Offline mmervine
#1 Posted : 04 September 2011 00:53:12(UTC)
mmervine
Using ESU decoders, is it possible to operate in consist mode on MM or is this a DCC option only?
Offline kbvrod
#2 Posted : 04 September 2011 01:13:02(UTC)
kbvrod
What kind of consist(s) are you thinking about?
Dr D
#3 Posted : 04 September 2011 03:01:14(UTC)
There are 2 options:
My post in ESU forum:
Called Consists = Lokprogrammer
Called Multi = ECoS
Trying to match 2 locos for a consist
Lokprogrammer 4: it is called consists and the maximum number can be entered is 127.
You can alter the lighting function to suit your consists, its programmed and everything works fine.
Put the loco onto the ECoS pragramming track, it recognizes the loco with Railcom plus and it also registers without any trouble, put your second loco on the track and there is a warning this loco address is already taken.
Ok, point taken.
I'm going back to the lokprogrammer and enter the original numbers of the 2 locos (335-336), program it and again no trouble.
Put it onto the ECoS programming track and it will automatically recognize both locos (335 & 336).
This is Ok as well.
Now I like to use the 2 locos in a consist.
Go to multi Loco function and it will register the locos.
Why have 2 different options of programming consists one called consists with the same number under lokprogrammer 4 and a multi consist determining its own number or identification code ?
regards.,
Answer:
Hi John,
the reason for this is simple. ESU produces decoders, that are DCC compatible, so they can be used with other digital controllers. Therefore the decoders can be used in consist mode.
If you use the ECoS, you don't need the consist mode, because ECoS controls multi tractions itself.
For all controllers except ECoS you should use the consist mode, for ECoS you should not use consist mode.
The end result is: yes you can.
If you have a version 4 decoder, turn off the Railcom plus function.(ECoS)
regards.,
Offline mmervine
#4 Posted : 04 September 2011 03:34:44(UTC)
mmervine
Ok, here is what we are trying to do:
One lok with a Loksound 3.5, the other with a Lokpilot 4.0
Control system Marklin 6021
I have the consist address set on the Lokpilot along with a start delay, but it does not seem to work. Any ideas?
#5 Posted : 04 September 2011 04:45:25(UTC)
How did you program the decoders ? with a lokprogrammer ?
regards.,
#6 Posted : 04 September 2011 08:40:03(UTC)
I never tried the consist mode of the ESU decoders, but if you set both decoders to the same MM address, and select that address on your CU 6021, both can be controlled at the same time.
#7 Posted : 04 September 2011 09:16:54(UTC)
Just pick 2 locos go to consist mode , add the 2 locos and the ecos. CS1, Cs2, Cs3 does the rest. No need to adjust anything. hook the locos togethr select the Cossist name in the loco list and away you go
I have had 2 MFX Locos in the consist,
a MFX and a FX,
a FX, and a Lokpilot 3.5
a MFX and a LP
NO hassels, no changing addresses , no programming on a lok programmer.
POP, QED
Nev
PS I Have never tried with a 6021 as I have never owned one. SO this does not help
#8 Posted : 04 September 2011 09:50:13(UTC)
Well, maybe yes (but no in most cases).
A loco without sound starts moving immediately, a loco with sound starts moving after 2 or 3 seconds. ESU LoPis without sound allow you to set a delay to synchronise them with sound decoders.
Speeds, speed curves and acceleration/braking delays should match or wheels will slip (with the risk of losing traction tyres).
Back to topic: ECoS has a consist mode, CU 6021 hasn't.
Offline mmervine
#9 Posted : 04 September 2011 13:02:02(UTC)
mmervine
regards.,
Yes, I have a Lokprogrammer and programmed the decoders. These are for a friend who only has a 6021 based control system. So far, I can not get this to work on the 6021. The Lokprogrammer screen says DCC consist mode which is why I am thinking that it won't work in MM mode (i.e. on a 6021).
Edited by user 04 September 2011 22:40:27(UTC)  | Reason: Not specified
#10 Posted : 04 September 2011 14:55:29(UTC)
You have to select the motorola mode on your lokprogrammer,
As Nev said with an ECoS it is so easy.
What I haven't tried is whether the 2 locos selected as a consist will automatically run at the same speed and as Tom mentioned with a sound decoder there is a delay but not in an ordinary lok pilot decoder unless you program it.
So one day I'll try it and see what happens.
Offline mmervine
#11 Posted : 04 November 2011 18:26:34(UTC)
mmervine
Ok, my friend John Avery figured this out and I used my Lokprogrammer to set the following:
Lokpilot 3.0:
CV 148 set to 4 (This turns 'sound on' in the foward direction for a non sound decoder)
CV 151 set to 4 (This turns 'sound on' in the reverse direction for a non sound decoder)
CV 253 set to 72 (This is the amount of delay. Trial and error resulted in a setting of 72 for a hobby lok)
F1 activates this, so you need to make sure that F1 activates the sound on the second unit with the Loksound decoder.
We ran two BR185's on John's layout after making these changes and they ran perfectly together. One lok with a Loksound 3.5, the other with a Lokpilot 3.0.
thanks 1 user liked this useful post by mmervine
Offline GSRR
#12 Posted : 04 November 2011 19:11:52(UTC)
GSRR
Lokpilot 3.0:
Mark,
Great to see you and John sorted this out. See you at Boomers?
Thomas
Offline NZMarklinist
#13 Posted : 04 November 2011 23:49:41(UTC)
NZMarklinist
Called Multi = ECoS
regards.,
John All,
That suprises me as in CS1-R to create a consist, (and if you want to run them on the same throttle, which is the whole point of consisting on your controller) you simply go to "edit Lok" or tap the spanner symbol and tap "new Consist". Seeing the firmware on my CS1-R is Ecos based I'm suprised they changed the terminology, and more so that you say don't use consist mode. If you have two dissimilar Loks of course you can drive one with each throtle, but that precludes all other train operations Confused
Glen
Auckland NZ
#14 Posted : 04 November 2011 23:56:06(UTC)
That surprises me as in CS1-R to create a consist, (and if you want to run them on the same throttle, which is the whole point of consisting on your controller) you simply go to "edit Lok" or tap the spanner symbol and tap "new Consist".
They changed the name - but this feature does not use the "consist mode" of the decoder (just as they recommend).
Offline mmervine
#15 Posted : 05 November 2011 15:17:33(UTC)
mmervine
Originally Posted by: GSRR Go to Quoted Post
Mark,
Thomas
Yes, I will be there on Sunday!
This page was generated in 0.520 seconds.
