Offline PierreGILLARD
#1 Posted : 26 May 2006 00:55:24(UTC)
PierreGILLARD
I am currently completing my second DPM building and I really like them. Here are some commented pictures :
1) Robert's Dry Goods # 102 :
View of the front façade. Windows are made with Main Stree Graphics Window Kit # 2336. Paints are from Humbrol and Floquil.
Lighting is provided by a transparent yellow 5 mm LED installed in each room of the building. Wiring is made with aviation compliant AWG 22 wires but I would like to change the type of wires for the next building because they are not flexible enough. I think that I will take a black commercial AWG 24 multibraid wire. By the way, this will avoid me to paint the white aviation wires inside the building.
2) B. Moore Catalogue Showroom # 104 :
This is my second DPM building under construction. Windows of the shop are spares left behind of previous Main Street Graphics Window kit.
View of the inside. Note the Evergreen styrene profiles used to reinforce the structure. L shaped profiles are already in place to receive the two floors and roof. Each storey will be then divided in several rooms each of them beeing lighted with a LED. Window blinds were simply painted on transparent sheets.
These kits are very cheap (mostly about US$ 12.00 each) and look very nice when completed. They will find a place on each American layout for sure.
Pierre.
Offline orubias
#2 Posted : 26 May 2006 02:07:42(UTC)
orubias
GREAT
Band on the run
Offline verheyen
#3 Posted : 26 May 2006 02:26:36(UTC)
verheyen
I'll second Pierre's recommendation of DPM kits. They're great, actually to scale, and can easily be adapted for European situations with minimal effort. Most of that work would be in the area of windows and doors which are rather different.
A note of caution though. These kits are not terribly finished or out of the box, semi idiot proof, like FaKiVo. You may have to do quite a bit of work to make sure the edges of the pieces are square and fit well, and in general just to assemble the kits. The kits can really make into anything you want as they are fairly modular. You'll also need to do more painting... They're a great introduction to scratchbuilding.
More info is at <http://www.dpmkits.com/>.
p.
#4 Posted : 26 May 2006 02:54:50(UTC)
PierreGILLARD
I totally agree with Peter's comments on DPM models.
If you need a "how to", I can suggest the following book : http://www.walthers.com/exec/productinfo/400-12258
But to my opinion, I prefer to paint all façades and add all windows prior starting with the building assembly on the contrary of what it is said in that book.
Pierre.
Offline bmcrae
#5 Posted : 26 May 2006 05:28:37(UTC)
bmcrae
Nice work Pierre! [:p]
Offline HueyCE
#6 Posted : 26 May 2006 06:49:10(UTC)
HueyCE
The buildings look very good.
Ira
Offline Steven86
#7 Posted : 26 May 2006 22:13:10(UTC)
Steven86
Very nice. The bricks are very well painted Smile
Offline jonquinn
#8 Posted : 27 May 2006 01:00:53(UTC)
jonquinn
I would also recommend City Classics HO building kits. These are based on actual buildings in the Pittsburgh, PA downtown area.
Offline ulf999
#9 Posted : 27 May 2006 10:27:47(UTC)
ulf999
Great work!
Offline Zora la rousse
#10 Posted : 27 May 2006 14:10:07(UTC)
Zora la rousse
That is a very nice house indeed.
I know several ways to place building on your layout:
1) Plastic kits, like Faller and Kibri.
2) Ready build houses, like Hornby Skaledale.
3) Paper build houses, like Metcalfe or the containers I am building at the moment.
But what is DPM building ?
#11 Posted : 27 May 2006 15:29:59(UTC)
OH ... they are so nice, Pierre SmileSmileSmile ... wish I had the space ...
Offline HueyCE
#12 Posted : 27 May 2006 15:31:47(UTC)
HueyCE
John- Turn them into stilt buiildings.
Ira
#13 Posted : 27 May 2006 15:35:31(UTC)
biggrin Yeah, Ira ... Or we say I got stealth buildings [xx(]. That way I have no work load at all ...
Offline verheyen
#14 Posted : 27 May 2006 16:01:46(UTC)
verheyen
Take a look at the link I posted earlier - <http://www.dpmkits.com/>.
DPM is a brand that makes fairly complete kits and modular sections to build whatever you want out of.
p.
[size=1" face="Verdana" id="quote]quote:Originally posted by Zora la rousse
<br />That is a very nice house indeed.
#15 Posted : 27 May 2006 16:51:04(UTC)
PierreGILLARD
DPM are plastic kits. If you compare them with Faller, Kibri, Vollmer and all other equivalent kits, you will have no other choice than to paint them as they come as four bare plastic façades with a transparent sheet for the windows and a styrene sheet in order to make the roof. You have to add all other details such as roof accessories, lightning, inside by yourself. So, they are really interesting for someone who wants to have a basic quality structure but who also wants to perform some scratchbuilding.
