#1 Posted : 12 December 2011 09:51:18(UTC)
Is the 60901 conversion kit suitable for this loco.I am planning to get two of them for the 3662,i think this great loco deserve a better decoder.
#2 Posted : 12 December 2011 10:14:53(UTC)
Is it possible to keep the decoder and change the two motors or i must change decoder and motors too?
#3 Posted : 12 December 2011 10:45:25(UTC)
Hi Panayotis,
The 3662 has a 6080 decoder and the motors are AC DCM. If you change the decoder to a better one with load regulation, acceleration and braking, etc, you will most likely need to change to motors to a DC type. You can do this with a 60901 set or newer equivalent, or just by changing the field magnet to a permanent magnet Hamo type.
Just upgrading the motors without upgrading the decoder is not really practical or desirable, in my opinion.
#4 Posted : 12 December 2011 10:53:36(UTC)
The decoder is a 6080 as Ray mentionned, and since it was to weak to drive two motors, Märklin added a "booster-board" to drive the twin motors.
That board is designed for wire-wound( so called "universal") motors and cannot be used with a 60901 type decoder.
If you drive the loco under heavy load, use two decoders, and simply synchronize them using the little potentiometers.
Otherwise under light loads, the 60901 can drive two motors, providing everything is mechanically sound in the transmission.
#5 Posted : 12 December 2011 10:57:36(UTC)
My problem Ray is the bad acceleration and braking delay.These two characteristics are depending on decoder or on the motors?The loco behave such as have a delta decoder.
#6 Posted : 12 December 2011 11:02:37(UTC)
The acceleration and braking delay is controlled by the decoder, so you definitely need to change it if you want this improvement.
I would suggest a lokpilot decoder and changing the motors with Hamo magnets. This is probably the cheapest and easiest way to achieve what you want. I believe one lokpilot can supply enough current for two motors.
#7 Posted : 12 December 2011 11:07:34(UTC)
Hi Panayotis,
By using a 60944 conversion set and 1 ESU lokpilot/Sound decoder you could do a lot with this loco, especially the prototypical light setting.
#8 Posted : 12 December 2011 11:31:00(UTC)
Thank you very much for your help my friends.Now i have to knoe how much i need to pay for all these
and if it is something i can afford now i will do it.
#9 Posted : 12 December 2011 11:35:24(UTC)
The conversion set is € 26.95 each, the decoder Lopi around € 30.00 and the sound decoder around € 100.00-120.00
#10 Posted : 12 December 2011 13:46:19(UTC)
If you want to do the conversion with only changing the magnet, Hamo magnets are about 10 euro each from ESU
#11 Posted : 12 December 2011 14:23:51(UTC)
If you go with the hamo magnet you may find the 2 motors may draw too much current and one decoder may not be enough.
So a quick calculation with a possible scenario 2 hamo magnets = € 20.00, 2 decoders € 60.00 = € 80.00
2 conversion sets € 54.00 + decoder € 30.00 = € 84.00.
#12 Posted : 12 December 2011 15:29:37(UTC)
I think i can afford it.If i change only the decoder and anything else?
Offline sudibarba
#13 Posted : 13 December 2011 05:05:29(UTC)
sudibarba
2 hamo magnets and one Lok Pilot decoder. Just remember to reverse the polarity on the motors so that they don't run in contention. The new decoders can handle 2 motors. I have converted many F7 two engine consists this way.
You could upgrade to 5 star motors but the improvement is minimal.
Eric
#14 Posted : 13 December 2011 08:55:25(UTC)
Thank you very much all of you.I will choose the solution of the two hamo magnets and the decoder.
#15 Posted : 01 February 2012 04:43:53(UTC)
Can anyone tell me the exact type of decoder and hamo magnet i need, to buy them?I see for example on ebay.de hamo magnet 51960 and 51961.Which type i have to choose?Decoder 54610,54611 etc.Which type i have to choose.I do not care
about sounds.Thank you again for your help.
#16 Posted : 01 February 2012 06:20:29(UTC)
Right<
ESU Magnet 51960 for DCM Motor need 2.
Decoder lokpilot V3 8 Pin Is cheaper than the 21 Pin.
Or 2 ESU Conversion Kits 54632, has Magnet and Decoder. you will have a spare decoder but you will find a us for it. the 54632 Kit is $43.90 US not sure in Euros.
Nev
#17 Posted : 01 February 2012 09:22:11(UTC)
Great help Nevvile,thank you very much.I will try to do the best for this great F7.
#18 Posted : 27 February 2012 18:52:20(UTC)
I ask marklin service departpment an answer to this problem and i must say that they answer immediatelly.They told
me to use two 60941 motor sets and one 60942 decoder.I will follow this sollution and i hope i will improve my great
F7.LOL
Offline sudibarba
#19 Posted : 28 February 2012 01:44:31(UTC)
sudibarba
F7.LOL
This is a good solution but I feel you could do almost the same for half the price with 2 ESU magnets(plus new brushes) and 1 ESU decoder. That assumes the motor covers and and armatures are in good shape.
Eric
#20 Posted : 28 February 2012 11:49:23(UTC)
All the loco is in great shape.Maybe a 60962 decoder with 60941 motors is another sollution,i asked my
dealer if there is a difference between the two decoders.Then i will decide but i think that i will go
for a marklin sollution.Thank you for the reply and help Eric.
#21 Posted : 14 April 2012 15:39:33(UTC)
Finally a friend from the Hellenic marklin club Andreas did the conversion.We put two 60941 motors and one 60942 decoder.The great F7 is now MFX ,have a lot of power and runs like a dream.I am very satisfied with the result of conversion.LOL
Offline 3rail4life
#22 Posted : 15 April 2012 14:07:36(UTC)
3rail4life
That is very cool, glad to hear it all worked out for you. I am planning to do the same conversion to my Santa Fe Blue Bonnets.
Gordon
This page was generated in 0.910 seconds.
