Offline smurfillo
#1 Posted : 28 May 2013 12:07:05(UTC)
smurfillo
Hi guys:
Recently I have acquired one crocodile 3015 digitalized with motorola 6080 microchip, the lok run well in digital layouts, but don´t run in AC layout. I've another digitalized machines and work well in both layouts.
Where could be the problem?
Thanks in advance.
#2 Posted : 28 May 2013 12:46:05(UTC)
As far as I know, the 6080 decoder should automatically detect whether it is running in digital or analog mode and adjust accordingly. If it isn't, maybe the decoder is faulty.
It may be that your 3015 is trying to draw too much current in analog mode, and simply will not work with the 6080 in analog mode. I know that the 6080 is for driving AC motors, but I don't think it was ever intended to drive the 3015 motor.
The 3015 was not ever able to be converted digitally until recently, as there was no DC magnet ever available for it, due to the size of the 3015 motor.
ESU has now produced a DC magnet for Marklin 1 Gauge locos with AC motors, and this magnet also fits the 3015. I would get one of these magnets and fit a Lokpilot XL / Loksound XL decoder, which can handle the larger sized motors.
I think whoever converted your 3015 hasn't done their research properly, and have done a bad job of converting it.
#3 Posted : 28 May 2013 13:44:00(UTC)
Are you sure it is a 6080 decoder? Could it be a Delta decoder?
Some decoders require all DIP switches in the OFF position for analogue operation.
Offline smurfillo
#4 Posted : 28 May 2013 17:35:29(UTC)
smurfillo
Yes it's an 6080 decoder, run well with a 6021 unit, I will try with all DIP switch off.
Thank You.
#5 Posted : 28 May 2013 22:51:35(UTC)
I was going to mention that, but didn't because a 6080 should detect an analog controller.
However, I stand by my previous comment - whoever converted it did a bad job!
Offline smurfillo
#6 Posted : 29 May 2013 00:40:52(UTC)
smurfillo
I tested the loco with the all DIP switch in OFF and the loco runs in AC, but unfortunately the decoder had a malfunction and not work well now Cursing
The lights function not work and it overheating Mad
I upload some photos, because I don't know who is the manufacturer and model is this decoder, and I need replace it now.Angry
Offline biedmatt
#7 Posted : 29 May 2013 01:12:42(UTC)
biedmatt
That is the super 6080 developed for the '96(?) released 36159 Brown Croc. As stated, these can be converted with a standard decoder with a permanent magnet. I did one about a year ago. It is much cheaper now with the recently released Hamo magnet from ESU. I'm waiting for the magnet now so I can convert a 36159.
https://www.marklin-user...15-SLFCMs-available.aspx
https://www.marklin-user...15-with-ESU-decoder.aspx
Matt
Era 3
#8 Posted : 29 May 2013 01:20:59(UTC)
Have a look through this site (in German unfortunately) - the site owner has posted pictures and descriptions of various decoders - http://www.x-train.de/ - you might be able to identify yours from the site. The decoder looks like it uses the 701.17b chipset, which were used in delta decoders - http://home.arcor.de/dr....nig/digital/edeltadi.htm
Unfortunately, as you might gather from the website home page, the website owner lost his life in 2011.
However, I come back to my original comments - Marklin never developed decoders and upgrade parts for converting the 3015 to digital, simply because the motor is too big and draws too much current for standard H0 decoders.
If you are going to persist with digitising your 3015, I would strongly recommend you look at the ESU magnet option with Lokpilot XL / Loksound XL decoder. If you simply replace the existing decoder with another of the same type, you may well run into the same problem again.
Offline biedmatt
#9 Posted : 29 May 2013 01:51:47(UTC)
biedmatt
When Marklin released the Insider model for 1996, it was a brown Crocodile #30159. They got so many requests to do this loko in digital that they developed a special decoder for it. It is commonly called the "super 6080" since that is basically what it is, an uprated 6080 so it can handle the load.
They also sold this decoder as a replacement part too. I found one on Ebay for a dear price, but I wanted it. Note the part number on the wrapper matches the part number on your decoder in your picture. I am not going to remove it from the bag because just as with the original 6080, it is subject to damage from static discharge and I do not want to drag out the static mats and wrist strap.
