Offline nelson77
#1 Posted : 31 October 2011 15:53:07(UTC)
nelson77
Hello All,
Just bought a new 7294 transfer table while in Germany. When I opened the box back home the transfer part is out of alignment. It does not have a manual in the box. Can someone tell me how to align the transfer unit to the board, or where to download a manual.
Nelson77
Westminster, Md
Offline Markus Schild
#2 Posted : 31 October 2011 17:34:44(UTC)
Markus Schild
Hi Nelson,
The manual can be downloaded from Marklin. Cut and paste the link in a new window:
Code:
http://medienpdb.maerklin.de/product_files/1/pdf/7294_betrieb.pdf
The base-plate has some slots on one end (behind the position of the last rail), which allow to remove or refit the bridge. On this picture, they can be seen on the right side of the plate:
http://johanvoermans.nl/images/uploads/ma7294.jpg
Markus
Offline nelson77
#3 Posted : 31 October 2011 18:17:53(UTC)
nelson77
Thank You Markus,
That helped I down loaded the manual and now have it running. One quick question. Does the transfer table supply power to the tracks that are attached to the table or do I have to run power to each one?
Nelson77
Westminster, Md
#4 Posted : 31 October 2011 18:22:33(UTC)
Markus Schild
Hi Nelson,
the transfer table supplies the track of the bridge-position. No further wiring needed.
Markus
Offline Nielsenr
#5 Posted : 31 October 2011 20:13:13(UTC)
Nielsenr
Nelson,
I can confirm what Markus has said. Whichever track is aligned with the bridge will have power. If you want all tracks to have power, you will have to add power to them.
Robert
Offline nelson77
#6 Posted : 01 November 2011 15:37:15(UTC)
nelson77
Thanks Robert and Markus.
Offline nelson77
#7 Posted : 01 November 2011 16:45:52(UTC)
nelson77
Hello Markus and Robert,
I just checked each leg off the transfer board and I do not have power on any legs when the sled is in front of it. I can run an engine on the sled all the down and back and the light stays on the engines the complete time.
I only have the power connected to one track leading to the board and on the board I have it connected to 'B1 and B0". I am using K track to the board and a couple of K to C transition tracks also. None has power is on any of the tracks when it is in front of it. Any suggestion in what to check for.
Nelson77
Westminster, md
#8 Posted : 01 November 2011 18:00:38(UTC)
Markus Schild
Hi Nelson,
The table was designed for M-track (Series 5100/5200). Today usually the C-track transition 24951 is used. It will not work with K-Track.
Markus
Offline Nielsenr
#9 Posted : 01 November 2011 18:34:23(UTC)
Nielsenr
As Markus has stated, get the 24951 transition tracks. These transition tracks are what I use.
Robert
Offline nelson77
#10 Posted : 02 November 2011 17:04:28(UTC)
nelson77
Thanks Markus and Robert,
Thanks for this forum for anawers for us new guys, It taken two years to get my trains running corectlty. Just finishing up on two more accersoires and than will be able to start the scenery. I would of never though it would of taken so long.
Nelson 77
Westminster, Md
Offline christos563
#11 Posted : 07 August 2014 13:33:29(UTC)
christos563
HI FROM THESSALONIKI, HELLAS.
After the basic line there is a second line on the right side, designed for a distance of 64.65 mm.
In the new transfer tables 72941 this distance may be 64.3 mm,
See if you can connect an old piece 2291 and lay some K tracks.
cherrio and greetings,
Christos563.
This page was generated in 0.315 seconds.
