Offline anthpao
#1 Posted : 29 December 2011 13:19:30(UTC)
anthpao
I have a problem with MS2 and ESU Sound decoders.
If the loksound decoder is M4 (mfx) then all 15 functions are registed and there is no problem. The problem is when the decoder is Loksound 3.5 or 4 with no auto register function. If I install such a decoder then I cannot access F8 to F15.
How should I register the decoder, by choosing "Find" in MS2 menu, by manually adding the address or by choosing from database the 36330 article?
In all three scenarios I get on the MS2 display the Functions for the lights and F1 to F4. If I manually add all the availiable functions then only F1 to F8 is working. F9 to F15 do nothing.
Please help...
#2 Posted : 29 December 2011 18:27:36(UTC)
Add the loco manually as DCC locomotive (not MM programmable nor the other MM option).
This page was generated in 0.212 seconds.
