Offline Danlake
#1 Posted : 09 February 2013 09:29:44(UTC)
Danlake
Short question regarding Marklin transformer 6647.
Supposed to be 4-16V and yellow output of 16V.
I got 230V in house and both of my brand new transformers are consistently giving 19.5V?
As I will soon install more Viessmann signals (they are being powered from these transformers) I am just getting slightly concerned if the higher voltage can damage the LED in the long run? And what about other lights that normally goes with standard 14-16V used in model rail roading?
Thanks in advance!
Brgds - Lasse
Offline Markus Schild
#2 Posted : 09 February 2013 11:03:23(UTC)
Markus Schild
Hi Lasse,
Measuring transformers without load always returns wrong results. Just connect a small bulb to the transformer and repeat the measuring. You will get something between 16 and 17 VAC.
Markus
Offline Danlake
#3 Posted : 09 February 2013 11:31:31(UTC)
Danlake
Thanks Markus,
I learned something new today!
Brgds - Lasse
#4 Posted : 09 February 2013 12:44:08(UTC)
16 V is the output voltage you should get with 230 V input voltage and 32 VA load. Less load, more output voltage.
As Markus wrote, measuring without load gives a useless result.
#5 Posted : 14 February 2013 10:03:26(UTC)
Also, what is the rated input of the Trafo on the label, is it 230VAC or 220VAC?
Even though NZ is a 240v supply country, there are LOTS of 220v trafo's to be found here, in fact 240v ones are more rare.
Did you find the output more in line with what you expect with a load on?
Interesting.
Steve
#6 Posted : 14 February 2013 11:12:49(UTC)
For about a decade now, Europe has a unified "compromise" voltage of 230 V and all recent M* products (including 6647 and 66470) are for 230 V.
IIRC my 6647 gives slightly more than 18 V without load.
Offline Danlake
#7 Posted : 14 February 2013 14:24:09(UTC)
Danlake
Steve
Hi Steve,
Are we not on 230V in NZConfused
http://www.trustpower.co.nz/index.php?section=79
My transformer is labelled 230VAC and bought from Germany. I will check with load on once I get back home from work - in 3 weeks time...
Brgds - Lasse
#8 Posted : 14 February 2013 20:43:19(UTC)
Steve
Hi Steve,
Brgds - Lasse
Just checking you were all paying attention Razz
It's true, a little knowledge can be dangerous, (mental note to self, double check what you write....).
Yep, you're quite right, 230v is the 'official' rated supply, with a tolerance of +/- 6% which gives you anywhere from around 215v right up to 243v. Usually my checks have been on the high side, just checked now (with a Fluke meter), 238.6v (with load).
I also happen to be doing my current loco testing with a 240v Trafo so I just seem to have 240v 'stuck' in my brain. My 240v is therefore retracted, and in the words of a certain MP using silly language recently, I apologise unreservedly Smile
230 230 230 230
Let's see if that sticks BigGrin
Otherwise, looks like I'm back to electric-school 101.
This page was generated in 0.379 seconds.
