Joined: 21/09/2006(UTC) Posts: 1,432 Location: NORFOLK UK
I am at the stage on my layout to start to but some Preiser figures and stuff on my layout and I was wondering what adhesive people use to stick them down.
Charles. |
CHARLES SHARPE |
Joined: 27/08/2005(UTC) Posts: 11,071 Location: Murrumba Downs QLD
Charles, Usually PVA BUT if I think I may move them at a later date I use "Blue Tack" Or White Tack. Not sure what you call it in the UK. It is a bit putty like but sticks and does not go hard. But it does stick like muck to a blanket. |
NOt wearing the Pink Pinny, which is hard to see and now I have a white Pinny which also is hard to see against MY pure white Skin Still have 2 new shiny tin Hips that is badly in Need of Repair matching rusting tin shoulders and a hose pipe on the aorta Junior member of the Banana Club, a reformist and an old Goat with a Bad memory, loafing around |
 1 user liked this useful post by nevw
Joined: 15/09/2006(UTC) Posts: 625 Location: Nuremberg, Bavaria
I'm usually using "Loctite" instant ahesive.
Previosly I also used PVA, but if you take a little bit to much adhesive, it causes some kind of "bubbles" around the feet of the Preiser figures.
Regards, Florian |
H0 3-rail AC with DCC, MM and mfx, 2-rail DC streetcars, and N gauge |
 1 user liked this useful post by Frankenbahner
Joined: 02/01/2009(UTC) Posts: 1,067 Location: Auckland, New Zealand
Super glue works for me, provided you don't want to move them again.
Cheers, Rick
 2 users liked this useful post by kariosls37
Joined: 23/08/2006(UTC) Posts: 2,597 Location: Beverly, MA
 1 user liked this useful post by kbvrod
Joined: 14/03/2005(UTC) Posts: 15,871 Location: Gibraltar, Europe
I used to use Super glue, but after a while I had a lot of Preiserlings with no feet when they had been knocked off the layout!  Now I use either white glue or Humbrol polystyrene cement, depending on whether I'm sticking them to wood or plastic. You have to find whatever works best for you. On my layout I tend to knock the figures off frequently as I clean the track or dust off the buildings. This will happen irrespective of the glue you use, but obviously if you use something quite weak like white glue or blue tack it will happen more often. If they are stuck on too firmly, as with superglue, then the feet will break off. You need to find a balance... |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
 3 users liked this useful post by RayF
Joined: 15/08/2012(UTC) Posts: 234 Location: Perth, Western Australia.
Ray I can see a market for Preiserling wheelchairs on your layout. (or a good surgeon) Dr D, can you explain further your wax composite? How would it handle 50 degree Celsius temps? Regards.....Chook.
 5 users liked this useful post by Chook
Originally Posted by: nevw  Charles, Usually PVA BUT if I think I may move them at a later date I use "Blue Tack" Or White Tack. Not sure what you call it in the UK. It is a bit putty like but sticks and does not go hard. But it does stick like muck to a blanket. Hi. Yes we have both colours of tack in the UK. Charles. |
CHARLES SHARPE |
Originally Posted by: Chook  Dr D, can you explain further your wax composite? How would it handle 50 degree Celsius temps?Regards.....Chook. Hi Chook,all, I won't give you a history of this but it was first used by dollhouse modelers to attach items to walls that were wallpapered.It is easily removed and will not tear the paper,so,... Here is one brand: http://www.department56.com/pro...amp;keywords=tacky%20waxYou can warm it between your fingers to soften it,place a dab on the bottom of the figure and then place it anywhere even on scenery.It will not lift it nor paint and easy to clean any residue.This is an easy way to move figures around and change a scene. Chook,it is a wax,I don't know what would happen at that temp.Try it! Dr D
 2 users liked this useful post by kbvrod
To glue the fireman and engineer in a loco I used with success Noch 61120. They can be removed with relative ease and without damage.
Best regards, Miguel
Mostly Märklin H0.
 2 users liked this useful post by mbarreto
Joined: 29/01/2012(UTC) Posts: 1,422 Location: Montreal, Canada
Hi Charles,
Superglue if you want permanence and are good at getting it right the first time, upright and in the place you want them. White glue is great to be able to tweak the position as they dry. And the "white" of the glue drys matt and transparent.
Wax or blue tack if you want to reposition them a lot.
