Offline estate
#1 Posted : 17 February 2012 20:39:11(UTC)
estate
First a little back story about myself. My name is Rob, I inherited my father's train collection a few years ago. After the shock of his passing and life getting back to normal, I've decided to sell it. There's a lot of N scale stuff and a small handful of Z scale stuff. My father had too many hobbies (I'm guilty of the same problem), so a bunch of the newer stuff was never used. Some of the stuff he bought in the 80s was used, and I remember as a young child being told to keep my hands off it! BigGrin
Anyhow, the first thing I've done is test out the locomotives. Four of them don't run, they just light up. I found this site that talked about reviving locomotives. Based on the table, and the age of some of these locomotives, I would guess the oil has completely congealed. http://www.zscale.org/articles/revival.html
I started with one of the ones I thought would be the easiest to take apart, 8863 Burlington Northern F7. Sure enough, the oil was very gummy and sticky. I would not be surprised if he hadn't used this locomotive for 20-25 years. I tried to rub off as much as I could with tweezers and lubed up the axles and gears per the instructions on that site. It seems to run well now, although the trucks had more resistance than I had expected. It makes some noise when running too. Since I'm not familiar with model railroading I'm not sure what to expect as far as noise. For reference I have a working steam locomotive from kit 81466 that seems quieter. I also have a triple locomotive 88321 that seems to be as noisy as the 8863 I revived.
So, my first question is: how much noise is normal? Aside from the congealed oil the locomotive looks really clean internally. It's hard for me to tell just how far to take the cleaning and reviving process.
Second question is: should I get some sort of degreaser for the congealed oil? I'm using Labelle #108 to lube these locomotives.
Final question is: he has a turntable kit that was never taken out of the box. I'm guessing he purchased it around 2004. Is there any maintenance I should do to it or can I sell it as new with a good conscience?
Thanks for reading!
Offline kbvrod
#2 Posted : 17 February 2012 21:13:36(UTC)
kbvrod
Welcome to the forum!ThumpUp
Depends,some older 3-pole loks will make noise.The newer 5-poles are fairly quiet.
Yes,a safe and easy way is to use lighter fluid,the kind used in refillable lighters.
Good choice on the Labelle 108.DO NOT use Märklin oil!
Dr Dirt
Offline ozzman
#3 Posted : 17 February 2012 23:58:30(UTC)
ozzman
Hi and welcome to this forum. Yes, the lighter fluid will do the trick, and so will dry cleaning fluid. You will have to re-oil the locos once you've used either of those fluids, or any other.
Dr Dirt's comments on noise are right on, but bear this in mind - the real ones make noise when they're running too ;-)
Gary
Z Scale
Offline Aquahog
#4 Posted : 20 February 2012 15:29:50(UTC)
Aquahog
I had the same issue with my loco after having it confined to the box for 5+ years. Degreased/cleaned it up with isopropanol (available in the drug store and normally used for cleaning electronics I gather) and relubricated it again. Mind you the isopropanol may dissolve paint so don't get it anywhere near the exterior of the loco or other painted surfaces you're careful about.
Mine has a five pole motor so it's quite quiet. It shouldn't be too difficult to distinguish between normal noise from running and the screeching of a loco with a lack of lubrication I think. If it's any consolation; the small amount of oil that is needed should mean that it's almost impossible to add too little oil if you give it a drop.
H0: DB Era III, carpetbahn
Z: SBB Era V, planning layout
Offline Z-nerd
#5 Posted : 11 October 2012 16:04:29(UTC)
Z-nerd
Electronics cleaner spray to clean the loco, but what type of oil for lubrication ? Can I use ATF-oil or oil for sewing machines ??
Any equivalent oils with the Labelle 108 ? available in sweden ?
Offline kbvrod
#6 Posted : 11 October 2012 18:58:19(UTC)
kbvrod
Hi Z-nerd,all,
>Electronics cleaner spray to clean the loco, <
Yes,get one that is safe for plastics.
Any equivalent oils with the Labelle 108 ? available in sweden ?<
Careful,with non-hobby lubricants. Check hobby shops,even non-trains ones,grease and oils are used for R/C and other hobbies.
Now Labelle and Woodland Scenics are sold all over the world.That doesn't mean that European firms do not make acceptable lubricants!BigGrin
Dr D
Offline Z-nerd
#7 Posted : 11 October 2012 21:11:01(UTC)
Z-nerd
Dr Dirt
why not Märklin oil ?? What about baby oil ? lubricants for roller skates ?
Offline kbvrod
#8 Posted : 11 October 2012 21:23:20(UTC)
kbvrod
Hi Z-nerd,all,
>why not Märklin oil ?? What about baby oil ? lubricants for roller skates ?<
I understand that sometimes language can be a challenge,....
Märklin oil is terrible.It dries too fast and it's viscosity is awful.Baby oil?Blink
USE A LUBRICANT FOR MODELS
Dr Dirt
Offline Z-nerd
#9 Posted : 11 October 2012 22:30:21(UTC)
Z-nerd
here: http://www.railroad24.de...senbahn/forum.php?id=132
some person wrote that synthetic engine oil 10W40 will do the job, he also claims that Märklin's own oil is a poor choice.
The problem is to find the right answer while the Märklin company is more interested in marketing their own products than giving information on alternative lubricants.
Offline kbvrod
#10 Posted : 11 October 2012 22:43:18(UTC)
kbvrod
Never F@#$%^ mind!Blink
Offline Vmcompetello
#11 Posted : 12 October 2012 00:41:12(UTC)
Vmcompetello
I'm sorry for your loss and I do not want to circle like a vulture but I am looking for a turntable and if you want to sell it let me know the price and maybe we can make a deal.
