Offline Lars Westerlind
#1 Posted : 13 January 2013 19:54:33(UTC)
Lars Westerlind
Hello all,
Time is closing to retire my beloved Intellibox I, but are there better alternatives? In this subject I would like discussions about Loconet capable systems only please. For me it's a demand that the system has full LocoNet, that is, alla commands and feedback signals in the system must be visible to all clients on LocoNet as well. Another demand is that it should be able to send both Motorola commands and DCC, including Motorola old functions.
To my knowledge that gives us this list (please correct me) in order of my current degree of interest:
1. Roco z21.
2. ECoS with Lnet converter
3. Intellibox II
4. IB-com
5. Digitrax; they possibly can send also Motorola commands with one central, but am not sure if they do it simultaneously with DCC.
6. More or less home built soultions, where central functionality.
This is a list of "centrals", that is, that is keep speed, direction etc of Locos, and accessory commands, and converting it to track commands.
My comments:
1. It appears very promising but far away from ripe. I like the apporach very much if only it will show full functionality and quality. I certainly like to use pads and phones for control.
2. Reviews highly appreciated. If I were to buy know, it seems the best.
3. Yes, a definie advantage is that it would allow for LNCV programming of my other utilities. The Intellibox has served me well, but Uhlenbrock is not doing a good customer service, and they do not the best SW in my taste.
4. Smart to avoid monolitic soultions, but doesn't have WIFI and not a good supporting community.
5. Digitrax is not my favourite; I feel a bit angry about how the handled the LocoNet licenses, and they have serveral peculiar solutions to me. No, not interested.
6. Well, I'm somewhat lazy.
Comments anyone? In particular, does anyone own a L.net converter?
/Lars
thanks 1 user liked this useful post by Lars Westerlind
#2 Posted : 13 January 2013 20:05:12(UTC)
1: LocoNet can control speed of locos, but no functions. Looks good on the feature least but is far from what you expect.
2: Was announced in 2011 for February 2012, not delivered yet, so no reviews available. Time will tell whether the Z21 team can implement LocoNet faster than the ESU team ...
If you wanna buy soon, look for 3, 4, or 5.
2 sounds promising, I consider getting one for my ECoS 60212.
#3 Posted : 13 January 2013 20:31:03(UTC)
Lars Westerlind
Ah,
that explains the lack of news regarding L.net cconverter. Seems I'll have to wait then; lets hope on Nürnberg fair. I guess Roco at least may stir up some activity from a sleeping market.
L
#4 Posted : 13 January 2013 20:48:04(UTC)
I suppose the real need for Loconet is due to your UB Lissy system, right?
And since that eg the CS2 can only accept red/brown output from the IB via the 6021 connect option, it limits that kind of solution, even if the IB should be able to work as a "slave" serving the Loconet functions independently. Would be interesting to know if any member has tried this kind of interconnect thing...
To me, the Ecos + the Loconet adapter looks like the most promising path so far...
Offline graafjp
#5 Posted : 13 January 2013 21:15:42(UTC)
graafjp
Well I also have a mixed setup using Loconet and CSII.
I use loconet for switching operations with the Uhlenbrock Track-Control, Intellilight and Lissy receivers. My sound locs are equiped with Lissy transmitters.
Sole purpose for the Lissy equipment is that I can now switch the sound on/off when a train leaves/enters my hidden parts of the layout.
I use an Uhlenbrock 6021 adapter connected to the Marklin Connect 6021 which is connected to my good old 6021 cu. All turnout controllers (6083)/signals are connected to the 6021.
For block automation and shadow station operation I use the IB-switch.
The Connect 6021 has a connection to my CS2 (60214).
So I use loconet for switching operations via the Track-Control panel and sound on/off operations and the CSII for running my locs.
One thing that does NOT work is giving a switch command on the CSII as this will most of the time results in a STOP situation on the CSII and 6021.
(This behaviour has already been described in the original Connect 6021 thread).
As long as switch commands ONLY come from the Loconet all keeps working ok. I can see the status of all switches/signals on the layout I defined on the CSII.
Furthermore the Track-control is not able to switch signals with 3 or 4 possible positions with a single button but I use an extra button to realise this.
I e-mailed Märklin once asking if a real loconet adapter would ever be made (as ESU has planned) but I never received an answer to that question.
If the Loconet adapter from ESU ever emerges and does REALLY work without limitation for the above setup perhaps I would consider switching my CSII for an ECos.
Jos
#6 Posted : 13 January 2013 21:32:18(UTC)
Lars Westerlind
Well, I'm addicted to LocoNet in several ways, entirely due to Uhlenbrock smart devices: Lissy, Intellilight, sensors, Track control, in all, they showed how to use netrwork and distribution, but don't have the power to supply a good central. In my opinion the z21 is a very good idea; the central should *NOT* IMHO provide GUI functions; leave that to other devieces. It should supply a good and relieable software to make sure commands from any throttle are reliable sett to the locos, also if they occur at the same time (I have some problems with that, thereefore not very keen on IB II).
Today it certainly seems very smart to use laptops, pads, and/or phones, which so a built in WIFI seems a good thing, much better than to pay a lot of money for a screen that is not good enough anyway. IMHO.
Another way put: I like LocoNet because of the potential to exchange some items without having to change the whole system. But so far I've not felt the suppliers play the same game; my feeling is that Digitrax have a sever guilt in that.
/Lars
#7 Posted : 14 January 2013 01:56:02(UTC)
Correct me if I am wrong, if I understand correctly Digitrax still have enough "ownership" of the loconet protocol that 3rd party developers require their certification. This will probably slow the deployment process of make sure it is stable from the getgo when it does appear.
Other question relating to the likes of ESU, Z21 etc is how they are going to make/promote/certify the various loconet device.
