Offline Tom Jessop
#1 Posted : 04 December 2012 21:42:08(UTC)
Tom Jessop
Good Morning all,
I require a spare parts diagram for the transfer table 7294, I think this table is about 30 odd years old, there are 4 very small bronze bearings on the drive train in the drive cab & last weekend I noticed that 2 of them were missing. Amazing what you find wrong with 2nd hand items. The M spares list only shows the wiring diagram & no blown up itemised parts list. Can any one help me out regarding the part list or even have a spare bearing lurking around in their spars draw.
Thanks in advance,
Tom in Oz where the temp today will be in the high 30's C.
#2 Posted : 04 December 2012 22:01:38(UTC)
Different to find the service sheet but someone/members can help you.
Offline Yumgui
#3 Posted : 04 December 2012 22:09:34(UTC)
Yumgui
Tada !
All I have, not sure it's what ya need ... not a lot on that parts list.
Just hope it helps ^^
Y Cool
File Attachment(s):
7294_Turntable betrieb.pdf (955kb) downloaded 69 time(s).
thanks 2 users liked this useful post by Yumgui
Offline Tom Jessop
#4 Posted : 04 December 2012 22:53:51(UTC)
Tom Jessop
Im after the exploded view of the gear train[ worm & normal gear ] from the motor to the final drive shaft, this is all housed in the control cab on the movable table.
Tom in Oz
Offline Markus Schild
#5 Posted : 05 December 2012 01:41:54(UTC)
Markus Schild
Hi Tom,
You are looking for :
E260080 - SINTERBRONZELAGER 4 Stück
6,00 € Unverbindliche Preisempfehlung(VPE: 4)
English: Bearing of sintered bronze, pack of four, 6.00 EUR retail price.
In stock at MÄRKLIN.
Regards from Germany were we will have -10°C next week.
Markus
Offline Ross
#6 Posted : 05 December 2012 07:25:16(UTC)
Ross
Hello Markus,
Can you also supply the number for the combined worm and pinion gear on the same axle please?
Hi Tom,
Markus
Ross
Offline Yumgui
#7 Posted : 05 December 2012 08:03:58(UTC)
Yumgui
Tom in Oz
Hmm, this spares list/explo view exists ?
Yum
#8 Posted : 05 December 2012 10:21:39(UTC)
Markus Schild
Hi Ross,
I know two numbers for gears of the 7294:
416750 - ZAHNRAD 4,99 €
416740 - ZAHNRAD 4,99 €
Unfortunately I don't know exactly which gears these are.
No, there is no further or more detailed list published.
Markus
Offline Ross
#9 Posted : 05 December 2012 21:22:07(UTC)
Ross
Hello Markus,
Thanks for the numbers re the gears. I use my transfer table alot and I'm on to my second unit as the gears, motor and contacts wore out on my first transfer table.
Ross
Offline Tom Jessop
#10 Posted : 06 December 2012 01:15:59(UTC)
Tom Jessop
Thanks very much Markus , i didnt realise that the 2 gearshafts that transfer movement to the final shaft had different gear ratio's or am i being just a mere male & wrong again. If they are different, which worm shaft goes where in relation to the motor cog ? It would be nice to have access to all these enlarged diagrams of spare parts to make it easy to order older replacement parts for those who have the courage & knowledge to do their own repairs.
Tom in Oz.
Offline Ross
#11 Posted : 06 December 2012 03:34:24(UTC)
Ross
Hi Tom,
The housing uses two combined worm and pinion gears and they are the same.
I noticed you online now, are you at work (big trains) or home with the (little trains)?
Ross
Offline Tom Jessop
#12 Posted : 06 December 2012 06:18:06(UTC)
Tom Jessop
Hi Ross,
At home at the present time , just up from a Nana nap before hitting the slave train at Midnight tonight. The last few weeks I have had the urge to do some construction on the layout, [\maybe after I had the big splurge while in Europe I developed a guilty conscience. I wonder why there is 2 different part no's in the reply from Marcus to you, different versions of the 7294 maybe?
Tom in Oz
#13 Posted : 06 December 2012 14:11:47(UTC)
Markus Schild
Hi Tom,
The 7294 has also gears outside the motor-house. I will try to find out which parts belongs to the motor.