You can covert this with the standard duty ESU decoder. It is what they recommend and what I did last summer. I've pulled 30 cars with that converted 3015 shown in the thread I linked above.
Matt
Era 3
#10 Posted : 29 May 2013 02:03:33(UTC)
As far as I know, the 6080 never had load control, but I don't know about the Super 6080 - I assume it doesn't either.
As biedmatt suggests, maybe a standard ESU decoder (Lokpilot / Loksound) with the ESU magnet is the way to go.
Offline biedmatt
#11 Posted : 29 May 2013 02:18:51(UTC)
biedmatt
No load control with the super 6080 and just one function- headlamps.
Matt
Era 3
#12 Posted : 29 May 2013 08:07:31(UTC)
No load control - and probably no overload protection.
While the Super 6080 was designed for the motor of the 3015, it probably was made for one with a clean collector with easy running gear.
Are there coal brushes in the 3015? If so, make sure the gaps of the collector are clean (carbon dust in the gaps increases the decoder load and might kill it).
Make sure there is no hardened oil in the gears.
Offline biedmatt
#13 Posted : 29 May 2013 12:30:13(UTC)
biedmatt
Tom and Bigdaddynz nail the reasons why I would go to the Hamo magnet and a new decoder. There are just too many ways to damage this decoder, they are not available any more and their running characteristics are inferior to a new decoder. I know the decoder in my 36159 will be going into a static bag as soon as I get the Hamo magnet I recently ordered. The difference between my converted 3015 and my 36159 is significant. The 3015 will just crawl and the 36159 stalls at low speed, dial in some more throttle to get it going and then it lunges.
Matt
Era 3
Offline smurfillo
#14 Posted : 29 May 2013 13:21:31(UTC)
smurfillo
OK biedmatt, the Loco have a 600336 and it 's impossible today obtain a replace part.
What standard duty ESU model do you consider suitable for this loco? I only want change the decoder, I don't want change the magnet.
HO, the machine look very clean and no hardened oil in the gears
Offline biedmatt
#15 Posted : 29 May 2013 13:54:39(UTC)
biedmatt
ESU 54610, or if you want/need MFX, then 64610.
Unfortunately, you need to change the magnet. Trust me, it is very easy to do. Pay attention to what you are doing and lay each part out in a row as you remove it. Then you know what order to put it all back. From what I remember, remove the brushes, remove the metal piece clipped to the bottom center and remove the two screws securing the two halves of the loko together. These screws pass through an eye in the magnet so you must completely remove them. Put in the new magnet, line up the comm and insert the screws. Use aux 1 for the lower right headlamp at both ends and map it to come on with the headlamps. These lower right lamps are always on at both ends no matter what the direction of travel is. Use the standard yellow and white wires for the other two headlamps at each end. This will emulate the correct Swiss lamp functions. The magnet is ESU 51965. If you have LokProgrammer, I could e-mail you my program including the tweaks I made for the motor running characteristics.
Matt
Era 3
Offline smurfillo
#16 Posted : 29 May 2013 20:07:01(UTC)
smurfillo
Thank You biedmatt, I bought the items in Internet today and now I have wait the shipment, when it arrives I'm contacting you again.
Offline Brakepad
#17 Posted : 29 May 2013 23:18:49(UTC)
Brakepad
France, Metropolitan
Hello Smurfillo,
May I ask you where you ordered the magnet?
I need some, but I can not find any store with them in stock.
Thanks.
Offline eduard71
#18 Posted : 30 May 2013 03:55:35(UTC)
eduard71
Chile
Hi there!,
I have a question, the 150 year set of 3 Cocodriles 31859 comes with one green and one white replicas of the 3015. As far as I know they are digital and I think even have a MFX decoder. Does this models comes with the same engine as the 3015 or they have a magnet instead? If not, is the plate and decoder available?, could it be used on an old 3015?
