Offline ozzman
#1 Posted : 14 October 2012 09:47:29(UTC)
ozzman
Nor sure if this is the right place for this question, but anyway...
What would be a good non-solvent based adhesive to use with balsa? I mentioned non-solvent based because I want to stick pieces of balsa wood to foam core board.
Gary
Z Scale
Offline kariosls37
#2 Posted : 14 October 2012 10:56:36(UTC)
kariosls37
I've used PVA wood glue on a fair bit of balsa and it has never given me any trouble.
Rick
Offline Western Pacific
#3 Posted : 14 October 2012 11:08:06(UTC)
Western Pacific
Not being sure what material your foam core board is made of, it is a bit difficult to give a precise suggestion. However, if your foam core board has a core made of for instance Styrofoam covered by paper or carton, then I'd suggest using a white carpenters wood adhesive.
I have sucessfully used Cascol, a product from the Dutch Akzo Nobel Group: Cascol
Having looked quickly at a brochure on wood adhesive products from the Akzo Nobel Group, it seems that Australia is a white spot on their map (or at least there is no blue spot there): Akzo Nobel map
You may figure out a similar white adhesive from looking at this safety fact sheet: Cascol safety data sheet
Offline kbvrod
#4 Posted : 14 October 2012 13:48:03(UTC)
kbvrod
White glue or carpenters glue.
Dr D
Offline ozzman
#5 Posted : 15 October 2012 11:52:05(UTC)
ozzman
Thanks for the advice and suggestions. I had tried white PVA glue and it didn't work, which prompted the question. The problem was that the glue wouldn't bind to the coated foam core board which I'm using. Note to self: don't use coated board again!
Later I remembered I had some Woodland Scenics foam tack glue and I tried that. It worked a treat.
Gary
Z Scale
Offline agvera
#6 Posted : 20 October 2012 19:33:48(UTC)
agvera
Argentina
People involved in aeromodelling use a solution of celluloid in acetone. Here is still sold at aeromodelling hobby shops.
It fills the pores and creates a strong bond between pieces of balsa. I don´t know how it will work on your foam but may be worth testing it because the acetone will attack the plastic layer and join the celluloid.
Good luck!
If you try it keep posted.
BR
Alberto
Alberto
era II + III + IV
Offline ozzman
#7 Posted : 21 October 2012 11:36:49(UTC)
ozzman
Thanks Alberto. The Woodland Scenics foam glue works very well. It looks quite like white carpenters glue, but the formula must be a little different. It's also water soluble, which is good for one's fingers.
Gary
Z Scale
This page was generated in 0.635 seconds.
