marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Registers on the forum
Register
OK
General topics
Digital
CS2 v3
2 Pages
1
2
Go to Page...
CS2 v3
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
linepro
#51
Posted :
10 February 2011 19:22:25(UTC)
Retweet
Originally Posted by: linepro
Looking at the changeLog.xml in the latest update:
GFP - Changelog
V1.36
Eine einstellbare Leistungsabgabe der Treiberbrücke zur Anpassung an den verwendeten Trafo. Diese ist aber noch nicht aktiv, da das Gegenstück in der GUI noch fehlt
"Adjustable power output of the bridge driver to adapt to the used transformer. But this is not yet active, as the GUI portion is missing"
So the sole question is adjustable up (how far) or down only?
Certainly looks hopeful for a 60214 -> 60215 software upgrade.
Also found over on Stummis:
Latest 60214s and all 60215s have isolated ground (brown cable), so that might have a bearing [whether you have adjustable output]. 60214s with the isolated ground have a special symbol next to the CE mark on the identity label on the back. May also explain why they decided to call it 60215 so that they could identify the hardware change.
User Profile
View All Posts by User
View Thanks
laalves
#52
Posted :
10 February 2011 19:26:10(UTC)
Retweet
@linepro: What does the special symbol look like?
WWW
User Profile
View Thanks
Posted :
10 February 2011 20:45:09(UTC)
Retweet
Originally Posted by: jeehring
Originally Posted by: laalves
Raising the available current to 5 Amp may also be excellent to solder wheels and sliders to the rail and pukos, thus creating permanent display rolling stock in the layout.... ;)
.....how or why ?
This is the same point that I made in post #11 in this thread.
How you ask? When a short occurs, e.g. a loco or coach derails creating a track short, the momentary high(er) current flowing through the wheels can melt the metal, and the metal in the rails, therefore instantly fusing them together. The higher the current, the greater the risk, especially with smaller sized H0 gauge wheels (as opposed to 1 gauge wheels).
WWW
BLOG
User Profile
View Thanks
linepro
#54
Posted :
11 February 2011 00:27:56(UTC)
Retweet
Its the EU symbol for "Sicherheitstransformator - kurzschlussfest.
Ausgangsspannung bis höchstens 50 Volt" - "Safety transformer - short circuit proof. Output voltage up to a maximum of 50 volts"; two rings in a sheild.
See
Electronic symbols
and match the German text (10th down in the table).
My 60214 doesn't have it [HW Ver 3.6].
The Stummis thread is
CS2: Massetrennung ja/nein bei 60214 und 60215
(also has a picture of a qualifying label).
User Profile
View Thanks
frankie
#55
Posted :
11 February 2011 11:22:25(UTC)
Retweet
.....how or why ?
ESU boosters also have a clear warning stating that the higher power one is for gauge 1 only, because of that.
Alessandro
I have a CS1 Reloaded!
User Profile
View Thanks
jeehring
#56
Posted :
11 February 2011 19:33:45(UTC)
Retweet
.....how or why ?
Yes, but this "higher power booster for garden gauge " from ESU is delivering 8 Amp ....
User Profile
View Thanks
darryl123
#57
Posted :
10 December 2011 08:06:40(UTC)
Retweet
hi
i have found in one of the menus where there is a nenu that says trafo and gives 3 choices of transformers to chose from. i think this is where you will be able to select where the 3 and 5 amp outputs will be selected as there is a choice for 60052 60061 and 60101. can this be the way to switch the output? i have the 60213 cs2 with the latest software update.
the screen is information where the menu is.
User Profile
View Thanks
Posted :
10 December 2011 08:42:00(UTC)
Retweet
I think that's the place. The 60213 should be limited to 3 A, no matter which power supply you select.
For the short circuit detection it probably makes a difference whether you select a transformer (60052) or a switching-mode power supply (60061).
a high level of quality
, the
, and
absolute precision
. You will see that
in all of our products
User Profile
View Thanks
Posted :
10 December 2011 11:10:21(UTC)
Retweet
However, Marklin have since released an engineering bulletin advising that the 5 amp option is for 1 gauge trains only and should not be used for H0 layouts.
WWW
BLOG
User Profile
View Thanks
MFX+ CabMode throttle knob and behaviour after CS2 v3.7.0(7)
Digital
by
05/09/2014 09:53:27(UTC)
CS2 v3.5 (not really) only GFP=2.43 avalable for download
Digital
by
07/01/2014 12:10:49(UTC)
2 Pages
1
2
Go to Page...
General topics
Digital
CS2 v3
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.612 seconds.
