Offline Danlake
#1 Posted : 01 May 2012 01:59:45(UTC)
Danlake
Good day fellow hobbyist,
I have started working on the lighting circuit for my small layout.
I decided to go with a 12V DC supply with dimmer and use of LED's. I believe is the most cost effective solution and safe as you don’t end up installing buring hot lamps in small plastic enclosures... Regarding LED I found below websites really handy:
General about LED:
http://www.kpsec.freeuk.com/components/led.htm#colours
Tinting of LED:
http://www.ngineering.com/led_coloring.htm
With inspiration from another user here (https://www.marklin-users.net/fo...st16932_Jornebanen.aspxk) – thank you JorgenBigGrin - I also constructed my own platform lights. Cost me about 1.5 USD a piece.
The lights are made up of 3mm warm light LED, 460 ohm resistor and brass tubes from K&S engineering:
I used the brass tube tube itself as a conductor. Used an automobile grey coloured primer spray can, which gave a really nice finish.
The hood is made from dome studs (clothing accessories found on Ebay). Hardest part was to drill the hole in the top...
Final result:
And most importantly it was lots of fun to make it yourself!
Brgs - Lasse
thanks 3 users liked this useful post by Danlake
Offline Chris6382chris
#2 Posted : 01 May 2012 02:13:28(UTC)
Chris6382chris
Danlake:
Great post. The lights look great. Did you taper the tubing at the end where the light fixture attaches or does it just look like that?
Chris
Offline Danlake
#3 Posted : 01 May 2012 02:32:15(UTC)
Danlake
Hi Chris,
Thanks - the 2 pins from the LED is used to secure to the brass tube. The minus is soldered to the brass tube itself and the plus is soldered onto the cable which you can see just penetrating from the open end of the tube. The black part above the hood is just the top part of the actual LED painted black.
Brgs - Lasse
#4 Posted : 01 May 2012 03:08:57(UTC)
Lasse,
Looks very neat and realistic.
Offline Maxi
#5 Posted : 01 May 2012 03:34:53(UTC)
Maxi
Very nice design.
I also made my own lights and found the project to be rather satisfying.
A sample of my designs can be seen at the following site.
Home made street lights
Matthew
Offline Lollo
#6 Posted : 01 May 2012 14:05:24(UTC)
Lollo
Excellent work, it gives me inspiration to make my own.
Thanks for sharing.
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
Offline Iamnotthecrazyone
#7 Posted : 01 May 2012 14:33:11(UTC)
Iamnotthecrazyone
nice work
Offline kariosls37
#8 Posted : 02 May 2012 04:52:34(UTC)
kariosls37
Nice lights. Those K&S tubes are suseful arent theyThumpUp
Offline Danlake
#9 Posted : 02 May 2012 12:54:05(UTC)
Danlake
Thanks for comments.
I was hoping to make some other versions (for street lights) where the top is bended 180 degress (u-shape), but keep getting sharp kinks in the tube. I was wondering if anyone had some good techniqiue to bend the tubes smoothly (maybe by heating them)?
Enjoyed browsing trough your website Matthew. Nice layout you build.
Brgs - Lasse
Offline jeehring
#10 Posted : 02 May 2012 14:10:21(UTC)
jeehring
...that's what I was wondering tooo : how to bend the tubes without "flatten" them, to make a nice curve...
Good idea, well inspired .thank you.
Offline kbvrod
#11 Posted : 02 May 2012 14:56:31(UTC)
kbvrod
thanks 1 user liked this useful post by kbvrod
Offline Danlake
#12 Posted : 02 May 2012 16:23:14(UTC)
Danlake
Excellent - I shall order some of these springs nowBigGrin
Offline Maxi
#13 Posted : 03 May 2012 00:19:32(UTC)
Maxi
Brgs - Lasse
Thank you, it was a real joy to build and play with.
To bend the 3mm tubing to a virtual U-shape, I created a simple jig. Wasn't a perfect U-shape, but created the shape I was looking for.
Here is a few pictures of the jig I created.
Jig parts with a sample bent tubing.
Jig parts
Tubing is inserted until it reaches the screw.
Jig parts
Views of jig
Jig parts
Jig parts
Jig parts
Hope this gives some ideas for trying to create your U-shaped lamp posts.
Matthew
Offline Danlake
#14 Posted : 03 May 2012 02:54:56(UTC)
Danlake
Good idea Matthew,
Thanks for tips!
Offline Johnvr
#15 Posted : 03 May 2012 17:01:11(UTC)
Johnvr
Great lights !
Regards,BigGrin
#16 Posted : 16 May 2012 12:05:32(UTC)
Very good tips and sites.
NN
Guest (8)
This page was generated in 0.451 seconds.
