Offline MarioFabro
#1 Posted : 25 August 2007 20:18:00(UTC)
MarioFabro
I have most components of the BLS Autoverlad train:
- a Ae or Re 4/4 (HAG)
- the auto carrying vagons (from HAG and LILIPUT).
I found this nice Steuervagen by swiss small lot producer EMB (www.emb-gmbh.ch)
Unfortunately, quite pricey at over 400 Euros.
I wonder how difficult it may be to build it from scratch, maybe starting from some old EWII liliput cars that I have. I would have to do some major work with the doors and windows and I am afraid of not being able to "pull it off". Of ocurse, I will use the underbody from a old model (beside the liliputs I also have some limas that I will not use).
Does anyone have experience with building a coach from scratch?
What would be the material of choice, plastic or brass?
Is it better to start from scratch or use a old coach as a basis, even if major modifications are needed?
I will probably have to find some plastic cement that can be sanded.. my hobby shop should help with that.
Related to this were my questions about decals, since mos of the decals on this car are white.
Here is a pic of the real thing:
Offline laalves
#2 Posted : 25 August 2007 22:00:42(UTC)
laalves
Brass is the noblest, but the most difficult to work, unless you have access to the proper tools.
This is a very straight-line, flat surface construction, so it should be relatively easy to build it to a very high standard, except for the window cutting bit. Ideally, you would have a friend with a CNC laser cutter, and you would CAD draw both lateral panels, front and back panels, and have those laser cut. Then it will be very easy to put it together.
If you don't have access to such high tech stuff, you will have to veeeeery patiently manually slot the windows. Do it with a pinvice with a drill to mark the corners of each window, and cut them out using a very new No.11 x-acto blade guided by a steel ruler.
Then use a rat-tail file to finish it off.
As to chassis, I would simply use a plank of Evergreen 2mm stock, internally reinforced with Plastruct tubing. Then I would steal the bogies and interior details from any old suitable old coach.
^Most other details (buffers, cow catchers, brake hoses, wipers, whistle, panto, blah, blah) can either be had from a MRR store, stolen from old rolling stock or from the parts bin, if you have one.
Have fun and keep us posted on your interesting project!
Luis
This page was generated in 0.197 seconds.
