Offline Corinkayaker
#1 Posted : 16 September 2012 12:48:58(UTC)
Corinkayaker
I have been reading this manual, and I am feeling a bit stupid... http://www.marklin.com/tech/SignalManual.pdf
I don't know how signals work in real life and likewise, how they work in miniature and I am not much wiser from reading this document.
I love the effect that signals and automatic control brings to a railway and would like to buy a few to play with.
My question is, what models, including control track should I be buying as a beginners set to get started and see how they work? Is there a simple explanation anywhere that a simple fellow like me will understand?
#2 Posted : 16 September 2012 13:15:31(UTC)
Hi Corin,
That manual has all the information you need to get signals working on your layout, but we can list a few basic points:
- Signals tell a train to stop, or allow it to continue. In model form signals can be connected so that trains obey them.
- The signal will tell a train to stop when it is red. Green allows it to continue at full speed, yellow means proceed slowly.
- There are also distant, or warning signals, which tell you the state of the next signal along the track. If the next signal is red, this one will show yellow, telling the train to slow down, otherwise it will show green.
- In model form the only control is to stop the train or not, so only red signal will affect the train.
- On open track, signals are used to stop trains crashing into the back of the one in front, so the track is divided into sections, or "blocks".
- When a train enters a block, the signal at the entrance to that block will change to red, so that the train coming up behind will not catch up to it. In model form we can position a contact track to activate the change of the signal.
- When the train leaves the block, the signal at the entrance to that block will change back to green.
- At stations, there are signals protecting the entrance of the station, and also regulating the exit of the station.
- Station entrance signals depend on whether the trains can only stop at one platform, or have a choice of pulling into a side platform or siding.
- If the train is going to the main platform the signal will show green. If it's going to a side platform it will show green/yellow. If no platform is free it will show red.
- At station exits, the main platform will release a train with a green signal. Side platforms and sidings will release trains onto the main line with a green/yellow. Otherwise they will show red.
- Station signals can be tied in with operation of the turnouts, so that the path selected through the station will show the green or green/yellow, and all others red.
I hope the above is of some use. I have tried to keep it simple, so I might have made a couple of over-simplifications. Let us know if something isn't quite clear enough.
#3 Posted : 16 September 2012 13:21:30(UTC)
To answer this question we need to know what type of track you use, what era you prefer, and what kind of control equipment. I would suggest very different solutions for a classic M track analogue layout and a modern digitally controlled one.
Also, do you want to to stick with Marklin or don't mind other makers?
#4 Posted : 16 September 2012 13:49:00(UTC)
Corinkayaker
First up, thanks for the very clear post on Signal operation.... its not that difficult when you put it that way... Thanks
Everything I have is analogue M track and I would like to stick with that, steamers only, so no catenary.
Your assistance is greatly appreciated mate.
I guess I would prefer Marklin , but if there is something better I am not really too fussed.
Offline kbvrod
#5 Posted : 16 September 2012 14:38:42(UTC)
kbvrod
German railway signals explained:
http://www.sh1.org/eisenbahn/index.htm
Dr D
thanks 1 user liked this useful post by kbvrod
#6 Posted : 16 September 2012 15:22:37(UTC)
The old marklin semaphores 7039,7040,7041 working perfect in any condition,the new digital are not working with cs2 72441 and s88.Be aware from them.
Offline guiverc
#7 Posted : 16 September 2012 18:00:40(UTC)
guiverc
Howdy
Signals in real life can be complex; most of Australia uses "Speed Signaling" where its not just one color - but a combination of colors which tell the driver the speed allowed. The standard "clear road ahead" in Victoria is green over red (left most line). Red over red is STOP (immediately; centre line). Victoria has numerous systems and allows for branch line operation just as RayF described too (areas where speed signaling isn't used). Seeing this in real life could possibly make it seem complex.
I too am new to marklin signaling as am rebuilding my layout after decades of being ignored. Historically I'd use cheap signals that didn't stop the train - just changed from RED for stop|halt and GREEN for go. I'd use a DPDT (dual pole, dual throw) switch which had one pole control the RED/GREEN globe of signal, the other the power to a tiny section (few tracks near signal) of track. This allowed the train to auto-stop on RED, but it'd stop a train going opposite direction to signal wrongly.
