Offline sevs
#1 Posted : 01 August 2012 15:55:17(UTC)
sevs
Say, if I have analog power from the catenary, and digital power from the center studs, and connect both the analog adapter and the digital adapter's ground together, will I screw up something then?
Edited by user 28 July 2014 05:56:42(UTC)  | Reason: Not specified
Regards, Jon Håvard :)
#2 Posted : 01 August 2012 16:08:30(UTC)
This will work fine ...
... until you accidentally connect centre rail and catenary while both have power (this will most likely kill your digital controller or the booster)
Offline sevs
#3 Posted : 01 August 2012 17:14:16(UTC)
sevs
Thanks, Tom
If I have connected centre rail and catenary while only one of them have power, what happens? Laugh
#4 Posted : 01 August 2012 17:26:44(UTC)
I presume that for a moment, nothing will happen. Then, after a second or so, nothing will continue to happen. Wink
Read more at http://www.brainyquote.c...html#PBlYo8iXFm3Ufmpm.99
But I haven't tried that - and I won't put my controllers at any risk to find out ...
Better turn both off both analogue and digital power before fiddling with rolling stock (especially tin plate stuff) or tools on the layout.
Offline Ian555
#5 Posted : 01 August 2012 18:52:17(UTC)
Ian555
Hi Jon,
I've ran both analog and digital Loco's on my layout for the past 3 years, BUT, they run on totally seperate tracks, both mechanically and electrically.
It's the only safe way to do it.
This way of course you can run both analog and digital Loco's together and directly compare the performance of both against each other.
Ian.
#6 Posted : 01 August 2012 19:08:13(UTC)
I have done 2 layouts now with the following solution, for those who have a few analogue items they want to run from time to time, but are mainly digital operators:
1: On a normal digital layout, I take one loop/line of track and wire it independently from the rest of the layout. The only permanent contact is K83 decoders working the switch motors, and 2-3 switches that join the loop to the main layout- on which with C track I isolate BOTH the hot and ground contacts as a security measure.
2: This leaves a possible ground joint from outer rail to outer rail at the switch, but that is it. (and I'm pretty sure it doesn't really matter anyways)
3: I then have 3 way toggle switches for both hot and ground wires to the isolated line. I use 3 way as I like taking both switches to the "off" position in the center as a security measure before flipping from one current to another. Via these switches I can route power to the rest of the layout, or to an analogue transformer.
It works like a charm, but like Ian recommends it basically just enables a very independent analogue loop on the layout. No trains cross over or anything like that. it does leave the benefit of the K83 keeping digital switch control while you run analogue trains though- which is nice.
#7 Posted : 01 August 2012 19:46:54(UTC)
If you have both systems connected but only use one at a time, you must ensure that the cables from the layout to each transformer are equipped with a switch to prevent power from one transformer from damaging the other.
If using digital loks on a layout where you also operate analog loks, you must ensure that all analog loks are safely removed or disconnected when powering up with digital. This may also apply to coaches and cars with lighting as they may not be equipped for digital operation.
The safest switch to use would be a switch which would have three positions, one for digital, one for analog and an intermediate one with no power source. This would ensure that there is no accidental power surge when switching from one system to the other.
You may also decide to power the catenary with DC which will enable you to run DC electrics on a Maerklin AC layout.
Good luck
#8 Posted : 01 August 2012 20:45:24(UTC)
Thanks, Tom
Scared Scared Scared Scared Scared
Offline BR01097
#9 Posted : 02 August 2012 06:01:02(UTC)
BR01097
I'm not sure Sevs^'s question got answered: to have the digital circuit using the center-rail stud contacts and the catenary wire for analog share a common ground (the tracks) routed back to their respective transformers will not fuck up anything. Accidentally connecting the center studs and the catenary at the same time (to each other, I presume that is what is meant) will cause a short, which may blow out a digital transponder.
Personally, I like the idea of running alternating current through the tracks and direct current in the overhead to power the few HAMO locomotives I own to mimic the various European system and cycle differences. It is the same principal of isolated circuity, also to no adverse effect.
