Offline frankthetank
#1 Posted : 10 April 2012 21:06:23(UTC)
frankthetank
Hi everyone,
I am trying to control a Marklin set using the 6051 digital interface connected to the 6021 control unit. The code is running under Windows XP and I am using the RXTX v2.1 (http://rxtx.qbang.org/) library to communicate via computer's serial port.
The serial connection is set up with the settings prescribed on the Marklin website (baud rate is 2400, 2 stop bits, no parity, 8 bit word size).
Sending one-byte commands (system-wide go/stop) works fine. However, any two-byte commands (e.g. loco control) fail. Following such an attempt also prevents subsequent one-byte commands from working until the system is hard-reset.
Any suggestions?
Thanks!
Frank
Online H0
#2 Posted : 10 April 2012 23:27:32(UTC)
Hi, Frank, and welcome here!
Did you activate hardware hand-shake (RTS, CTS)?
#3 Posted : 11 April 2012 03:14:12(UTC)
frankthetank
Thanks for the welcome and your reply!
I have gone into the Windows XP device manager and, under the properties for the serial port, set the port's settings to:
Bits per second: 2400
Data bits: 8
Parity: None
Stop bits: 2
Flow control: Hardware
I believe that the "Hardware" setting for flow control should enable the CTS/RTS handshake. Is that correct? Or does this need to be configured somehow in the code (that is, via the serial communication library that I am using)?
I am very much a beginner in this area, but it is confusing to me that the one-byte commands work fine, but I have never been able to get any two-byte command to work at all, and I don't have a good guess of where to begin troubleshooting.
Thanks again for your help!
Frank
Online H0
#4 Posted : 11 April 2012 08:33:04(UTC)
Yes, that should do it.
I never tried a 6051, but IIRC there can be a problem if commands come to fast.
You could try a Sleep for 500 milliseconds after each byte - maybe this will get the two-byte commands to work.
Or maybe a 6051 expert can help ...
Offline Renato
#5 Posted : 11 April 2012 15:49:36(UTC)
Renato
Hi Frank,
If I remember well, first the command byte and then the locomotive address byte are sent.
Did you do this or did you inverted the two bytes?
Kind regards
Renato
#6 Posted : 11 April 2012 15:52:49(UTC)
frankthetank
Ok, I will try later with a sleep before each byte (I think I might have tried this already, but I can't remember) and then update this post.
Yes, I took note of this order and sent the command byte (loco speed/function) before the address byte. I also tried it in the reverse order, just in case, but (of course) that did not work either.
Thank you both for your input!
EDIT: Putting a 500ms sleep between bytes had no effect...
Edited by user 11 April 2012 19:56:29(UTC)  | Reason: Not specified
Offline rjftrains
#7 Posted : 12 April 2012 04:17:47(UTC)
rjftrains
You really need to put a loop in your code to keep polling RTS/CTS to see if the device (6051) is ready to accept the second byte of any two-byte command sequences (locomotives, turnouts, etc.). I struggled with this when I wrote my own software (TPL) in VB3 a long time ago; this caused me some issues as well. And, as you've discovered, sending the second byte before the Interface is ready will indeed lock it up. I can only tell you what I did with VB (but I did get it to work perfectly). Please contact me via e-mail if you think I might be able to help you.
Robert Frowenfeld
RJFtrains@aol.com
www.RJFtrains.com
914-232-5546
#8 Posted : 18 April 2012 05:26:53(UTC)
frankthetank
Thanks for the input. Yes, it sounds like my problems are similar to those that you faced. I have since checked to ensure that flow control is set to CTS/RTS and added a loop to poll the device for CTS before any byte is sent (and if not, wait 100 ms and try again).
This is what I'm observing now:
One-byte commands continue to work. So, for example, if I want to start the whole system, I poll for CTS (the device is immediately ready) and then send the number 96 and the system responds.
This change has not fixed two-byte commands. However, at least I understand what's going on a little better (but not why). If, for example, I want to set train #26 to speed 10, I poll for CTS (the device is immediately ready) and send the number 10 (speed). Again, I poll for CTS (again, the device is ready) and send the number 26 (loco address). However, the locomotive does not change speed. Now, if I want to send any subsequent command (e.g. stop the system by sending the a single byte, the number 97), I first poll for CTS, and at this point the device has locked up, it remains in the loop indefinitely (well, I've waited for ~20 seconds), and I need to reset the system.
I'll continue experimenting in this area, but it's starting to feel like I've tried everything.
#9 Posted : 18 April 2012 11:39:02(UTC)
Hi Frank,
For what it's worth, make sure you rule out the Cable.
Are you using the one that came with the 6051?
And assuming also that if you are, it is connected directly to a 9-pin COM port on your PC? (rather than through a 9pin-25pin adapter)?
If the Handshaking wires are not connected as required you will also get weird symptoms.
Melbourne
#10 Posted : 18 April 2012 11:49:35(UTC)
One other thing I might suggest is confirming if everything works normally with one of the other control programs, Digipet for example has a Demo version for download...
http://www.windigipet.de/downloads-international/win-digipet-english/ although these demo version are usually crippled to prevent saving files or limited to only 1 or 2 loco's, it might still be a good test for your setup to aid in troubleshooting.
#11 Posted : 18 April 2012 14:16:27(UTC)
I'm watching this with some interest and hopefully will one day get my interface going but to connect it to a computer, the computer must have some type of program to receive or operate or is able to communicate with both components.
What would some of you recommend which program to use ?
regards.,
#12 Posted : 19 April 2012 11:22:33(UTC)
Make sure you DO NOT have the loco dialed up on the 6021 (or any 603x)
This page was generated in 0.677 seconds.
