Offline mancsaint
#1 Posted : 22 November 2012 16:25:18(UTC)
mancsaint
I have been able to get hold of one of these locos cheaply, but without a manual. The lok is setup for catanery power but I cannot see how to swap it to power through the track.
Can anyone help me in this regard, and even better send me a scan of the manual?
Many thanks
Sean
#2 Posted : 22 November 2012 16:43:18(UTC)
Sean, you have to take the housing off, if you know how. and you will find a very small plug with 2 pins, this has to be moved to another spot.
Offline kbvrod
#3 Posted : 22 November 2012 17:41:53(UTC)
kbvrod
Tip go to: http://www.roco.cc/service/ersatzteilblaetter.html
Punch in the lok number and you can get a spart parts download(pdf)
Happy Thnaksgiving! and 2nd's to our Canadian friends!LOL
Dr D
Offline mancsaint
#4 Posted : 24 November 2012 02:15:07(UTC)
mancsaint
[img]null[/img]Thank you kbvrod and river6109 both of you helped me solve most of the problem. I have downloaded the parts list and spotted the bit that needs moving, the copper contact "fork" is presently facing the end of the lok, does it need to be moved 90 degrees to point to the side, if so both prongs will touch the same contact strip.
When I put the lok on my programming track and switched power on it ran at full speed off the end of the track, luckily onto thick carpet so was undamaged. I'm hoping that the decoder will kick in and stop it running away when power is via the tracks.
SeanCatanary/Track switch
mancsaint attached the following image(s):
Offline mancsaint
#5 Posted : 24 November 2012 10:14:43(UTC)
mancsaint
I have moved the switch 45 degrees, as far as it will go, and get the same result when I put power to the track, the lok tries to go off the end at full speed, except this time I stop it.
Sean
This page was generated in 0.281 seconds.