Not tried, but I have also seen pins attached to the bottom, where you can just pin them into styro or soft-based layout and reposition when you like. Of course, too many repositionings with this technique would make for the many bulletin board holes. However, this way might help to avoid them leaning in directions you don't want.
Let us know what you decide on, or how it goes. I think the biggest question is trying to work out the narrative of how the figures interact and create your story with the surroundings.
- Mark
DB DR FS NS SNCF c. 1950-65, fan of station architecture esp. from 1920-70. In single point perspective, where do track lines meet?
 1 user liked this useful post by Mark5
I also use the Noch 61120 "Hin und Weg Kleber", it's easy to apply and as Miguel says, it's quite easy to move the Preisers afterwards :), great when Junior want's to move the figures around, but it works best on suitable surfaces, e.g. not good on grass in my experience :)
^__^ Mike |
A single track on the floor is better than no track at all... |
 1 user liked this useful post by MikeK
Hi all, If anyone clicked on the link I posted,Tacky wax is cheap and that 1oz tube could do every Preiser figure on Miniature Wonderland! I got one on eBay for 99¢ + free shipping. Yes,some figures can/should be always a part of the layout,favorite scenes,etc.Those would be glued down depending on the the surface material. Where it bothered me was at station platforms,in the Bw "Are you people just going to stand there?"  So I would move them and/or replace them before a session. Dr D
Originally Posted by: kbvrod  Hi all, If anyone clicked on the link I posted,Tacky wax is cheap and that 1oz tube could do every Preiser figure on Miniature Wonderland! I got one on eBay for 99¢ + free shipping. Yes,some figures can/should be always a part of the layout,favorite scenes,etc.Those would be glued down depending on the the surface material. Where it bothered me was at station platforms,in the Bw "Are you people just going to stand there?"  So I would move them and/or replace them before a session. Dr D I think my people will remain in the same place all of the time. Perhaps later on I might think I would like to change them but not sure. Charles. |
CHARLES SHARPE |
 1 user liked this useful post by charles Sharpe
Wouldn't Marmite or Vegemite do the job? |
Juhan - "Webmaster", at your service... He who asks a question is a fool for five minutes. He who does not ask a question remains a fool forever. [Old Chinese Proverb] |
 3 users liked this useful post by Webmaster
Hello Juhan. Never thought of that. We have lots of it my wife has eaten it for the last 40 years at lunch time on ryvita. It is also very good to stop nat bites etc. My wife never gets nat bites I always do so when I to scotland at the end of may I wil eat marmite the month before. I know it works as I know a army doctor who tells the soldiers to take when they go in the jungle. Charles. PS sorry to go off the thread a bit. |
CHARLES SHARPE |
Joined: 02/01/2006(UTC) Posts: 878 Location: Stockholm, Sweden
Originally Posted by: kariosls37  Super glue works for me, provided you don't want to move them again.
Cheers, Rick Hi Rick, I haven't noted any movements in the package and even not when I tickle them with my soft paint brush, so I don't think they would like to move later either.. (Now I really thought I was funny. I'm just dying from laugh here the last 5 minutes) |
 3 users liked this useful post by Martin T
Joined: 28/11/2007(UTC) Posts: 8,243 Location: Montreal, QC
Hag used to sell a product called autofix which was designed to hold cars on their BLS car carriers. It can also be used to keep Preiserleins in place.
 2 users liked this useful post by mike c
Originally Posted by: MikeK  I also use the Noch 61120 "Hin und Weg Kleber", it's easy to apply and as Miguel says, it's quite easy to move the Preisers afterwards :), great when Junior want's to move the figures around, but it works best on suitable surfaces, e.g. not good on grass in my experience :)
^__^ Mike How long does it take to dry. Charles. |
CHARLES SHARPE |
Joined: 10/11/2006(UTC) Posts: 455 Location: Pacific Ocean
 1 user liked this useful post by hgk
Originally Posted by: hgk  Hi George,all, Same as the Noch product they work with each other (Noch&Woodland Scenics) Dr D
Originally Posted by: charles Sharpe  Originally Posted by: MikeK  I also use the Noch 61120 "Hin und Weg Kleber", it's easy to apply and as Miguel says, it's quite easy to move the Preisers afterwards :), great when Junior want's to move the figures around, but it works best on suitable surfaces, e.g. not good on grass in my experience :)
^__^ Mike How long does it take to dry. Charles. Hi Charles. It takes about 3 hours to go off /set. Charles. |
CHARLES SHARPE |
Joined: 30/01/2004(UTC) Posts: 276 Location: Houston, Texas
Charles,
I have used Detail Tack sold by Micro-Mark. It stays sticky but is not visable and also good for autos and other detals. I assure you that once you have used it you will also never return to using glues.