#10 Posted : 02 August 2012 08:03:31(UTC)
Say, if I have analog power from the catenary, and digital power from the center studs, and connect both the analog adapter and the digital adapter's ground together, will I fuck up something then?
Love the highly technical technical analysis of potential failure!! "Fails Unless Constantly Kicked" !!
I actually did this for some time on a former layout some years back - the brown/'ground'/common remained connected all the time, but I was also very particular to keep the Red (Stud&Catenary) wiring very distinctly separate. It enabled me to run some older non-converted Loco's along with the Digital ones, in fact against the common advice I used the overhead for Digital and the stud for Diesels & Steam. I had no problems with the Digital off the overhead but at that time I had all older style decoders as well - 6080 & 6090 which seemed quite happy with it, but I understand the potential problems with some of the newer decoders that are more sensitive to the possible erratic contact made by the pantograph.
Keep those Reds away from each other, and above all else, don't cross the beams, keep out of the nebula, and always keep the flux capacitor loaded to capacity, you never really know when you are going to need 1.21 Gigawatts in a hurry!!
Offline sevs
#11 Posted : 03 August 2012 16:21:50(UTC)
sevs
Thanks, everyone! :D
Offline Piete
#12 Posted : 07 October 2023 05:25:17(UTC)
Piete
Great to read the experiences above. So I have an MS1 (60652) which is powered by a Marklin 16V AC transformer via the digital adaptor "ugly box" (60115). That works fine for digital locos on an Mtrack layout. I would like to run analogue locos from the catenary and the two systems would share the track as a common ground. (I also noted above not to accidentally connect the centre rail with the catenary when putting on metal carriages etc).
The question is, can I use the same 16V AC transformer to supply the catenary (analogue locos) and to supply the digital system via the digital adaptor?
Does the digital adaptor (60115) have some kind of floating transformer with a switch mode power supply or does it only use a bridge rectifier? If it is the latter, I think that my proposal to use the same transformer for both systems may not work, because a part of the rectifier in the adaptor would be short-circuited because of the shared ground?
Similarly, can I use that same transformer to supply my Mtrack points and signals because these also use the track as a common ground for the lights.
Or would I encounter the same problem?
Offline BenP
#13 Posted : 07 October 2023 06:05:14(UTC)
BenP
I assume that digital power uses 16V AC yellow and brown connects, while variable analog AC uses red and brown connects of white transformer. While yellow and red are separated (ground is shared), i would not use one transformer for two different systems. Track shorts and rolling stock power demand may cause damaging problems.
Online marklinist5999
#14 Posted : 07 October 2023 14:18:55(UTC)
I>M>H>Opinion, experimenting with too many different power connections, and trying to divide, or separate a layout, signals, and or tirnouts, can result in severe shorts and spikes which can damage digital controllers. Especially newer ones like a CS2, CS3, MS2, etc. which use switched mode power supplies. Mixing these with older conventional tranmsformers is asking for trouble.
If a short circuit doesn't trip the controller saftey quick enough, damage can occur to them, and locomotve decoders.
Offline bph
#15 Posted : 07 October 2023 17:13:55(UTC)
Märklin answers this question with yes in the 03092 book, ref page 167. And also back in 1998, in this publication, see Q and A section on page 78:
https://www.3rotaie.it/Cataloghi/Marklin_Insider_-_Marklin_Digital.pdf
However I would be very careful, and to be sure, send Marklin support an email and ask if it is possible with your equipment. (personally, I would not do it because of the risks)
https://www.hovland.net/bilder/mj/Mix_analog_digital.jpg
a wiring example for older cs2/1 etc:
https://www.hovland.net/bilder/mj/wiring_dig_analog.jpg
Offline Piete
#16 Posted : 08 October 2023 06:31:57(UTC)
Piete
Hi Thanks for the reply. I understand that I can have a digital rail system and an analogue catenary system. But this was not my question. My question is if both systems run off the same transformer? I suspect not because since posting I checked with a multi-meter to see if the brown ground output from the AC transformer is the same voltage as the ground going to the digital track and it is not. Furthermore the diagram shows 2 transformers with neither the active or ground connected.