Marklin signaling has the same flaw (stops trains in either direction when red), but has benefit of being able to be controlled by "remote control track" (5146/5147/5213) which allows automatic block operation. A train going over these tracks can be made to change a signal green or red depending upon how you wire it. The cheap "lights only" signal with "dpdt" switch (which did the work) are unable to do this. The documents are describing how this is done, which isn't difficult (esp. when you can experiment).
5146 = M track equiv. to 5107 (1/2 straight) remote control track
5147 = M track equiv. to 5101 (1/2 curve std) remote control track
5213 = M track equiv. to 5201 (1/2 wide curve) remote control track
7039 is home signal (semaphore or arm type; contains globe that shows red/green too); 7088 is lighted version (red/green lights only)
7036 is distant signal - if used it gives driver warning of the 7039/7088 he/she is approaching; usually wired to change automatically with 7039/7088.
7040 is two arm signal, refer RayF's description - or think of one arm as referring to one direction, other arm the alternate direction. Both at stop - train stops.
7038 is distant signal used with 7040 (or 7041; sorry can't help with difference between 7040/7041)
7042 is yard signal. (all signals I've mentioned are lit - so if room dark you can still see signal)
Marklin also have 7236/7239/7237/7240/7241/7238/7242 but have only seen these in catalogs.
Any questions I'll happily help you with (where I can) - but same applies to many on this great forum.
Chris g.
thanks 1 user liked this useful post by guiverc
Offline drstapes
#8 Posted : 17 September 2012 23:48:35(UTC)
drstapes
All the old M track signals detailed in the other replies are readily available on ebay for usually very reasonable prices.If you buy there try and get one in good order and with the metal base plate that fits under the M track. Quite a few are advertsed without this. Boxed examples are nicer but tend to be more expensive. You will also need the control swith panel 7072 to work them which are similarily available cheaply on ebay. The contact tracks for remote control are also seen from time to time.Why not get hold of an old marklin catalogue (prior to the mid 1980's) which will detail all the M track and signals.
Geoff (UK)
thanks 2 users liked this useful post by drstapes
#9 Posted : 17 September 2012 23:57:24(UTC)
Corinkayaker
Thanks heaps guys. I think I have it covered now. I just bought some bits and I will have a play when they arrive.
I can't thank you all enough for explaining all this to me. Now I have decided what to buy I can have a play and fill in the blanks as I go along.
I bought 2 x 7039 1 x 7040 4 x 5147 and 2 x 5213. Should be enough to get me started anyhow.
#10 Posted : 18 September 2012 03:37:45(UTC)
Moved topic into General MRR \ H0 Scale. It hardly belongs in 'Collectors Corner'!
#11 Posted : 06 October 2012 06:56:26(UTC)
Corinkayaker
Sorry I thought collectors corner was for old out of production models which is what we are talking about,
anyhow the signals arrived and I am well pleased with how they work! Thanks for the advice everyone!
#12 Posted : 06 October 2012 09:00:06(UTC)
if you collect signals than they go in the collectors corner, if you play with signals make sure they work probably.LOL
#13 Posted : 06 October 2012 09:29:41(UTC)
Didn´t Marklin stop producing old semaphore signals?
I suggest you shall try Viessmann slow action semaphore.
Very closed to prototyp in shape and functions.
#14 Posted : 06 October 2012 11:04:13(UTC)
The 7039/7040/7041 type semaphore signals last appeared in the 2010/2011 Yearbook. That's hardly old!
M track was discontinued in 2000.
#15 Posted : 06 October 2012 12:35:46(UTC)
Corinkayaker
Well there ya go! You can tell I am no Marklin expert then? Anyhow I received 3 7039 and 1 7040 and a bunch of switch track thingy s, been playing with different layouts all day. They add a whole new dimension to my train set.
This page was generated in 0.922 seconds.
