Offline kweekalot
#1 Posted : 28 February 2013 14:25:59(UTC)
kweekalot
Hi All,
The last months I wanted to purchase an 'electrostatic flocking device', but I'm shocked by the high cost. Blink
Some examples:
  • Faller 'Gras-Fix': € 99,=
  • Heki 'Flockstar': € 150,=
  • Heki 'Flockstar XL': € 210,=
  • Noch 'Grasmaster': € 155,=
  • Langmesser 'Profi-Flock' : € 859,=
Perhaps such flocking devices are worth buying if you have a MiLuWa layout in your train room, but for my smaller layouts I find those too expensive.
And if you look on the many German MRR forums, most users aren't really satisfied with the devices.
The Noch Grasmaster is already renamed as the 'Gras Desaster' and the Heki Heki Flockstar as the 'Flock Loser'.
Many heart complaints are that the batteries are low quickly, the fibers are falling over the edge when shaking the Faller Gras-Fix device, the Noch Grass Desaster is awkwardly big, the high voltage too low, the results disappointing ... etcetera.
Almost all users do some kind of modifications to their device to achieve better results.
There was a good and affordable device, the XTEQ Tools "Grass-O-Mat" for only € 59, =, but it has mysteriously disappeared from the scene and is no longer sold.
The only real good flocking device that remains is the Langmesser 'Profi Flock', but with € 859 a bit too expensive for me.
Many modelers build their own electrostatic flocking device, the costs are no more than € 10 and the functionality is similar to the Langmesser 'Profi-Flock' device.
I really enjoy reading the many home made construction reports on the internet, some home made flocking devices looks clumsy, some are real look alike clones of the Langmeser 'Profi Flock'.
It seemed fun and useful to me, to start a Flocking device thread here too on the forum.
I also want to make my own device and start with a simple one, and if I've gained some experience with it, build a profi one.
For a start here some pictures of the more official 'electrostatic flocking devices':
Marco
FALLER GRAS-FIX
NOCH GRASMASTER
HEKI FLOCKSTAR
HEKI FLOCKSTAR XL
LANGMESSER PROFI FLOCK
XTEQ TOOLS GRASS-O-MAT
Offline Danlake
#2 Posted : 28 February 2013 15:07:07(UTC)
Danlake
Hi Marco
Good idea with this postThumpUp
I am using a cheap one bought from Micromark.
Sure it's not perfect, but for small areas it works just fine and get the job done. And only cost 40 US$Cool
https://www.micromark.co...rass-tech-usa,10399.html
Brgds - Lasse
Offline NZMarklinist
#3 Posted : 28 February 2013 15:19:45(UTC)
NZMarklinist
I have seen grass being applied in MiWuLa on a video somewhere.
They use what looks like the Langmesser 'Profi-Flock'
I have a Noch Grassmaster and with the small funnel attachment it is very versatile and works well ThumpUp
Glen
Auckland NZ
Offline kweekalot
#4 Posted : 28 February 2013 15:25:17(UTC)
kweekalot
Hi Lasse,
Many thanks for your link !! ThumpUp
I didn't know that Micromark device.
Marco
Offline kweekalot
#5 Posted : 28 February 2013 15:31:20(UTC)
kweekalot
And here are some photos of German home made devices ....
HOME MADE FALLER GRAS FIX CLONE
HOME MADE NOCH GRAS DESASTER CLONE
HOME MADE LANGMESSER PROFI FLOCK CLONE
thanks 3 users liked this useful post by kweekalot
#6 Posted : 28 February 2013 15:42:19(UTC)
Hi All,
Some examples:
Marco
I must tell to you that Noch grass master has been upgrade.
Version is now 2.0 and itemnr is 60135.
This grass master has now 20,000 volt while the old 60131 which i have now is about at 15,000 volt.
My grass master is excellent up to 6 mm high grass.
I can use 12 mm high grass too but not so good results than what 20,000 volt grass master can do.
Offline kweekalot
#7 Posted : 28 February 2013 15:49:32(UTC)
kweekalot
Hi Glenn,
It would be great if you can upload that Langmesser Profi Flock MiWuLa video here !!
Marco
Offline kweekalot
#8 Posted : 28 February 2013 15:55:57(UTC)
kweekalot
Hi Anders,
Thanks for this information ! ThumpUp
The Faller device is only 5000 Volts.
The Langmesser 'Profi-Flock' is doing 70.000 Volts. Scared Scared Scared
I think the shock of the Langmesser device is somewhat unpleasant. Razz But not fatal.Smile
Marco
Offline kbvrod
#9 Posted : 28 February 2013 20:26:08(UTC)
kbvrod
Hi Marco,all,
Great topic!
I have the Noch unit on loan from a friend to scenic his Z layout/module.Here are some tips I found in it's use:
1) There are 2 'filters' (plastic pieces with different size and number of holes)that can be fitted on the grass container,one for short grass(2mm) and longer grass(5mm+),They work well in that regard.
2) It is important to break up clumps of the static grass before you fill the container and to shake it during use.