Tex
 1 user liked this useful post by Tex
Joined: 18/08/2007(UTC) Posts: 1,081 Location: Denmark
I also use the Hin und Weg-kleber or the Scenic Accents Glue from Woodland Scenics, which is the exact same product. I use it for more than Preisers. I also use it to mount phonebooths, mailboxes and the like. It is very easy to work with, and I would definitely recommend it. |
 1 user liked this useful post by sjlauritsen
Joined: 22/11/2006(UTC) Posts: 676 Location: Shoreline, WA
All, has anybody used the new glue from MBZ? Reynaulds has a youtube video: Probably cost a boatful of gold... |
Thom European Train Enthusiast - Pacific Northwest Chapter 4th Division, Pacific Northwest Region, National Model Railroaders Association |
 1 user liked this useful post by seatrains
Joined: 22/01/2009(UTC) Posts: 14,878 Location: On 1965 Märklin Boulevard just around from Roco Square
the downside of it is it attracts cockroaches, ants and other insects and some people may can smell the extract and you could have a lot of noses in one area, fighting for the closest spot I'm using super glue, a.) if I ever have another public display, (people can't take it off unless they break it , my son uses hot glue but I don't particular like it because it leaves the glue showing and if you use less they don't stand up or by the slightest touch fall over. with superglue you would have to give them quite a hard knock to break them. John |
 2 users liked this useful post by river6109
I use super glue to fasten my Preiser figures. When i pull them of,i use sharp hobby knife and cut loose them underfoot. |
H0 DCC = Digital Command Control
 2 users liked this useful post by Goofy
Joined: 23/02/2011(UTC) Posts: 171 Location: Kansas, USA
I like to move my figures around a lot. I use left over clear window foil as a platform for each Preiserling. I paint the platform a flat color and add a little static grass or dirt to eliminate the gloss look. The foil is very thin and doesn't show to bad. However, I like the other sticky products mentioned and will try those in the future.
Gary
 4 users liked this useful post by glight1
Joined: 27/12/2009(UTC) Posts: 1,165 Location: Western Cape Cape Town
I use white (cold) glue; works well, and when dry doesn't show any of the glue residue. Have to be careful when positioning them that they don't start leaning over! Folk would think they been getting too much Marmite!! Whatever you use to support the figures while the glue sets, just be careful not to get the "supports" stuck in the glue as well!! I speak from experience..... regards, Joe
 1 user liked this useful post by Joseph Meiring
Joined: 22/09/2009(UTC) Posts: 2,073 Location: Edinburgh,
I use flock glue - I think it's by WS but I'm not sure. It is a type of PVA but dries clear so doesn't stand out.Being so tacky it doesn't need long for it to go off and support the Preiserling unaided.
It also gives me the option of moving them if I need to.
Mike |
1957 - 1985 era What's digital? |
 1 user liked this useful post by hennabm
Hi. In the end I have used 4 types of glue PVA and Preisers own were I can get some thing next to to support it Hot melt glue in places like woody and grass places and super glue were I needed speed for the glue to go of i.e. station platforms. This last week I have been doing the platforms 30 people on each of 3 platforms and what I did was put a bit of super glue on the end of a wooden tooth pick and use that to put the glue onto the feet of people. Many thanks for all your ideas. Charles. |
CHARLES SHARPE |
Joined: 04/12/2013(UTC) Posts: 2,266 Location: Hobart, Australia
Originally Posted by: charles Sharpe  I am at the stage on my layout to start to but some Preiser figures and stuff on my layout and I was wondering what adhesive people use to stick them down.
Charles. Hello Charles, I note this reply is only one year late! When fixing the preiserlings to a flat surface I use Faller Expert glue if the plastic is suitable such as here:   Some plastics will not adhere to the plastic glue and then I use super-glue as here:    At times some surfaces are flat but not plastic (some rubber-like) and I use Woodlands Scenics "hob-e-tac" as seen on this road surface:   When there is an irregular surface I again use Woodlands Scenics "hob-e-tac" such as these 2 chaps arguing on the irregular surface of the steam service facility yard or the huntsman in the hills fixed to irregular surface scenics:   Regards, PJ
 7 users liked this useful post by PJMärklin
