Offline aruncit
#1 Posted : 21 October 2011 22:43:19(UTC)
aruncit
Hi, I recently upgraded my CS2 60215 to the latest version 1.6.4 and tried to set up for ipad app. It does not work. Can anyboby please help?
Offline Fredrik
#2 Posted : 21 October 2011 23:29:14(UTC)
Fredrik
on the CAN-page in the Setup: Is the CAN set to "broadcast" (is normally on "auto")? If not select "broadcast" - also assure the CS2 is assigned a correct IP-address in your routers IP-range.
Fredrik.
WWW: MJ-fjärren
thanks 1 user liked this useful post by Fredrik
Offline aruncit
#3 Posted : 21 October 2011 23:52:02(UTC)
aruncit
Here is what i have
IP Address :192.168.1.6
Subnet Mask: 255.255.255.0
DNS :192.168.1.1
IP Getaway :192.168.1.1
CAN : Broadcast
IP : 192.168.1.1
Offline Fredrik
#4 Posted : 22 October 2011 02:23:49(UTC)
Fredrik
Ok - then try and set the IP below CAN to 192.168.1.255 and see what happens (eventually you must reboot the CS2).
Fredrik.
WWW: MJ-fjärren
thanks 2 users liked this useful post by Fredrik
Offline aruncit
#5 Posted : 22 October 2011 05:41:39(UTC)
aruncit
That did the trick. Thanks a lot
Offline Fredrik
#6 Posted : 22 October 2011 11:54:46(UTC)
Fredrik
You're welcome, glad it helped! BigGrin
Fredrik.
WWW: MJ-fjärren
#7 Posted : 24 October 2011 21:03:33(UTC)
Hi and Welcome to the forum.
Offline iTrainx
#8 Posted : 24 October 2011 23:37:24(UTC)
iTrainx
I am struggeling with my CS2...it will not remember the subnet mask 255.255.255.0 it basicaly change it back to 255.0.0.0 every time i restart.
I am good with networks and routers...but are getting furious about this.
i am on sw version 1.5.2
any ideas?
Train on
Petter
"I am about to pick up my childhood hobby again because of the Marklin Mobile Station App on iPhone...;-)"
Offline iTrainx
#9 Posted : 25 October 2011 18:58:41(UTC)
iTrainx
any ideas?
Fixed ; Ipad and Iphone connects without any problems now...
I had to upgrade to CS2 version 1.6.4 with USB since it never got to internet without subnet 255.255.255.0.
After upgrade this is fixed and it remembers the subnet mask.
Only those with 10.0.0.1 routers had this problem...
I am so glad we have Microsoft...life with Linux would be very geeky ;-)
Train on
Petter
Offline Alfredo
#10 Posted : 10 August 2014 14:50:42(UTC)
Alfredo
Hi all, I AM new in this forum, not a new Marklin user though. I've been unsuccesfully trying to connect my CS2 TO the iPad Marklin app. I've gone through most (or all) tips round in internet and still cannot connect both devices. Have tried the tips you guys mention above also no success.
This is what I have:
On my IPad:
IP AD: 192.168.1.35
SUBNET MASK: 255.255.255.0
ROUTER: 192.168.1.1
DNS: 80.58.61.250, 80.58.61.254
On the CS2:
IP adresse: 192.168.1.35
IP- netzmaske: 255.255.255.0
IP-gateway: 192.168.1.1
DNS server: 80.58.61.250
And then set TO "auto"
On the CAN menu, the number is 192.168.1.255 and I've tried to connect both with "broadcast" and "auto"
So, the que questions are:
1.- on CS2, do DNS SERVER and IP-GATEWAY ende TO be the same? I've got some instructions saying so and some not saying anything (I've tried both posibilities nome of then working). Also i have tried with the other DNS number (the one ending in 254) and doesnt working
2.- any ideas? CS2 has been succesfully updated TO the last version and also has my iPad.
Thanks for your help, I AM lost.
Alfredo
Offline Alberto Pedrini
#11 Posted : 10 August 2014 15:31:31(UTC)
Alberto Pedrini
Hi Alfredo,
you have the same ip adress in two devices, that is the same to compone your telephone number in your telephone.
I suggest to set a fix ip address in the CS2 192.168.1.100, so the router have the address from 1 to 99 free for a lot of devices.
Alberto
Marklinfan Club Italia
www.marklinfan.net
thanks 1 user liked this useful post by Alberto Pedrini
#12 Posted : 10 August 2014 15:35:55(UTC)
Alberto Pedrini
Another thing to all have problems, unplug the dsl cable from the router when you run the apps, it happen that the iPop pad phone and other, when see the line open make a lot of hidden operation that can slow or block the system Crying
Alberto
www.marklinfan.net
This page was generated in 0.471 seconds.
