Offline Hemmerich
#1 Posted : 30 October 2011 22:45:30(UTC)
Hemmerich
This thread has been opened for any discussions about the famous SBB Re10/10 locos.
Offline Armando
#2 Posted : 31 October 2011 02:37:50(UTC)
Armando
I have the 37323 set. Could any one explain what the prototypical headlight arrangement should be?
1) Heading locomotive: "A" (3 headlights on) front, and all off at the rear?
2) Rear locomotive: all off front, and single right lower light at rear?
Thank you and greetings from Houston, TX.
Armando García
#3 Posted : 31 October 2011 05:08:23(UTC)
Armando,
that would be the correct lighting setup. The front lok has the 3 white headlights to light up the route and warn oncoming trains and others while the second lok has the single rear taillight on the lower right to indicate that this is the tail end of the tractive unit. The Re 10/10, composed of a Re 6/6 (Re 620) and a Re 4/4II or Re 4/4III (Re 420 or Re 430) is operated as a single consist with a single driver. As such, the lighting setup reflects the front and back of the consist and not as two separate loks.
Offline Jeremy Palmer
#4 Posted : 31 October 2011 11:30:50(UTC)
Jeremy Palmer
Barbados
Hi Mike,
Do these sometimes operate with a pusher? There must be some amazing strain on the
couplers on these grades?
Jeremy.
Jeremy.
#5 Posted : 31 October 2011 13:31:05(UTC)
Hi Lutz,
Are you looking for pictures of prototype Swiss Electric loco?
Hundreds of pictures found on
http://www.railfaneurope...FF_FFS/electric/pix.html
#6 Posted : 31 October 2011 15:40:49(UTC)
Jeremy/All:
Prior to the introduction of the Re 10/10 as a concept, heavy traction on the Gotthard was performed using multiple Ae 6/6 or by one of the few single Ae 8/14 (a double Ae 4/7). On the Loetschberg/Simplon, this would have been done by one of the famous Ae 8/8s of the BLS or by multiple Ae 4/4. The length of a train that could be pulled by any of these locomotives was dependent on the maximum load that the couplers could support on the particular incline of the route.
In order to increase the number of cars that could be pulled by a single train, it was often common to find a train with one or two Ae 6/6 at the front, an additional Ae 6/6 within the first third of the train and in some cases a "pusher" or "banker" lok at the rear of the train. This enabled the transport of the ever longer and heavier trains and train traffic that the then newly formed common market necessitated through Switzerland on the Gotthard route. The older loks (before 1965) required that a driver be present in each lok. The drivers in the intermediate or pusher loks would be in contact with the lead locomotive via radio. The more modern Re 4/4II, Re 4/4III, Re 6/6 and Re 460 are capable of remote operation and can be directly controlled from the leading locomotive.
A single Re 6/6 can pull a 800 ton (optimal) train up the 26/1000 grade. A combined Re 10/10 can pull a 1200 ton train up the same grade. Adding a pusher or intermediate lok can increase the allowable weight up to over 1600 tons. The use of a pusher or intermediate lok decreases the pressure on the couplings ahead of that lok and allows additional weight to be towed behind that lok. The determining factors are the maximum weight that the locomotive can pull (by locomotive type) and the maximum strain (weight) on the couplings.
#7 Posted : 01 November 2011 20:29:24(UTC)
Just by "accident" I shot a couple of photos of the Re10/10, while my wife and I had dinner at a hotel in Lavorgo at the Gottard line in July 2006.
It was quite dark, so the shutter time was rather long, so the quality is not so good.
Downhill:
Uphill:
#8 Posted : 02 November 2011 14:01:06(UTC)
Jeremy Palmer
Barbados
Here is my Re 10/10 contribution - a photo taken during last summer's "once in a lifetime"
Swiss holiday. I seem to remember Stefan mentioning that it was taken at Liestal.
Jeremy.
Jeremy.
Offline Hemmerich
#9 Posted : 09 November 2011 23:21:54(UTC)
Hemmerich
Not really much need for that since I've many hundreds of own taken pictures for any kinds of Swiss rail stuff - including numerous varieties of Re10/10 compositions (last ones from just a few days ago). BigGrin
Offline bmcrae
#10 Posted : 10 November 2011 17:59:50(UTC)
bmcrae
Envy mode://on Drool
Offline Robert Davies
#11 Posted : 11 November 2011 21:07:22(UTC)
Robert Davies
I have a couple of questions about Re10/10's.
1) When was the concept of the Re10/10 introduced? My last serious spotting trip to Switzerland was in 1990 and I spent most of a day at Erstfeld. Although I saw a lot of freight trains (and by then all the Re4/4's and Re6/6's had been delivered) I did not see a single Re4/4+Re6/6 combination (although I did see a couple of 2xRe4/4). My view is that as an operational concept, it did not appear until the late 1990's or early 2000's, but can someone come up with the proper information? (For those folk who like to do these things properly, this will have an impact on the liveries of the locos.)
