Offline marklinologos
#1 Posted : 12 February 2013 18:46:25(UTC)
marklinologos
Hi to all,
I want to ask if is possible to connect and use in my layout digital signals from marklin-type 76XXX with my mobile station 2 60653. If yes, how I can program the signals for adress with mobile. Usually programmed with 6021 control unit or central station.
Also I have an idea to use the signals with contacts 24994 -24995 (for automatic) and with control boxes too (for manual use) by put switches in the cables of contacts and go the contacts off when I want to play manual.
Is this possible or you believe that I will have problems...? Do anyone of you try this way or another tip for manual and digital use..?
Thanking in advance,
Keep Marklin away from China
This page was generated in 0.296 seconds.
