Offline Semaphore
#1 Posted : 19 December 2012 01:46:12(UTC)
Semaphore
Hello all,
With Christmas around the corner and work slowing down a bit, I find myself more in the basement working on the layout.
Before I install the second level over my shadow yard, I want to make sure that everything works. So this brings me to my question:
I am using the ESU version of an s88 feedback module called ECOSDetector Standard connected to my ECOS 50200. I have it programmed so that when a track is occupied by a train (contact track) it will switch the turnout in the other direction so that no other train can enter the yard.
I am wondering if you can program the Detector in such a way that when the train leaves it automatically switches the turnout direction back into that track. Or should I make a second contact section, connected to a different port on the Detector to make this change?
Thanks all and Merry Christmas!
Steven Delhaas
Steven
JE MAINTIENDRAI
Offline Iamnotthecrazyone
#2 Posted : 19 December 2012 01:53:04(UTC)
Iamnotthecrazyone
Originally Posted by: Semaphore Go to Quoted Post
Hello all,
Steven Delhaas
I may be talking nonsense because not all my neurons are with me right nowCrying but don't you have to program the Ecos not the decoder? I would do it by setting a route in which when the same contact track you have now is empty (Constrains tab I think) switches the point to any way you like therefore making that route active.
#3 Posted : 19 December 2012 02:00:16(UTC)
Iamnotthecrazyone
Just to make sure we are talking the same language. Contact or circuit track? They are different, with contact track I think I gave you the right info with circuit you'll need an extra one.
This page was generated in 0.340 seconds.