City Classics kits share exactly the same philosophy : http://cityclassics.fwc-host.com/
I also like the DPM modular system, a concept that is now also offered by Walthers. Each time I place an order to my local hobby shop, I include one or two unexpensive DPM modular packs. One day, I will be able then to design and build several buildings of my own. This modular system is very interesting for stores, factories or any other industrial building, for instance.
Pierre.
#16 Posted : 22 December 2006 03:45:30(UTC)
PierreGILLARD
Looking for an idea with DPM modules ? Click here for picture !
And another view of that building.
Pierre.
#17 Posted : 26 December 2006 15:31:15(UTC)
Very nice pictures.
Offline Biased turkey
#18 Posted : 01 January 2007 06:11:14(UTC)
Biased turkey
Nice work Pierre,
I just started to build the DPM "roadkill café" ( in N scale ) 2 days ago.
Your Robert's dry goods building will be an inspiration when it'll be time for me to paint my building.
The only minus point with DPM models is that the windows are not separated items, but are just molded in the same piece as the walls.
Maybe in HO scale it's not such a big inconvenient, but in N scale it is.
#19 Posted : 01 January 2007 20:13:37(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by Biased turkey
<br />Nice work Pierre,
Thanks Jacques.
Please post pictures of your "Roadkill Cafe" when completed ! [:p]
Trimming of window frames are required even on DPM HO buildings. It would be obviously a more delicate operation on N scale models.
Pierre.
Offline hmsfix
#20 Posted : 29 January 2007 19:21:52(UTC)
hmsfix
Got the DPM Kit # 106 "Laube's Linen Mill" today and I'll try to transform it to a railraod station building. Painting the plastic parts will be a lot of fun Smile, and assembly seems to be not difficult at all.
But I have one question: Is there a good method to get this typical brick wall structure: red-brown bricks with white or grey seams ?
Hans Martin
#21 Posted : 30 January 2007 02:26:21(UTC)
Hans Martin: Can't wait to see another one of your masterpieces [:p]
#22 Posted : 30 January 2007 03:20:35(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by hmsfix
<br />Got the DPM Kit # 106 "Laube's Linen Mill" today and I'll try to transform it to a railraod station building. Painting the plastic parts will be a lot of fun Smile, and assembly seems to be not difficult at all.
Hans Martin
I usually start with a coat of Tamiya Primer from a spray-can. Bricks are then painted with Humbrol # 70 or a mix of # 70 and # 33. Mortar is then added by a wash as described here.
You can also find a method of weathering as I used (by chance ...biggrin) on my roundhouse walls.
I hope this could help you anyway even if you are an expert in American buildings and scenery.
Pierre.
Offline hmsfix
#23 Posted : 05 February 2007 23:38:33(UTC)
hmsfix
Finished the assembly of the kit this weekend. Many thanks for your advice, Pierre. Essentially I tried what you have recomended. Only difference is that I mixed the paint from simple water based acrylic wall paints.
Coloring the mortar with a very thin wash of white (or light grey) paint worked very well. Finally, the building got a wash with thin black acrylic paint, so it looks a little aged.
Most work was painting the window frames with dark ocher and brown. This required some extra care, but in total the kit assembly was very easy.
I attached sheets of white japanese paper behind the windows. This is in order to achieve a diffusive light.
Presently I am making some experiments with LEDs. What I am still looking for are big illuminated letters to write "HOTEL" or so on the wall.
Many small details still missing. Eventually Harold Lloyd climbing up the wall biggrin.
Hans Martin
#24 Posted : 06 February 2007 01:44:37(UTC)
Hans,
Have a look here. First step in Locating neon Signs etc
I have seen a selection at our big train show and there is a big range. I have not yet looked for the US Site.
http://www.gwydirvalleymodels.com/
Nev
#25 Posted : 06 February 2007 03:28:21(UTC)
PierreGILLARD
Great work, Hans Martin ! [:0]
You will find various kinds of roof advertising billboards in Walthers' catalogue.
From my side, unfortunately I have not progressed in my LED's experiments. I have worked a little on my roundhouse last week, but that is all. [:(]
Pierre.
Offline jonquinn
#26 Posted : 06 February 2007 15:12:50(UTC)
jonquinn
this is the place for signs
http://www.microstru.com/Animated-signs.html
I have their Las Vegas sign (prebuilt), and the Shell billboard (kit with photo etch). The Shell sign is too big for HO I think - it looks like it would be over 100' tall but is it nice looking.
these are really nice and add a unique touch to your layout - I highly recommend them.
#27 Posted : 06 February 2007 19:49:54(UTC)
Excellent signs,thanks for the link.
Guest (10)
This page was generated in 0.783 seconds.
