Offline transform609
#1 Posted : 21 December 2012 14:19:05(UTC)
transform609
Turkey
i can't run my maerklin 37725 loc on mobile station (60652)..i dont know which number of locs from database of 60652 for my 37725 loc,can you help me?
#2 Posted : 21 December 2012 14:34:25(UTC)
Default address is 20. Do you have the 37724 in your database?
Or 37365?
Names won't match, but symbol and functions do.
#3 Posted : 21 December 2012 14:55:02(UTC)
transform609
Turkey
HO Thank you very much,i found it..But a bad thing..Loc runs for a while and stops itself.Then remove from the rails and put again,runs again for a whileand stops again.I use long tracks on my diorama.Is it causes that?Do i need double voltage supply?Or my loc is damaged?
#4 Posted : 21 December 2012 15:25:29(UTC)
Maybe dirty tracks and decoder gets no more power. Maybe dirty collector and decoder switches off (overload protection). Or hardened oil. Or something completely different.
I don't think track voltage is the problem, therefore I think that more feeder tracks won't help (but I could be wrong).
Did you open the loco? Are there DIP switches on the decoder?
#5 Posted : 22 December 2012 06:41:24(UTC)
transform609
Turkey
Thank you HO,i'll check out the points you said.I didn't open lokhaus,i contacted with the seller before i touch down
This page was generated in 0.376 seconds.