3) Move the ground connection close to the area your applying the grass in(it will help it stand up better)
4) Make sure to shut the unit off when done,it will drain the battery!Laugh
5) Having a funnel at the end of the unit,let's you control where it goes.A general application on land or hillsides are ok with the broad based applicators.
6)If near tracks or structures,tape and cover them!Static grass will cling to them,glue or no,....
7) Have fun!BigGrin
Dr D
thanks 2 users liked this useful post by kbvrod
Offline Iamnotthecrazyone
#10 Posted : 28 February 2013 21:34:46(UTC)
Iamnotthecrazyone
Views messages in topic : 1,048
I am glad to see I wasn't the only one not liking them.
thanks 1 user liked this useful post by Iamnotthecrazyone
Offline Mark5
#11 Posted : 28 February 2013 23:15:35(UTC)
Mark5
Hi Kevin
So how well does it work on curved hillsides and odd surfaces?
I am guessing its the wetness of the glue that creates the conductivity.
Also supposing that once dry, you can vacuum or somehow clean up the unglued excess.
Agree with Marco that video links would be helpful here.
Thanks for all the great info Gentlemen!
- Mark
Offline kbvrod
#12 Posted : 28 February 2013 23:18:01(UTC)
kbvrod
Then all you have to do is buy 'tufs' or grass mats and cut them to fit.Glare
DR D
Offline kariosls37
#13 Posted : 01 March 2013 00:38:45(UTC)
kariosls37
I built a static grass applicator a while back, dead simple really. It consists of a electric flyswat, a emty jar of peanut butter and some odds and sods.
I haven't had to grass anything in a while, but the applicator wasn't that powerful on 2 AA batteries. When I get on with grassing my next layout, I intend to stick a 9V battery into it and see how that goes. The thing I like about it not being too powerful is that not all the grass stands upright, which especially on a paddock is not the case.
Attached is a photo of my device.
Rick
kariosls37 attached the following image(s):
thanks 1 user liked this useful post by kariosls37
Offline Mark5
#14 Posted : 01 March 2013 07:12:33(UTC)
Mark5
Looks great Rick!
I'd love to see the results of what you did with it... makes sense about the grass needing to look "organic" ...
... was wondering about exactly with a mega-charged unit.
- Mark
#15 Posted : 01 March 2013 07:50:47(UTC)
Iamnotthecrazyone
DR D
They are certainly my first choice. I had only limited experience with the Noch and I wasn't too convinced about, someone mentioned spraying the grass with water for better results but I've never got around to try that. Unfortunately, The device wasn't mine and I no longer have access to it, I wouldn't pay the price to give it a second chance.
#16 Posted : 01 March 2013 09:53:23(UTC)
Some examples:
And the Gras Master 2.0 is also cheaper - 119.74 eur at Lokshop.
Offline kariosls37
#17 Posted : 01 March 2013 10:44:35(UTC)
kariosls37
You ask, we produce...
thanks 2 users liked this useful post by kariosls37
Offline kbvrod
#18 Posted : 01 March 2013 17:42:22(UTC)
kbvrod
That puzzled me too! Noch said to never add water and Scenic Express said to lightly mist itConfused Blink .This was in the chamber that holds the grass.
Dr D
thanks 1 user liked this useful post by kbvrod
Offline kbvrod
#19 Posted : 01 March 2013 17:59:57(UTC)
kbvrod
[Hi Mark,all,
>So how well does it work on curved hillsides and odd surfaces?<
Fine,I usually use an earth colored acrylic paint(cut 1:1 w/water) as the 'glue'. Then, again it depends on what area is being scenic.
>I am guessing its the wetness of the glue that creates the conductivity.<
No,the applicator creates an electrical charge in the fibers + and - at each end so they will land straight up(sometimes Smile )
Even after the paint is dry,you can apply slightly thinned coat of matte medium over the area and then apply the grass.
>Also supposing that once dry, you can vacuum or somehow clean up the unglued excess. <
One would be surprised,this stuff clings to everthing(* see my tip on masking above)
>Agree with Marco that video links would be helpful here. <
I did a search on YouTube:
https://www.youtube.com/results?....0.0...1ac.1.K4yDAMFJlRo
Dr D
thanks 3 users liked this useful post by kbvrod
Offline Lollo
#20 Posted : 03 March 2013 23:29:59(UTC)
Lollo
You might find these links useful. You can build a high power static grass applicator for little cost.
http://model-trains-video.com/MTV-0011.php
In the video it shows you how to do it, and you can buy the Ion generator for $25 USD
http://secure.oatleyelec...02853d4867849a58f940a953
This Ion generator only costs $14 AUD
I use a electronic fly Zapper from Bunnings for my first static grass applicator, and works well.
Plan to modify my existing one with an ion generator from above.
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
thanks 2 users liked this useful post by Lollo
#21 Posted : 16 December 2015 11:49:16(UTC)
I'm not sure why I didn't post these when this thread was first created, but there are a few articles and videos on the internet on how to make your own grass applicator.
http://modeltrains.about...-Model-Train-Scenery.htm
http://spiderfield.ommer...-static-grass-applicator
thanks 8 users liked this useful post by Bigdaddynz
Guest (14)
This page was generated in 0.882 seconds.
