Offline Semaphore
#1 Posted : 19 November 2012 20:05:32(UTC)
Semaphore
Hello all,
If you are using a k84 decoder or signals from the 76xxx series, the train is halted in the stop section by cutting the power to the center rail. This causes the locomotive lights to go out.
Is there a way to stop the train while maintaining the headlights?
Thanks!
Steven Delhaas
Steven
JE MAINTIENDRAI
#2 Posted : 19 November 2012 21:06:25(UTC)
With the K84's the answer is no. With the signals, I think you can add a resistor into the circuit which allows limited power to the stop section to keep the lights on. But, not having used the Marklin signals, I'm not 100% sure on that. You certainly can do it with other types of stop modules.
#3 Posted : 19 November 2012 21:12:19(UTC)
Hi, Steven!
Use the braking modules #72441 or #72442 or similar modules (e.g. from Bogobit).
The resistor trick will work with some new models with white LEDs, but light bulbs will not shine and motor sound will be off.
Resistors were used with 6090 and older decoders to keep the memory alive. They were not used to keep lights on.
#4 Posted : 19 November 2012 21:33:45(UTC)
Just checking some reference material, which suggests you might be able to put a 1.5k resistor across the K84 contacts, which should allow enough current to power lights, but not drive the loco - but I don't know how digital locos will react to this.
In regards to the 76xxx series signals, the only reference to resistors I can find is
"If you have had problems with locomotives
not leaving a signal block or leaving it in the
wrong direction, you can solve this problem in
the Digital system by installing a 1.5 kilo ohm
resistor. This resistor comes with the k83
decoder. lt is also available from Marklin under
spare parts number 517050."
Offline kbvrod
#5 Posted : 19 November 2012 22:13:03(UTC)
kbvrod
Steven,ypu might be out of luck on this.I think the thing BDaddy is talking about is using the the resistor on the K-84 is for older decoders (loks) to keep their memory(?)
Tom might be right,it has not been tested here.
I have used headlights on,to know the lok is called up on the CU,although there are some rules if lights are on during daytime and what the operations are,...
Dr D
thanks 1 user liked this useful post by kbvrod
This page was generated in 0.379 seconds.
