider from the locos so they cannot make a connection internally (with the selector switch in the middle between catenary and centre rail positions).
All 60215 and some 60214 have galvanic isolation (and 5A output), early 60214 are like 60213 (no galvanic isolation, 2.4 A output).
AFAIK this makes no difference with respect to analogue catenary.
What exactly is the warning in the manual? Which manual?
#3 Posted : 20 June 2013 15:38:35(UTC)
I found the manual.
They say that MS or CS should not be used to power the catenary.
Here they say it can be mixed:
The catenary can be connected to a Märklin H0
operating system that is different from the one
connected to the track. (Example: Catenary with
AC power, tracks with Märklin Digital).
We do not particularly recommend using Märklin
Digital as and operating system with the catenary.
Here they say "don't use MS/CS with catenary:
Caution:
When using Märklin Systems (Mobile Station
or Central Station) as the operating system,
it is not possible, to use the catenary to supply
power to the electric locomotives.
Offline Janne75
#4 Posted : 20 June 2013 15:46:01(UTC)
Janne75
Thanks Tom once again!
So it is best to be careful with 6647 and always have it at "0" zero position when handling locos or wagons. I can even put locos on track before I start CS2 to be on the safe side. I can put all rolling stock on tracks without catenary and move them with my hand under catenary. No need to put any rolling stock under catenary and take a risk of shorting both positive currents (CS2 and 6647).
I have to be very careful that catenary wires will not drop on tracks if they will get loose or get dameged for some reasons. My CS2 60214 has a logo in the bottom that has like two circles crossing each other. Is this a sign for galvanic isolation? My CS2 came in relatively new starter set 29500 from year 2010/2011.
The warning you asked for is in 74121 Working Catenary instructions (included in Feeder Mast 74121 package).
Here is the whole text:
"Working Catenary
You have the option with the Märklin catenary of using it to supply power to electric locomotives. When doing this, a feeder mast must be used in place of a standard mast every 2 to 3 meters / approx. 6-1/2 feet to 10 feet.
The catenary can be connected to a Märklin H0 operating system that is different from the one connected to the track. (Example: Catenary with AC power, tracks with Märklin Digital).
We do not particularly recommend using Märklin Digital as an operating system with the catenary.
Caution:
When using Märklin Systems (Mobile Station or Central Station) as the operating system, it is not possible, to use catenary to supply power to the electric locomotives.
This 74121 instruction is dated 01 07.
Janne
#5 Posted : 20 June 2013 15:50:53(UTC)
That's the sign for galvanic isolation, so you should be able to use 5 A with 100 VA power supply (which is not recommended for H0 gauge by Märklin).
Offline Janne75
#6 Posted : 21 June 2013 12:12:32(UTC)
Janne75
Today I took of sliders from thirteen of my analog electric locos. Less noise and friction. Some of these are basically new vitrine models and worked great from analog AC catenary ThumpUp . It feels like I have now more usable electric locos as before I had them only in display cases or some of the more used ones were sometimes driven at temporarily built analog tracks on the floor. I like these analog motor and reversing unit sounds. These and the smell of burnt oil reminds me from my childhood Smile .
I did not realise before that actually my CS2 don't have to be powered if I only want to run my analog electric locos from catenary with 6647 transformer. I thought that it will not work like this and CS2 must be on to "give" ground to loco wheels. This is good so my CS2 is even better protected if wanted. So I have not yet tested this AC analog catenary with my CS2 powered...
Janne
Offline Janne75
#7 Posted : 22 June 2013 17:25:52(UTC)
Janne75
I just tested my analog catenary test section when CS2 was powered also. Everything works just fine! Smile
I ran one of my SBB 3050 that is digitalised with older Märklin 6080 decoder from track power (CS2) and old Austrian ÖBB 3036 analog from AC catenary at the same time. That analog 3036 has less noise as it don't have slider anymore and analog motor is more quiet than digitalised (6080) 3050's motor.
Some of my older locos don't like wide radius turnouts. They cut track power for a short moment when they run over them sometimes. If sliders causes this then no problem when running without them. It can be the old style wheels that causes these power cut offs which happen only on wide radius turnouts for some strange reason Confused . I hope that my analog electric locos will not do this when I get my catenary over two of them at my outer mainline.
Janne
This page was generated in 0.438 seconds.
