Offline Lokführer du 3e Rail
#1 Posted : 01 January 2013 15:19:29(UTC)
Hello all,
I'm searching for the list of active CV's and their value to reset my Fiegende Hamberger 's decoder.
Thanks in advance.
#2 Posted : 01 January 2013 18:03:20(UTC)
Hi, and welcome to the forum!
The prototype train didn't have any CVs (wrong forum, Digital forum would be more appropriate).
The Märklin model is not the "Fliegender Hamburger", it's just the successor "Bauart Hamburg".
The decoder is an ESU decoder. Just write value 8 to CV 8 to reset the decoder to factory defaults. The default values cannot be read from the decoder.
#3 Posted : 02 January 2013 01:39:37(UTC)
#4 Posted : 02 January 2013 18:04:31(UTC)
Hi and Welcome to the forum.
Offline RUBEN SPAIN
#5 Posted : 02 January 2013 19:04:49(UTC)
RUBEN SPAIN
Originally Posted by: Lokführer du 3e Rail Go to Quoted Post
Hello all,
Thanks in advance.
Do you Know you can upgrade the 37770 with a ESU loksound? I have installed a loksound into my VT 137 and it looks wonderfull.
There was a ESU KIT for this train. It was 61450 and came with the square speeker that fits perfectly into the train. This is very old and maybe dificult to find now but you can use the 62450 (loksound V3.0 mfx) and buy a 100 ohm square speeker with ESU 50448 reference
If you want a V4 then the reference is 64450 Loksound V4 mfx. You will need the 4 ohm 50334 square speaker
Here I attach a file with photos of my train and the manual of instalation.
File Attachment(s):
37770.rar (1,183kb) downloaded 128 time(s).
manual.rar (672kb) downloaded 89 time(s).
thanks 3 users liked this useful post by RUBEN SPAIN
Offline jeehring
#6 Posted : 04 January 2013 11:00:23(UTC)
jeehring
Thank you Ruben.
....excuse me, what is ".rar" ?
My PC asked me if I really want to accept a modification of my hard disk...and is announcing "Editor = unknown".... Confused
Is it normal ? Confused
#7 Posted : 04 January 2013 11:09:06(UTC)
Roland, rar files are an archive file like zip files. You should be able to extract the rar file with the latest versions of Winzip, but Winrar is the program used to create rar files.
http://www.rarlab.com/download.htm
#8 Posted : 04 January 2013 11:27:22(UTC)
My Laptop says the same.
Ruben, can you please change the files to a format which is recognised by most PCs? Pdf would be good!
#9 Posted : 04 January 2013 11:29:57(UTC)
Just download Winrar, and use that to extract the archive. It's free for 30 days or so.
#10 Posted : 04 January 2013 12:07:59(UTC)
My work laptop doesn't allow me to install any software myself.
I might try it at home, or just not bother.
Thanks anyway, David!
Offline RUBEN SPAIN
#11 Posted : 04 January 2013 13:43:27(UTC)
RUBEN SPAIN
Here it is the same but compressed in zip format
File Attachment(s):
37770.zip (1,859kb) downloaded 65 time(s).
thanks 1 user liked this useful post by RUBEN SPAIN
#12 Posted : 05 January 2013 02:53:01(UTC)
When reading the CV's I don't see any CV named CV8. Decoder is read as ESU Lokpilot DCC V2.0
It seems impossible to be reseted.
Anybody can help?
#13 Posted : 05 January 2013 09:57:24(UTC)
I don't know if it can be reset with an ESU LokProgrammer.
It can be reset with a CU 6021, an Intellibox, an MS1. Should also work with MS2, CS1, CS2. Just register the train as MM programmable and do the reset.
BTW: which controller(s) do you have? Please indicate if you need further help on resetting that thing.
It doesn't support DCC. It's an MM only OEM LoPi 2.0.
#14 Posted : 05 January 2013 10:00:28(UTC)
It should be able to. The Lokprogrammer software allows you to write CV's directly to a decoder.
#15 Posted : 05 January 2013 10:18:15(UTC)
That works with every DCC decoder. But does it work with an MM only decoder?
Back then Märklin were using ESU decoders with 8-pin plugs. Decoders "can only be replaced at the factory" because they always have a wire soldered to an El Cheapo sound module and a special firmware without DCC. Sigh.
Offline eroncelli
#16 Posted : 05 January 2013 13:10:36(UTC)
eroncelli
Lokprogrammer works with ANY ESU decoder: write 8 in CV8 to reset.
There might be some difference with decoder specially made by ESU for Maerklin (can't say exactly).
Offline RUBEN SPAIN
#17 Posted : 05 January 2013 13:11:28(UTC)
RUBEN SPAIN
The decoder can be reseted writing 8 to CV8. It can be done with Marklin 6021, ESU ECOS, Marklin CS1 or CS2, lokprogrammer etc. I know because when I upgrade my 3770 with a loksound I used the deco to upgrade a DELTA locomotive. It works perfecly.
The decoder only works in MM mode, not DCC. I upgrade its firmware to the last that ESU have for a LP2.0 but it is still without DCC. My lokprogrammer detects it as LP2.0 but with no DCC protocol.
#18 Posted : 05 January 2013 18:25:13(UTC)
I have both Märklin CS2 and ESU color station. I did try to reset the decoder with CS2 but it didn't work. Reading the CVs with ESU color station aborts and reading these with lokprogrammer succeed but reveal no CV8 so I can't reset to firmware value with value 8 set on that CV as it doesn't seem to exist!
So I stay with the problem.
I think I will upgrade my SVT 137 with Loksound V4 with eight plugs interface.
#19 Posted : 05 January 2013 18:31:21(UTC)
I'm sure we can rewrite an existing CV but create it, is it possible?
What is also estonnishing is the fact that lokprogrammer can detect the origin of the decoder as an ESU DCC V2.0 and I think that these data are stored in CV 8, so I'm not understanding what happens because I can't see any CV8 on the datas of the decoder window read by the lokprogrammer.
#20 Posted : 05 January 2013 18:34:14(UTC)
As I said It doesn't work with CS2. That's the reason why I'm searching for the initial values and CVs from a working decoder on a SVT 137
#21 Posted : 05 January 2013 18:57:14(UTC)
In the CS2, create a new loco with #37770 from database, put the train on the programming track and select "Reset" from the loco options screen. You should see the lights of the train flashing for a moment and it should have the default settings after that.
If it still doesn't work with the default address, then maybe it's damaged (can't hurt to try the reset 2 or 3 times).
#22 Posted : 05 January 2013 19:45:15(UTC)
It does'nt work. I think you're right the decoder is probably damaged.
Offline RUBEN SPAIN
#23 Posted : 05 January 2013 23:41:18(UTC)
RUBEN SPAIN
try to upgrade firmware with the lokprogrammer.
Here I attached the program to do the upgrade
File Attachment(s):
FirmwareUpdate_2.2_Setup.zip (1,392kb) downloaded 28 time(s).
This page was generated in 0.797 seconds.
