Offline Maurice
#1 Posted : 10 March 2012 06:55:49(UTC)
Maurice
I have a 7191 buffer that shorts out the track when the yellow wire is attached to the lighting circuit.
Is the screw by lantern supposed to be isolated in some manner? The one I have does not seem to have any isolation with buffer metal and I suspect this is the problem.
I do not have another to compare so any help appreciated.
Regards, Maurice
thanks 1 user liked this useful post by Maurice
Offline Western Pacific
#2 Posted : 10 March 2012 10:30:59(UTC)
Western Pacific
Yes, there is a need to have insulation between the screw, the "hood" and the buffer plank on the one side and the tongue soldered to the yellow cable on the other side. If not insulated, you’ll create a very direct contact between the yellow cable and the track bed of the M-track and in other words connecting the yellow cable directly to the brown return cable.
On my old layout I had a couple of those stop blocks (and of course at places difficult to reach) and I have dropped the small plastic insulation a number of times when changing bulbs, but luckily always found it after some searching after I had detected the short circuit. (I often did this type of work with the transformers switched off on that layout).
If the plastic piece is totally missing, perhaps you can wind a small amount of electric tape around the tongue soldered to the yellow cable at the end where the screw goes.
Offline Maurice
#3 Posted : 11 March 2012 02:02:49(UTC)
Maurice
Thanks very much for the advice - electrical tape worked well. Maurice.
Offline jimwallace1652
#4 Posted : 07 September 2015 22:22:22(UTC)
jimwallace1652
This solution worked for me too. Thank You very much
thanks 1 user liked this useful post by jimwallace1652
This page was generated in 0.417 seconds.