Markus
#14 Posted : 10 December 2012 16:36:33(UTC)
Markus Schild
Now I got definitely the right number for the two shafts with the worm/gear combination:
416790 ANTRIEBSWELLE (drive-shaft) 7,99 EUR, in stock at Märklin.
Markus
Offline Ross
#15 Posted : 11 December 2012 21:12:43(UTC)
Ross
Hello Markus,
Thank you for finding the correct numbers. I'll add these to my spares order.
Markus
Ross
#16 Posted : 12 December 2012 03:55:32(UTC)
Tom in Oz
Hi Tom,
For what it's worth, I'd also check out Sb Modellbau, they produce a number of conversion kits to improve a wide range of products and I see they appear to have a motor kit for the 7294 but whether it includes all you need I'm not sure, could pay to drop them a line - here's the 7294 motor kit link....
http://www.sb-modellbau.com/product_info.php?products_id=449&cPath=
Steve
Offline Python61
#17 Posted : 24 October 2013 11:05:46(UTC)
Python61
I would not normally resurrect an old thread, but this one has two of the three part numbers I need to repair my Transfer Table 7294.
Could someone please provide the part number for the drive shaft that passes through the motor-house and drives the carriage across the Transfer Table.
Python61
#18 Posted : 25 October 2013 02:14:39(UTC)
Markus Schild
Hi Python61,
This should be
416770 - ANTRIEBSWELLE
19,95 € Unverbindliche Preisempfehlung Ab Werk lieferbar.
(Drive-Shaft , 19.95 EUR Retail price - In Stock)
Markus
Offline Python61
#19 Posted : 25 October 2013 07:04:58(UTC)
Python61
Hi Markus,
Thanks for your prompt reply, only drawback is the 49.95 Euro shipping charge to Australia from the Marklin Online Shop. If you have any suggestions for alternate places to purchase these spare parts, I would greatly appreciate it.
Python61
Offline Tom Jessop
#20 Posted : 25 October 2013 07:27:38(UTC)
Tom Jessop
Try "Toot Toot'" in NZ . They helped me out with the bearings I was after, very quick service . Or try Noel in Brissy but not sure what his spare parts stock is like.
Tom in Oz
gee the %0 Euro is a bit steep ,parcel post small box is $13 euro for memory & Im sure the part you are after would leave plenty of space in the box for a few wagons.
#21 Posted : 25 October 2013 07:32:53(UTC)
You can order through the Brisbane dealer. The website is http://www.trainsntoys.com.au or there is toot-toot in New Zealand see http://www.toottoot.co.nz . They will take a long time to get the part if they don't already have it in stock, but the freight, if any, will be way less than 50 euro.. Huh
Update - what Tom said - curses on those touch typists!
Offline Tom Jessop
#22 Posted : 25 October 2013 07:46:28(UTC)
Tom Jessop
The question now is are you going to run ELoc's on the table using catenary ? If so you will also need the support pillars, the special catenary piece & the end pieces for the tracks that join the table , I have all but the small end pieces & have never seen the end pieces appear for sale on ebay by themselves . Does any one know what the part number is for these ?
Much appreciated in advance,
Tom in Oz.
#23 Posted : 25 October 2013 09:40:19(UTC)
Markus Schild
Hi Tom,
The parts for the catenary are:
416940 OBERL.-BRUECKE (half of support pillar which holds the catenary (four needed for one bridge)) : No longer available
416950 FAHRDRAHTSTUECK (small catenary piece): No longer available
416960 FAHRDRAHTSTUECK (long piece for the bridge): 9.99 EUR, in stock
Markus
Offline Python61
#24 Posted : 25 October 2013 23:13:11(UTC)
Python61
I was hoping to get my Transfer Table operational before Christmas. So I had already contacted Noel of Trains N Toys, but he could not assure me of delivery before Christmas of items not in stock.
Toottoot's website indicates that they have the bearings in stock. So once that is confirmed, I will order them and maybe that will get the Transfer Table operational, as currently there is only one bearing installed.
Again thanks for your prompt and very helpful replies.
Kind Regards
Python61
#25 Posted : 26 October 2013 23:55:35(UTC)
Originally Posted by: Python61 Go to Quoted Post
Hi Markus,
Python61
Python & Tom,
If you have your transfer tables accessible, can you post some detail photos of the mechanism showing the missing or worn parts?, with the numbers that Markus has provided it could be helpful to match the numbers with the parts showing for others to refer to, and I'd like to add it to my parts sheet for the item.
Steve
This page was generated in 0.587 seconds.
