Offline 20-VOLT-AC
#1 Posted : 28 April 2012 10:56:14(UTC)
20-VOLT-AC
Hi Guys.
Does anyone know which control switches i need for a 451 G crane (early version ) ?
Neil.
1950's Marklin Fan .
Offline Dave Banks
#2 Posted : 28 April 2012 11:28:47(UTC)
Dave Banks
Neil, is this what you are looking for: http://www.ebay.com/itm/...-Crane-HTF-/120897658420 ?
This will also work: Märklin Control Box 97279 in newer grey box.
D.A.Banks
#3 Posted : 28 April 2012 11:35:46(UTC)
Eckert Engineering on US ebay have the newer (white) control boxes.
Offline Dave Banks
#4 Posted : 28 April 2012 11:57:02(UTC)
Dave Banks
D.A.Banks
Offline Markus Schild
#5 Posted : 28 April 2012 12:45:41(UTC)
Markus Schild
Hi Neil,
The early version came with a pair of switches like these (one of each). But they had special stickers and were numbered 474/51 and 475/51. But there is no technical difference.
Markus
Offline 20-VOLT-AC
#6 Posted : 28 April 2012 12:58:07(UTC)
20-VOLT-AC
Hi Markus.
Yes they look like the ones, all metal construction types.
Will get some on ebay DE site, none here in UK !! Glare
Thanks Neil.
Offline 20-VOLT-AC
#7 Posted : 28 April 2012 13:05:59(UTC)
20-VOLT-AC
Does anyone know if the mechanisms and gearboxes on the early 451 G cranes are the same as the later 70** series ?
Can the drive parts on later versions be swapped over and used for donor parts on early versions if needed ?.
They are well engineered inside.
Neil.
#8 Posted : 28 April 2012 14:36:14(UTC)
Markus Schild
Hi Neil,
Yes, the drive parts of the 7072 would fit mechanical also in the early version. But in detail a 1950s part every-time looks a little bit different from the later ones. Due to historic reasons I would avoid to mix up new parts in an old crane. It is always cheaper to buy a model in good working condition than restoring one.
Markus
#9 Posted : 29 April 2012 23:28:50(UTC)
Originally Posted by: DaveB Go to Quoted Post
Yes, that's them!
Offline drstapes
#10 Posted : 30 April 2012 01:22:54(UTC)
drstapes
I gather you can use the 7072 control boxes as well,which would be a lot cheaper,perhaps someone could explain how this is done?
Geoff (UK)
#11 Posted : 30 April 2012 11:36:27(UTC)
Markus Schild
Hi Geoff,
Yes, this can be done, but you need an additional control - box 7210. The functions "up/down" and "rotate" must be connected to the 7072, the magnet and the light (these are two functions at early cranes) to the 7210.
Markus
Offline drstapes
#12 Posted : 01 May 2012 00:08:52(UTC)
drstapes
Marcus,
Thanks for your reply,
You really have the answer to everything!
Geoff (UK)
Offline 20-VOLT-AC
#13 Posted : 02 May 2012 21:37:38(UTC)
20-VOLT-AC
Thanks guy's for all your interesting answers on this post !
Neil.
Offline LMS800
#14 Posted : 03 May 2012 11:26:08(UTC)
LMS800
Hello Neil,
for the cran 451 G you need two control panels, panel 474/51 for "turn left", "turn rigt", "up" and "down"
and panel 475/51 for light und magnetic funtions.
Regards Wolf
#15 Posted : 03 May 2012 17:42:43(UTC)
Neil.
Neil
I have an extra control for that crane, but later (blue) version .
It's yours, just send me an MP with your coordinates
Jacques
This page was generated in 0.431 seconds.
