Offline Rinus
#1 Posted : 12 December 2011 21:40:14(UTC)
Rinus
Hi there,
I'm about to give Rocrail a try on my lay-out.
I've explored their page, downloaded the program and watched some vids on youtube. It all looks good. Besides that its free! Digipet costs quite a lot.
I especially appreciate the possibility to use my Uhlenbrock Lissy transmitters as contacts + my Intellibox. I've got quite a lot of them and it would be a waste of money not to use them.
On this forum I noticed some users of the program.
Can you tell me your experiences? What are the easy-to-make-mistakes? Is it as reliable as the website promises?
Im a real novice in using software+pc to manage my lay-out.
Thanks in advance,
Rinus
Offline Nielsenr
#2 Posted : 12 December 2011 22:07:26(UTC)
Nielsenr
Rinus,
I did download Rocrail and installed it on my laptop a while ago. I did get it to communicate and control a couple of locos. Haven't done much with it since, but one of these days I will get back to it. If you do start using it, please post your experiences with it. I too liked that it was free.
Robert
Offline French_Fabrice
#3 Posted : 12 December 2011 22:57:28(UTC)
French_Fabrice
Hi Rinus,
I'm using Rocrail since about 6-8 months. I've chosen this software primarily because my computers all run under linux, but I've also tried it in a virtual machine under XP with the same success.
I can't compare with any other train software as I don't own others. My advice may be a "one point of view only".
My layout is not very large (18 blocks are setup) and is still under construction, so I can't provide any real "continuous operation" feedback, but from time to time I put 8 / 10 locos running for an hour in automatic mode, and that's really amazing, especially the random way the routes are chosen on the fly...
About mistakes...mmm, I don't remember a lot...Sometimes misunderstanding on my side, but the default values Rocrail is configured with are "secure" so there is not a lot of risks. Enable the "Stop on Ghost train", as it will immediately stop operation in case an unknown loco or wagon is on an unplanned block.
Carefully read the docs, there are a lot of infos. Read and re-read them and quickly experiment a feature you're interested in as it is a very rich software with many many possibilities.
Start with the tutorial with very basic things, stop, go, setup a turnout address, switch it with the mouse, add a MM loco (Motorola 14), then maybe a DCC if you owns one, and finally a mfx. Regarding mfx, it's a bit special, read the docs before (you'll have to find out the "real" address)...
Then only add one sensor -contact track, reed, circuit track- (or more), create a block, and look if the sensor activates when the loco is in the block. Then, add more blocks and a route, and experiment.
I use it with a 60214 CS2, no special trouble except sometimes some of the 763XX signals don't start, so I press the stop bar then release it, and the normal behavior comes back. I think it's an electric problem on my side, not with Rocrail. No glitch with turnouts and locos.
I've started blocks with only one sensor per block. It gives good results but not very satisfactory if you want to stop the loco just before the signal. I recently attempted 3 sensors in a block, then downgraded it to 2 sensors per block. Using timers with the events "enter2pre" and "in" and adequate tuning of the deceleration of each loco (decoder tuning), it gives perfect results.
I don't use a turntable at the moment, but I'm planning one if I find enough room !Crying
That's my feedback at the moment, but I'm far from having discovered all that software can do.
HTH
Fabrice
Offline Besra
#4 Posted : 13 December 2011 12:36:41(UTC)
Besra
Hi Rinus,
I'm using Rocrail since beginning of 2009, starting as a complete novice in computer control of model railroads. Over time I became familiar with both the program and required hardware. I'm still using my old Intellibox (from the mid 1990's). A word of warning here: The Intellibox (the old one, 65 000) is known to perform unwanted and spontaneous resets if connected to a PC via the serial connector - not always but in most cases. Loads of discussions on various forums regarding this topic. There is a simple way to overcome this drawback, not for free but much cheaper than a new controller: Do not use the RS232 connection. Connect the Intellibox via LocoNet instead. I described how to connect the components here: http://wiki.rocrail.net/doku.php?id=intellibox-en (Chapter Spontaneous Resets). Since my IB is connected to the PC via the Uhlenbrock USB-LocNet-Interface I never had any spontaneous resets any more.
Back to Rocrail: If you follow the tutorial http://wiki.rocrail.net/doku.php?id=stepbystep-en you are on the save side. However avoid changing any parameters you don't understand (a little word of warning here because recently someone entered his controller's IP address where by default the port and address of the Rocrail server are configured - something you never have to change usually - of course it did not work and the guy complained Rocrail was possibly hard to understand BigGrin ).