2) Are the Re4/4 and the Re6/6 permanently coupled together or is the Re10/10 a loco diagramming arrangement such that any freight Re4/4 can appear with any Re6/6 and they just stay together as if they were one unit until the loco roster takes them back to their home depot?
TIA!
Robert
Era III - IV
Hardware versions 3.6 / 4.33
Software version 4.2.1 (0)
#12 Posted : 12 November 2011 03:22:38(UTC)
TIA!
The Re 10/10 is a unit composed of a coupled Re 6/6 (Re 620) and Re 4/4II (Re 420) or Re 4/4III (Re 430). These units are operated as a single unit and are assigned as such. This means that for the duration of the assignment, the two loks remain coupled together. The Re 10/10 was initially used on the Gotthard beginning in the 1980s. The frequency of these combinations increased over the years.
With the introduction of the Re 460 beginning in 1993, a large number of Re 6/6 and Re 4/4II locomotives were freed up and this allowed the SBB to increase the number of units operated as Re 10/10. This further allowed for the transfer of the Ae 6/6 from most of it's duties on the Gotthard route, which could then take over duties in the flatlands, freeing up even more Re 4/4II. In 1999, the tractive fleet was divided between passenger and cargo divisions. 12 Re 6/6 were assigned to the passenger division. Those Re 6/6 were transferred to the cargo division along with a number of Re 4/4II in exchange for the cargo division's Re 460s in 2003. This resulted in the largest potential number of loks being available for operation as Re 10/10s.
During the period 1984-1995, the SBB loks were modified to include the UIC connectors between the front windows (the little white piece on the front of the 34/37344/34345/37345/37356/29481/29483 Re 4/4II models and the 37321/37322 models). Shortly thereafter, handrails were added to facilitate the access to those connectors. A little earlier, the loks had begun being equipped with new halogen rectangular shaped headlights. It was possible over the years to see quite a variety of combinations in Re 10/10 operation.
The SBB has also used two Re 4/4II to pull some Express trains. Those loks are not operated as a Re 8/8, because at the end of the run, each locomotive goes on to separate duties and a different set may well handle the same operation the next day. The Re 10/10 is not broken up, unless one lok is replaced or both loks are assigned to other duties in a new schedule.
It is possible to see other combinations, say a Re 10/10 plus additional loks. These are not permanent and are separated at the end of the run or when the extra locomotives reach their destination along the way. It is common, for example, in heavier trains, for an intermediate or pusher lok to be detached from the train in Goeschenen as it is no longer needed for the descent on the other side of the tunnel. The lok most likely will return to Erstfeld as a solo, but be attached to a northbound train for additional braking power.
Here is a site with a lot of useful information about SBB and Swiss locomotives (in German):
http://www.lokifahrer.ch/
(Click on Lokomotiven der SBB CFF FFS)
Offline Dreadnought
#13 Posted : 12 November 2011 15:20:15(UTC)
Dreadnought
For some time I have been meaning to thank Mike for his posts. They are always informative. I admire, enjoy, and learn from him. Thank you.
#14 Posted : 12 November 2011 23:03:51(UTC)
Robert Davies
Thanks to Mike C for your reply and all the information in it.
I hope to be in Switzerland in 2012 (although probably only passing through) and my plan is to ride over the Gotthard one more time and see some of these units in action, along with all the more modern traction that now exists.
[My wife wants to visit Rome (neither of us have ever been) and also Venice. The plan is to fly to Rome and spend a few days there but then I have persuaded her to do the return trip by train. (She likes train travel so didn't need much persuasion). We will go Roma - Venezia, spend a day there, then Venezia - Milano - Chiasso - Basel - Paris - London! Sounds fun to me!!]
Robert
Era III - IV
Offline marklinsa
#15 Posted : 14 November 2011 09:08:59(UTC)
marklinsa
Guten Morgen Lutz
Any chance for us to share your photographs? i.o.e - listed somewhere on a website?
Herman Steyn
DRG Epoche 2, SBB & Narrow Gauge
www.herman.rula.co.za
http://www.samodelrailway.hot.co.za/
#16 Posted : 10 March 2012 21:19:37(UTC)
Robert Davies
For those who like these wonderful 'beasts', you may be interested to note that even in 2012 it is still possible to see all-green Re10/10's in service.
This clip https://www.youtube.com/watch?v=UD0JdxaCMEk was taken on 18 February 2012 and you can see the all-green Re10/10 at Erstfeld from 9mins 10 seconds. Unfortunately the light is poor so it is not possible to make out the actual loco numbers.
Robert
Era III - IV
Offline Unholz
#17 Posted : 10 March 2012 22:25:00(UTC)
Unholz
My guess is Re 4/4 II 11330 plus Re 6/6 11663 "Eglisau".
Guest (5)
This page was generated in 0.733 seconds.