Personally I would always expect to need have a backend infrastructure (loconet) and a separate front end "Central" to convert the commands out to the track. Option 6, with a PC as a mediator, for me is the most realistic way to proceed in order to get/stay productive. If a vendor finally delivers a verifiable solution then by all means bypass the PC. However once the PC is involved other (tailoring) possibilities open up.
If your IB1 is failing, that may make a difference but if not I would retain it as the LocoNet master, even if it did not connect to the track. and find an interface to the Central of your preference.
#8 Posted : 03 February 2013 14:13:29(UTC)
Lars Westerlind
Nuernberg fair has come, but little real news have reached me regarding this subject. Updateds anyone?
z21 still seems interestring for me, but not until
- LocoNet implemented
- open API documented.
Uhlenbrock release a new Daisy II throttle; I like the ergonomics of nr 1 so I will probably get one. Uhlenbrock, IB2, is still an option, as it has LNCV programming which will probably not be available in any other solution. But I'd like a more ready smartphone/pad solution, and better support.
ESU L-net adapater - as said, still announced but not yet realesed, and no news. Anyone?
#9 Posted : 03 February 2013 16:23:33(UTC)
Please note that there is z21 and Z21 (and little is known about z21, the new starter set controller).
#10 Posted : 03 February 2013 16:38:21(UTC)
Lars Westerlind
Ah yes,
but this thread is about Z21 only, as z21 doesn't have LocoNet.
CHeers.
Offline GSRR
#11 Posted : 03 February 2013 17:04:44(UTC)
GSRR
Originally Posted by: Lars Westerlind Go to Quoted Post
Ah yes,
CHeers.
Lars,
I think Tom was politely pointing out that you referred to z21 lower case in post #8, no?
Picking up on what Peter said. There are ownership issues, and it seems there are delays to new items coming to market.
If you we're to purchase an IB II, then use a PC with say iTrain installed, would this meet your needs, and protect your investment?
r/Thomas
http://berros.eu/itrain/en/systems.php
#12 Posted : 03 February 2013 18:39:48(UTC)
I didn't know that z21 comes without LocoNet.
So far you always wrote z21 in this thread. I just pointed out that z21 has a new meaning since Roco revealed their tradefair new items.
z21 seems to have X-bus connectors at the front, but they write that a smartphone or tablet is needed - therefore I have no clue which interfaces the z21 will have.
#13 Posted : 03 February 2013 21:40:29(UTC)
Possibly not a bad idea, given that the professional version of iTrains can interface with more than one digital controller at the same time.
I had been thinking of getting a couple of the ESU Loconet adapters, if only to see if that would allow me to connect a CS1R to an Ecos as remote controllers. Seems I can't do this at the moment as the Loconet adapter is 'vapourware'!
#14 Posted : 04 February 2013 18:46:37(UTC)
Lars Westerlind
Ah yes,
CHeers.
Lars,
r/Thomas
Sure,
sorry for beeing unclear. Appreciate that you poiinted out z21/Z21 this for me, I'll try to but it correctly hereafter.
And yes, the http://www.z21.eu/Start-mit-Z21/Experten points out that z21 lacks LocoNet, CAN, one X-bus, Snifferbus,
programming track connecxtion, as well as Voltage setup (if understood correctly)
#15 Posted : 04 February 2013 19:03:25(UTC)
Hi, Lars,
thanks for the link. I clicked on "z21" to find information about "z21" - but you have to click on "Z21" to find what's missing in "z21". As I said elsewhere, "z21" is a "Z21" without the interfaces that aren't working yet ...
And their web site is as intuitive as their controller naming convention.
Still a lot "not yet" in their FAQ list.
Offline Rinus
#16 Posted : 04 February 2013 19:39:18(UTC)
Rinus
Hi all!
I bought a IB2 recently. My old IB IR broke down. Since I'm working with Uhlenbrock Lissy system and I've got quite a lot of this, the choise was very limited and therefore easy. I eventualy choose of the IB2, and I must say I like it very much.
The interface has improved. Menu structure etc is pretty much the same, but its much easier to find your way. The larger screen and more selection buttons provide a better interface than the old one. Also the connectors to the power supplie are of a better quality and there is a USB available at last.
Only downside was its price. I got mine for 433 and thats quite a bag of money.
Rinus
#17 Posted : 04 February 2013 20:00:00(UTC)
Lars Westerlind
Hello Rinus,
thank's for your resume; I wonder - could you tell more about the interface? I could only find p50x on UB site; do you/anyone have what appears to be the new API?
IBII certainly is an option for me. If I will choose another option I think I must either change central for programming, or possibly, using a LocoNet interface do the programming from a computer. Using a computer all the time is not what I desire, but I might be forced to change my mind.
Offline Rinus
#18 Posted : 05 February 2013 08:59:28(UTC)
Rinus
Hi Lars,
I myself am using it in combination with RocRail, which also supports the Lissy system. p50x was one of the options but there where more. I will check this evening.
However sometimes I don't want to use the computer and use only the Ib instead to perform a quick run around the layout or to test something.
Rinus
BTW: very good to see you back on the Forum! ThumpUp ThumpUp ThumpUp
#19 Posted : 24 March 2013 19:01:53(UTC)
Lars Westerlind
Ok, time has passed.
meanwhile following has happened on my horizon:
1. Z21 have release the x-bus based API, but no signs of a proper LocoNet implementation.
2. My dealer tells that ESU are supposed to release the LocoNet interface this summer.
3. I'm still working with what I really want.
No ideal solution. So at last I started consider a JMRI. I did not want a computer solution, for unclear reasons, but begin to realize that this might might be just what I need. More about that in a separate thread.
thanks 3 users liked this useful post by Lars Westerlind
Guest (6)
This page was generated in 0.698 seconds.