Besra
thanks 2 users liked this useful post by Besra
Offline dntower85
#5 Posted : 13 December 2011 22:29:05(UTC)
dntower85
I have used RocRail of and on for a few months now. Is great for a shareware program but sometimes it seems a little buggy when running in the automatic mode, Not crash blue screen of death buggy but I some times get unpredicted results when dealing "Autogen" routs running in automatic mode. And only some times. Confused
I might have a rout that says the train can go from Block A > B > C (">" = direction of travel) and another one that says go from C > B > A;
So the strain starts at A goes to be then to C, then it invokes the next rout and it knows the train can travel from C to B but it would sometimes assign the rout as C < B > A so when the train gets to B it thinks its going the wrong way and tries to run the train back to block C then when the train runs to block A it registers it as a ghost train.
there were some other strange things that I had to do to make it work at all see attached screenshots.
Orignal
this made it work by moving the hidden station from the bottom to the right
worked this way
I have registers so that I can use AndRock but have yet to try it, because I have disconnected the 100 foot Ethernet cable that ran from the router up the stairs to the Ecos station. Bored Blushing
DT
thanks 1 user liked this useful post by dntower85
Offline Rinus
#6 Posted : 14 December 2011 12:49:53(UTC)
Rinus
Many thanks for posting your experiences!
Very usefull. Hard to imagine that something that is for free is so interesting in this hobby, isn't it?BigGrin
I've started drawing my trackplan last evening. I hope that it will go faster when I get some more experience. There aren't fast keys to select a certain type of rail arn't there?
Do you guys try to draw in a certain scale, or do you keep it pure schematical? And do you open a new railplan for every level of the lay-out or do you draw the entire lay-out in one window?
Also, do one of you use Rocrail in combination with Lissy?
Bye,
Rinus
Offline dntower85
#7 Posted : 14 December 2011 15:08:16(UTC)
dntower85
Rinus,
Scale is not important but leave enough room when your creating block names so the title of the train show up properly.
This will help when you have two BR 01's on the track if its too short it cuts off the road number and you cant tell which one is where on the screen.
I had to redo it a few times to get every thing to show up on the laptop that I use to run the train.
Also save different version of the layout, a good practice would be to save the layout with a different name just before you hit AutoGen to create routs. If you have a mistake in the drawing and you hit autogen it can make some strange rout connections that are hard to get rid of with out starting over.
The thing I like most about RocRail is the simulation mode you can start it up in automatic mode and start clicking your contacts the way the train would run and test it over and over before you ever connect it to the layout.
If you have a complex layout you might want to build just sections of it and test them in the simulation mode first before adding it to the full track plan.
The other thing I like is that you can define a block with only one contact sensor. Most of the other programs require at least a contact for the train entering a block and one on the exit. In my hidden station I don't care if the train suddenly stops. So I only have one contact on each track in the hidden station where I want to stop the train and one as the train enters the yard to slow it down.
DT
Offline Besra
#8 Posted : 14 December 2011 18:46:25(UTC)
Besra
Hi Rinus!
No, there aren't any accelerator keys to select objects. The <Alt>-R combination, however, is very useful to rotate objects. There's a wiki page listing all accelerators: http://wiki.rocrail.net/doku.php?id=gui-accel-en in case you are interested.
Concerning the track plan the message is: keep it simple! Rocrail is not a track-planning program. Citing the wiki: "Every object in the track plan will use resources from the underlying Operating System. Objects without any functionality for controlling the layout should be avoided for optimal performance". In other words the more elements (objects) the faster your PC's CPU has to be. You won't see a major difference between 50 or 100 elements but 1,000 may have an effect...
You may split up your layout on different levels (tabs in the plan-window of Rocview). If you have a larger layout that otherwise won't fit your screen size this is the method of choice. I have four levels so I can keep the zoom at 90% which allows for the objects to have a suitable size on my touchscreen monitor.
Besra
Offline Rinus
#9 Posted : 17 December 2011 00:12:02(UTC)
Rinus
Great!
I'll explore the programme this weekend!
Regaqrds,
Rinus
Offline dntower85
#10 Posted : 21 December 2011 03:33:58(UTC)
dntower85
Well after having a vacation day and getting to play with Rocrail and even getting andRoc on the tablet up and working.
But after a few hours of fun, Rocrail crash and it messed up everything.Cursing Cursing
I had to reinstall Rocrail and now even though I finally got the track plan loaded again I can not get a good connection to the Ecos station.
Rocrail can only turn on and off the track power and it does not control the Locos or switches.
DT
Offline dntower85
#11 Posted : 21 December 2011 21:11:33(UTC)
dntower85
The Rocrail forum got me back running again
But I still have some issues with some of the routs
oops
DT
Guest (4)
This page was generated in 0.462 seconds.