I have looked into the tread of the Stummis forum but since I do not read German I am lost, but for the images , it looks like the model have the same big engine but I cant see if it uses an magnet.
http://www.stummiforum.d...amp;t=38594&start=25
Eduardo
#19 Posted : 30 May 2013 05:01:25(UTC)
Eduardo,
When you have a close look at the photos you can see 2 wires (green + blue coming from underneath the magnet, indicating it is a coil.
although it is mfx I don't know how they've arranged the analog to digital conversion (decoder). apparently these locos do not have any acceleration or braking delay and can therefore not be classified as highefficiency motor.
also the noise level seems to be the same regardless whether the loco runs analog or digital.
#20 Posted : 30 May 2013 07:54:41(UTC)
Same old AC/DC motor (no permanent magnet). Loco is mfx, but without load regulation.
One special thing about this loco: the PCB in the loco also contains the motor driver, allowing standard decoders to be used with this high-power motor.
Offline biedmatt
#21 Posted : 30 May 2013 12:37:06(UTC)
biedmatt
The big Crocs in the 31859 set are interesting. As John and Tom have stated, they do use a field coil and they are MFX. I am in the process of changing my MFX lokos to DCC with ESU decoders. When I installed the ESU decoder into these lokos, they would run, but even with the low speed setting at the minimum value, they ran way to fast at speed step one. M must have some very strange values for the speed settings on the decoders in these lokos. So the MFX decoders are back in and I'm debating what to do. I do not have the patience to wait 1:40 seconds to re-acquire the MFX decoder each time they are placed on the track.
M may have the 31859 parts to convert a 3015 or similar Croc, but I would go the ESU route if you are going to change one from it's original configuration. That's my quandary with the 31859 Crocs, do I modify them or wait on these two lokos each time they are placed on the track?
Edit: I think I will try this again with all aux outputs on to see if the drive needs external power like a sinus drive does. If that works, it will be easy to determine which aux must be on. Probably will need to turn off load control as you must with sinus drive.
Matt
Era 3
#22 Posted : 30 May 2013 14:15:11(UTC)
Matt,
there has been a quite a discussion about its starting time (Stummi's forum) with different opinions but I didn't read through it all.
I must confess, Märklin has gone half way to produce something digital but have left off the perm. magnet. I can't understand why it has to be, a complete strange Company, which has nothing to do with the Märklin Crocodile history is producing a spare part and so it produces the other magnets for Märklin enthusiasts to retain the 3 pole motor.
You would expect Märklin would go the extra step to provide its buyers with a perm. magnet.
I must confess I don't think much of the conversion set done with a perm. magnet only but I never did a final test run whereas the decoder will set itself to its maximum running characteristics.
Offline biedmatt
#23 Posted : 30 May 2013 15:17:06(UTC)
biedmatt
I agree John. There are so many of these 3015s and their variants out there not to mention those lokos which use the same motor. I can't imagine why M doesn't just make a proper permanent mag and 5 pole comm for these engines. They could make a complete kit with mag, comm and decoder. There is more than enough interest. No doubt they will trot out another variation in a few more years, probably brown again, it's been a while for that version.
Matt
Era 3
#24 Posted : 30 May 2013 16:03:32(UTC)
With extra power transistors on the loco PCB, you definitely have to disable load regulation on the decoder.
Maybe the loco ran fullspeed because load regulation was on, but feedback from the motor did not get rhough and the decoder thought that more power was needed.
#25 Posted : 30 May 2013 16:35:26(UTC)
the 3015 is a collectors item and the after thought of bringing out a replica with a digital decoder may has resulted in separating the 2 crocodiles.
Offline biedmatt
#26 Posted : 31 May 2013 12:30:45(UTC)
biedmatt
I tried a LokPilot again last night in the green 31859 Croc. Turned off the load control and configured aux 2, 3 and 4 to a function button so I could experiment. Aux 1 is the marker lights. It still took off like a shot. I had expectations of getting it to work, but no go.
I think I'm going to put the Hamo magnet in this and the white one too. With the MFX decoder, the speed range was fine, but sometimes it would get "stuck" and I would need to go backwards a bit before it would go forward again. The Hamo equiped 3015 does none of that. Perhaps I will go sound too.
Matt
Era 3
This page was generated in 0.708 seconds.
