Offline bygger01
#1 Posted : 11 October 2012 22:49:12(UTC)
bygger01
Good evening
In our little railway club in Herborg / DK, we are running AC based on Märklin
Our control is a CS2 - 60214 - with 2 boosters
So for the members controlling the different sections, we want to use Mobilstations and we have 4 of the old type 60652, and here come the problem, when we are connecting them to the CS2
Two works very good, but the other two are reporting No Master - Do you have a way to come around this problem ?
Can we update them ?
Can a CS1 help ?
Hoping for a helpfull respons
Steffensen from Herning in Denmark
http://www.vsvmj.dk/
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
#2 Posted : 11 October 2012 23:22:19(UTC)
Originally Posted by: bygger01 Go to Quoted Post
Can a CS1 help?
If the software of the MS1 is too old (you can check that under OPTIONS => INFO, look for AP) then it will help to connect the MS1 to a CS1 or ECoS.
But MS1s with old software normally keep flashing all elements of the display endlessly when connected to a CS2, so maybe it's a different problem here.
Offline bygger01
#3 Posted : 12 October 2012 17:40:07(UTC)
bygger01
When I open my mailbox, there was this answer from Märklin ( I also asked them yesterday evening )
Dear Mr. Steffensen,
thanks for your question.
There can be two possible causes.
The software version in the MS 1 is old. You can make an update at a CS 1 60212 with version 2.04.
When you have no choice to update the MS 1 you can send it to our repairservice.
If that not works is the cable at the MS 1 the ground. You can order it under the spare part no. E105680.
We hope that this information will help you.
Sincerely yours,
your account manager
Selma Reisert
So that is service .....
I will try this and then keep you updated
Offline bygger01
#4 Posted : 22 October 2012 22:36:30(UTC)
bygger01
Just to inform you, that that was the trick .....
This page was generated in 0.379 seconds.
