Offline dan67millie
#1 Posted : 09 March 2012 19:18:58(UTC)
dan67millie
Hi can anyone help with a scratch building project of mine. I need the measures of a v100 or 212 diesel. First the distance between the centre of each axle on one bogie to see if it is the right size for conversion and the length from the edge of the buffer to buffer not length over buffers as per cat discription! also a measure between the centre of each bogie to bogie if you can. Plus if any one can be so nice as to tell me the motor bogie size please.cheers Dan I dont have ither locos so a measure from one would be greet tar
#2 Posted : 09 March 2012 19:35:08(UTC)
I think it´s same underframe of both diesel locomotive.
#3 Posted : 09 March 2012 19:40:58(UTC)
Märklin's new V 100.10 (later 211) will be shorter than Märklin's new V 100.20 (later 212, 213, 214).
If the question is about V 100.20, then these are only two different class names for the same locomotive.
I don't know if the old V 100.20 from Märklin has the correct dimensions (at least the handrails are not correct).
The current V 100.10 from Märklin uses the same frame, therefore it is too long.
Offline dan67millie
#4 Posted : 09 March 2012 19:57:21(UTC)
dan67millie
Yes thanks but i need the measures please because i dont have ither cheers Dan
#5 Posted : 09 March 2012 20:16:13(UTC)
Will prototype information be helpful for you?
http://www.loks-aus-kiel...p?nav=1400696&lang=1
Bogie to bogie: 6000 mm, axle to axle in a bogie: 2200 mm
http://www.v100.de/index.php?nav=1402249
http://www.v100.de/index.php?nav=1401189
Offline dan67millie
#6 Posted : 09 March 2012 20:40:37(UTC)
dan67millie
Thankyou cheers have a good weekend DanBigGrin
This page was generated in 0.310 seconds.
