Offline Larry
#1 Posted : 09 May 2013 22:39:08(UTC)
Larry
I was regretting not ordering the Club anniversary 37020 freight steam locomotive with a condensation tender. Then I looked at my Marklin engines (temporarily in storage) and discovered I have a 37023 loco whose engine looks identical to the 37020 except the tender is not a condensation tender with the fans etc.
Any of you have the 37023 and opted to order the anniversary model (37020)? If so, what were your reasons?
What is the purpose of the condensation tender, how does it compare to the conventional tender and did it fall into disfavor for some reason?
Larry
#2 Posted : 09 May 2013 22:51:44(UTC)
Typically the operating range of steam locomotives is limited by water.
Condensation tenders are one way around that problem. During war times they also reduce the visibility of steam locos (as steam is "recycled" and not ejected).
Typically steamers can run 300 km with a full tender - enough for a small country like Germany.
In South Africa, condensing tenders were used much longer.
In the USA and France, some steam locos took fresh water while driving - a simpler technique (less maintenance) to increase their range.
Edited by user 10 May 2013 07:59:53(UTC)  | Reason: Senior's moment
#3 Posted : 10 May 2013 01:32:19(UTC)
..Typically steamers can run 300 km/h with a full tender...
Yikes! Scared Why did we need a Thayls if steamers can go that fast?
#4 Posted : 10 May 2013 01:38:52(UTC)
because they're not called steamersFlapper
Offline Larry
#5 Posted : 10 May 2013 03:00:07(UTC)
Larry
Thanks, Tom, for sharing your great insights. I greatly appreciate it.
Larry
#6 Posted : 10 May 2013 08:01:27(UTC)
My fault - corrected.
#7 Posted : 10 May 2013 10:08:01(UTC)
This was done on the main lines in the UK as well, and I always thought the idea was very cool. It works by having a trough between the rails full of water, and a scoop under the tender that can be lowered into the trough. As this is done at speed the water is scooped into the tender under considerable pressure, filling it in seconds.
It must have been spectacular to see!
Offline Paul59
#8 Posted : 10 May 2013 12:43:14(UTC)
Paul59
That's right. There were water troughs on most of the main lines in the UK, I think they were about 1/4 mile long. They could pick up a couple of thousand gallons in about 15 seconds! Apparently it took a huge amount of strength to wind the scoop back up against the force of the water. It had to be done quickly too as if the tender overflowed the front coach would get deluged in water. Not a problem in the winter but in the summer some of the windows would be open... BigGrin
Even some of the early diesels had water scoops fitted to replenish the water tank that fed the steam heating boiler.
Paul
thanks 1 user liked this useful post by Paul59
Offline rmsailor
#9 Posted : 10 May 2013 13:46:04(UTC)
rmsailor
Condensing tenders were developed during World War 2, by Germany for use in Russia where there were problems with adequate water supplies. The exhaust steam is diverted back into the tender where it is passed through an array of tubes, cooled by air fans. In place of the steam exhausting up the chimney a fan provided the draught to the fire. This could cause problems with steaming as the automatic feedback between the rate of working and the amount of energy being produced is lost. As a normal locomotive works harder, more draught is generated in the smokebox which increases the rate of combustion. On top of which of course is the greatly increased weight and complexity of condensing tenders.
Around London, condensing tank engines were used in tunnels. However here the steam was simply diverted into the side tanks. Eventually the water would get so hot that the injectors would stop working. At that point the water in the tanks would be dumped and replaced with cold water.
Bob M.
thanks 1 user liked this useful post by rmsailor
Offline witzlerh
#10 Posted : 10 May 2013 21:29:45(UTC)
witzlerh
You have been a member since:: 25/09/2010(UTC)
Condensation tenders were also hard to maintain. The theory of recycling the water is great but between the mechanisms and the corrosion, they were hard to maintain. I would like a condensation lok just for the engineering curiosity.
Harald
CS2 DB & Canadian Era 3-6
Offline kariosls37
#11 Posted : 10 May 2013 22:57:05(UTC)
kariosls37
With all steam ships and power plants having condensors, I would have thought they had the problem of corrosion sussed. I suspect that the problem on applying them to locos was that tenders tend to vibrate and jerk, stressing parts of the condensor, and the sheer weight of it all. Any extra weight in the tender you add means less tonnage and therefore money you can move. The artificial draught is a problem as well, how to get the draught going without excessive wear on the machinery. Also, it may seem odd, but the pulsing draught makes a steam boiler steam much better than a continuous draught.
My two cents worth,
Rick
#12 Posted : 10 May 2013 23:22:34(UTC)
Corrosion was a big problem with the Franco-Crosti design, but a quick search on google found no articles about corrosion problems with condensing tenders (no exhaustion fumes involved).
Offline Western Pacific
#13 Posted : 11 May 2013 13:57:06(UTC)
Western Pacific
Paul
Couldn't there have been problems also in winter sometimes?
I guess there is a reason why this method was never used in Sweden.
Think: Temperature below 0 C or 32 F. OhMyGod
This page was generated in 0.543 seconds.
