Offline jonas_sthlm
#1 Posted : 31 March 2012 14:03:16(UTC)
jonas_sthlm
I am trying to get feedback from the TT bridge through Viessmann S88 5233 device.
The question is whether this will work and what feedback is the best option Confused
If I connect everything like the drawing show the bridge always report activity from the track Confused
Should not the connection with track symbol B 0 0 be separated from all other electronic inside box.
Edited by user 01 April 2012 21:49:12(UTC)  | Reason: Not specified
Offline jonas_sthlm
#2 Posted : 15 April 2012 14:26:23(UTC)
jonas_sthlm
I find the problem so everything work fine now BigGrin
I remove "Interference suppression protection" between B and 0 on the bottom.
Offline French_Fabrice
#3 Posted : 07 May 2012 16:11:32(UTC)
French_Fabrice
Many thanks for your schema. ThumpUp
I've successfully set up my TT as yours. I had luck, there was no capacitor !
After definitive wiring, I'm preparing a test with Rocrail.
Thanks again.
Fabrice
Offline jonas_sthlm
#4 Posted : 17 May 2012 12:05:32(UTC)
jonas_sthlm
Fun and good that we have this global forum to help each other, as long as you live, you learn ThumpUp
Offline ecastrog
#5 Posted : 01 June 2015 16:48:40(UTC)
ecastrog
Ecuador
Hi Jonas
I am interested in your post, but unfortunately seems that the image have been removed. I have the same problem that you had, so I was trying to find a solution
Could you please share the image again?'
Thank you very much.
Esteban
Offline efel
#6 Posted : 15 June 2015 13:11:40(UTC)
efel
Hi Jonas,
Could you tell us if the "Interference suppression protection" you remove is the component we can see there:
https://www.marklin-user...--quick-Howto#post491199
Do you have more detail (type, reference..) about that component?
Thanks in advance,
Fred
This page was generated in 0.321 seconds.