Vinnie
Offline ozzman
#12 Posted : 12 October 2012 02:05:03(UTC)
ozzman
I use Fleischmann oil. It seems to be OK.
Gary
Z Scale
Offline Z-nerd
#13 Posted : 12 October 2012 09:59:36(UTC)
Z-nerd
OK, I know a retailer selling the Fleishmann oil. Is it the 6599 Fleischmann Spezial-Öl 20ml bottle ?
Offline ozzman
#14 Posted : 12 October 2012 10:57:30(UTC)
ozzman
Yes, that's the one I've got.
Gary
Z Scale
Offline Z-nerd
#15 Posted : 22 October 2012 19:46:58(UTC)
Z-nerd
I have to revive this 8800 all the time. Dismantle it, put the wheels into white spirit. Then putting the wheels back and add a dash of oil containing
graphite. Without oil it squeks. It's easy to forget to bend the "contactplates" back into place (or whatever you call them )
Offline detyo111
#16 Posted : 04 December 2012 17:53:02(UTC)
detyo111
Every Marklin Z scale train engine should run easily, silently, and effectively. If it doesn't, the issue can almost always be set. In most conditions, one can get back a poorly-running or non-functioning Marklin Z train engine in under three moments....
thanks 1 user liked this useful post by detyo111
Offline Z-nerd
#17 Posted : 07 December 2012 17:48:36(UTC)
Z-nerd
Not the 3-pole 8800. It runs poorly even if it's cleaned, espcially if running it slowly.
Offline Z-nerd
#18 Posted : 27 August 2013 20:14:54(UTC)
Z-nerd
8800 by Joner1769, on Flickr
Ran in to problems again. Bought a brand new 5 pole 8800 about a year ago. It worked perfectly when I used it. Then I took a 6 month break from Z.
Then when I started up again the loco was jumpy and stopped after a few minutes. So I dismantled it and cleaned it and oiled it, but it still begins to work poor after a while.
Offline Paul59
#19 Posted : 28 August 2013 22:29:26(UTC)
Paul59
Interesting topic this since I got my old Z gauge stuff out of the loft last year to see whether it had survived or not.
I used to run a couple of exhibition Z gauge layouts and the last time the locos were run was around 1991 so they hadn't been run for 21 years and spent all that time in a box in the loft.
There are around sixteen locos or so ranging from the smallest 6 wheel tank engine and diesel shunter up to BR01 and Crocodile with a selection in between - steam, electric and diesel. They all have the three pole motor as the 5 pole hadn't come out back then I don't think.
When I got them out of the loft I set up a medium size oval of track with a couple of turnouts as a test track. Each loco I gave a VERY SLIGHT oiling and put them on the track. All but 1 run ran ok. After a couple of laps they were running as smoothly as they ever had done. The current consumption was the same as it used to be and they seemed no different to when they last ran all those years ago.
The one that didn't run was gummed up (a P8). I removed the plate under the chassis and gently moved the gears to and fro and applied a tiny bit of fresh oil. It then ran fine and smoothly pulling six coaches just like it always had done.
So, that was 100% success rate without having to do much after 21 years storage in the fluctuating temperatures of a loft.
Marklin certainly built them good eh? BigGrin BigGrin
Not sure what to do with them now - I suppose I should build a small layout really.
So you may not have to do as much fiddling as you think - I had thought that mine would be completely dead but they seemed no different to when I put them up there.
Paul
Offline Z-nerd
#20 Posted : 29 August 2013 08:41:04(UTC)
Z-nerd
Paul
I wonder if those were rather new unused locos. After a few hours of use the wheels wears out and a narrow copper coulored ring is visible on the wheels. Dirt easilly sticks to the wheels and the loco runs jumpy and erratically.
Also it's strange that you didnt have to clean the locos due to hardened oil. I bought a brand new 5 pole 8800 last autumn. I didnt run it for 6 months, when starting it up again I had to pick it apart and clean it first.
Online H0
#21 Posted : 29 August 2013 09:49:46(UTC)
Originally Posted by: Z-nerd Go to Quoted Post
Also it's strange that you didn't have to clean the locos due to hardened oil.
Märklin used oil that hardens for a while - I guess in the '90s.
My H0 stuff hibernated nearly 30 years and there were no problems with hardened oil. OTOH I had sets new from a dealer where the oil had glued the motor (one of them was a 1996 one-time series).
The oil is the problem, not the time that has elapsed.
Offline Paul59
#22 Posted : 29 August 2013 10:07:22(UTC)
Paul59
I wonder if those were rather new unused locos. After a few hours of use the wheels wears out and a narrow copper coulored rin g is visible on the wheels. Dirt easilly sticks to the wheels and the loco runs jumpy and erratically.
No, they were very much used locos. My layouts attended many exhibitions (some two day affairs) where the locos would run for many hours constantly.
Also when building the layouts I would often run trains around whilst I was working.
I did use Relco high frequency track cleaners which worked well and also kept the wheels clean. I don't remember having to clean the wheels manually although I suppose I must have done occasionally.
I do remember that I rarely oiled them and when I did it was very sparingly using the pointed end of a needle to apply tiny drops to the axles, gears etc.
I had a 8885 BR003 which I got used from a local model shop. It had spent months running all day every day on a display in their shop window so must have covered many many miles. The wheels on one side were quite worn through always running in one direction around the track. Nonetheless it did great service on my layouts and still ran well last year when I got them out again.
Maybe getting some serious miles on the clock is the answer. I know the locos did seem to run better once they were loosened up.
Paul
This page was generated in 0.531 seconds.