But I am now also wondering if I can operate Mtrack points/turnouts with the digital power supplying the track, given that it is always on or could this possibly interfere with the digital decoders?
thanks 1 user liked this useful post by Piete
Offline bph
#17 Posted : 08 October 2023 16:12:10(UTC)
how it is rectified might be a valid point, so check with Märklin before you try anything.
But also take a look at picture #8 on page 9, in the above PDF, there you can see that the "track" ground is connected to the "transformer" ground. And page 71 in the Märklin catenary manual
Voltage differences do happen, eg if you power a 60175 booster with a transformer you can get a higher track voltage, compared to what the cs3 outputs when powered with a normal 19v power supply. and according to Marklin support it works ok to connect those two track grounds together....
I powered my analogue m-track turnouts etc for some years using the same transformer that powered the 6021. (just make sure you don't risk making a short between transformer yellow and track red, and if you are using more transformers make sure they have the same polarity)
#18 Posted : 08 October 2023 19:25:21(UTC)
Don't do this, this will destroy the MS1.
There cannot be a common ground between the input side and the output side of any Mobile Station or any digital controller that uses an H bridge on the output side.
This setup was possible with the 6020/6021 and 6604/66045.
Offline Piete
#19 Posted : 13 October 2023 10:34:07(UTC)
Piete
Thanks for the clarification. I am now also wondering if I can operate Mtrack points/turnouts with the digital power supplying the track using a 7072 analogue controller, given that it is always on or could this possibly interfere with the digital decoders and MS1?
Offline BenP
#20 Posted : 17 October 2023 14:54:38(UTC)
BenP
Seems to me that you are better off connecting the turnouts to the yellow-brown of an AC transformer with 7072 box. This powers the switch light and controls solenoid separate from digital track power, and lowers power draw. (You can use red-brown of that AC transformer for scenery incandescents)
Added: this does require shared track ground between AC and digital, which others seem to discourage.
Edited by user 18 October 2023 13:45:35(UTC)  | Reason: Not specified
Offline SvenM
#21 Posted : 05 July 2024 06:16:35(UTC)
SvenM
Following on from the above, I am running digital steamers and diesels from the track and analogue electric locos from old school catenary - they work fine - just don't have a derailment that brings the overhead down on the track!
My question is: I am using the old school K track signals and would like to have a go at automation; can I use the power out-takes (is that what they are called?) for the track and overhead (are they connected?) of the same signal (like you can for an analogue system) to power each system or, will that bugger everything up?
Many thanks for your help in advance
thanks 1 user liked this useful post by SvenM
Offline Wolfram_Stn
#22 Posted : 09 July 2024 20:07:19(UTC)
Wolfram_Stn
Hi Sven,
as long as there is no, but really not any contact between the two circuits, you can do what you asked.
And as long as the signal has not been deteriorated, you will not have any contact.
Why?
Because on analogic layout, you did not have any contact between track and catenary, so why should you have in semi-digital?
Good old 7239 old type (with the same relais as 7039) and 7188 had a fixed pair of red cables to connect on the track, and a pair of connectors for the catenary.
Newer models (flat relais) had two pairs of climp connectors, which you could use on your choice for track or catenary. In fact, it's the same relais as 7245 but 7245 has no signal lights.
See p.25 (pdf-page 26) in this document: https://www.marklinfan.n...cumenti/SignalManual.pdf
you connect your track to H and K (one inside the controlled sector, one on the central), and your catenary to L and N (one inside the controlled sector, one on the transfo).
If you read a little bit spanish - I did not find the english version... https://www.marklin-spai...y_conduccion_Marklin.pdf
thanks 3 users liked this useful post by Wolfram_Stn
Offline SvenM
#23 Posted : 10 July 2024 10:37:16(UTC)
SvenM
Originally Posted by: Wolfram_Stn Go to Quoted Post
Hi Sven,
Why?
Many thanks for the reply Wolfram! That was what I was thinking too but wanted confirmation from one of the many experts on this great forum!
thanks 2 users liked this useful post by SvenM
This page was generated in 0.950 seconds.
