<font face="Arial]</font id="Arial] My new TRIX 22026 steam loco is equiped with a 21-pin connector for decoder . The manufacturer sugests TRIX 66839 decoder . As I have a few of Uhlenbrock 76420 multiprotocol multifuncion decoders , I like to install one of them. The problem is that I don't know which function ( motor ,front-rear lights, smoke generator etc )of the loco is connected with each pin of loco connector. Maybe the manual of 66839 has some info. Is this connector a standar ,meaning that any manufacturer who use it , connect the same function to the same pin ? Any help ? Dimitris
Joined: 16/02/2004(UTC) Posts: 15,463 Location: DE-NW
AFAIK this is a M*/ESU standard. You can buy ESU decoders with 21-pin plug - they should be compatible. |
Joined: 20/04/2003(UTC) Posts: 2,248 Location: Amsterdam, Netherlands; Göteborg, Sverige,
Hi all, This information is taken directly from another topic in this forum on the 21-pin connector: Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by Hemmerich<br /> Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by jeehring Lutz, do you know pins attribution of the 21 pins connector? Is there a website to find a description with the mapping of the Pins?
I have read that pins 6 & 7 are for loudspeaker, what about the other pins?
Thank you in advance
See here:  Opposed to some other sources, the pin descriptions and numbering scheme here is in conformance with the NMRA/MOROP definition proposal (in German only; if you need it in English let me know). The loudspeaker output is at pins 9 and 10. Another source, using the same definition scheme can be found here: http://www.ad-soft.ch/moba/_mai.../decoder/mtc_buchse.html |
Sander
--- Era I(b): K.Bay.Sts.B. and K.W.St.E. |
<font face="Arial]</font id="Arial]  Thanks all. I'm much obliged for the immeditly response to my question. I have solved my problem 90%. Anyway , I still wonder on which pin is the smoke generator of the loco connected. Dimitris
Joined: 21/10/2004(UTC) Posts: 31,697 Location: United Kingdom
Welcome to the forum polifimos.
Joined: 12/01/2003(UTC) Posts: 2,528 Location: Groton, Connecticut
I would be willing to bet the smoke generator operates off of pins 4 & 19. Welcome to the forum Dimitris. Ira |
Building German Era I-II layout(Mk IIIc).  |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE <br />I would be willing to bet the smoke generator operates off of pins 4 & 19.
I don't think so, usually the smoke generator is connected to AUX 1, here pin 15. The "ground" usually comes from the metall loco body. If not, pin 16 (orange) can be used as "ground." |
Sander
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by Sander van Wijk<br /> Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE <br />I would be willing to bet the smoke generator operates off of pins 4 & 19.
I don't think so, usually the smoke generator is connected to AUX 1, here pin 15. The "ground" usually comes from the metall loco body. If not, pin 16 (orange) can be used as "ground." Don't know what I was thinking[|)], thanks for the correction.[:I] Ira |
<font face="Arial]</font id="Arial]  Hallo all, Pin 15 is smoke function FOR SURE. After using a multimeter tester and with help of the more detail info from the site ( only German ) http://www.ad-soft.ch............. , that Sander van Wijk suggested, All pin-function-cable color of the connector in the tender FOR TRIX 22026 steam loco are clear now. Pin 21 -left wheels power pickup, brown cable loco and tender ( connected also to loco+tender body). Pin 22 -right wheels power pickup, red cable from loco wheels and black cable from tender wheels both connected to a big (1 Watt ?) resistor that goes to pin 22. Pins 18 - 19 motor ,blue - green cables. Pin 7 - rear lights, yellow cable Pin 8 front lights, yellow cable also. Pin 16 - front and rear light common , gray from front lights and orange from rear lights. Pin 15 - smoke generator (Seuth Nr 24) , black cable. The body of it is grounded to the chassis-body of loco. All the above ( cable color especially) are as checked in the TRIX 22026 steam loco and I don't know if it is the same in all Trix locos equipped with 21-pin connector. Now I can install my Uhlenbrock 76420 decoder. You will be informed as soon as the test of loco. Friendly regards and thanks to all again. Dimitris
I would like to make a little adapter pcb with a 21 pole header on it. Does anyone have mechanical dimensions/order code/manufacturer for the header?
Bert
[8)] Hallo Bert, With Header you mean the pins side or the holes side of the connector ? I'll try to messure mine as acurate as possible and send you the dimenions. The only dificult part is the distance between the pins or centers of holes. It's to small. Anyway I'll ask this days in my lokal market for such connectors and if I'll find something i'll inform you. Dimitris
I mean the pins. I will need to order the pins themselves so I definately need a real datasheet and manufacturer.
Thanks for the offer though.
Bert
You have been a member since:: 25/09/2003(UTC) Posts: 2,786 Location: ,
I must say 21 pins connector is becoming a standard. There is a roco 21 pins decoder. There is also a Uhlenbrock 21 pins decoder .ESU decoder of course! Kuehn or TAMS has also announced a 21 pins decoder( don't remember which one of those manufacturers)
Liliput has announced next Loks will be implemented with 21 pins connector...
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by jeehring 21 pins connector is becoming a standard.
Do you know any 'official' documents where that standard is described? It would be nice if I could order the pins for it and make my own adapter pcb to plug the decoders on. If I find the info I will share the pcb here somewhere. Bert
Never mind,
I found the info I needed. The pitch of the pins is 50 mil or 1.27mm. It is a standard and easily available.
Bert
I wonder if Lenz shall following after same system by starting producing 21 pol decoder,that there will been equipped with ABC,USP and Railcom system...?  Goofy  |
H0 DCC = Digital Command Control
Kind regards, Guus |
My mtc-21 PCBs just arrived, I will post a picture of them later on when I have assembled the connectors.
Bert
Hi all, Here are some pictures of the PCB I made. A lokpilot V3 is next to the PCB for reference. Top:  As you can see, the board accepts mtc21 boards as well as the old NEM652 plugs (not assembled here) Side:  Bottom:  The ICs you see here are meant to amplify the AUX3 and AUX4 functions and to make AUX1 direction dependant with the lights output. Perspective:  Bert
Joined: 22/04/2004(UTC) Posts: 12,139 Location: New York, NY
I hope no one visits a poor Southener's layout in Brooklyn. Intruders beware of Gators. AT&SF, D&RGW, T&P, SP, WP, UP, BN, NYC, ARR, epI-III - analog & digital Marklin Classics only. CU#6021 FX-MOTOROLA DIGITAL SYSTEM. Fast as lightning and no trouble. What else ... Outlaw Member of BIG JUHAN's OUTSIDER CLUB. With the most members, worldwide
Hi Bert, I second that  Is the 21 pin plug available in elctronic shops? BTW: I ordered a 21pin adapter at HAG.It's a simple circuitboard with a 21 pin plug and 9 wires. Yours looks far more sophisticated! Kind regards Guus |
Joined: 10/02/2004(UTC) Posts: 2,162 Location: Portugal
Ah! Are you going to sell these? Because if you do, I will get two for now, and definitely more in the future. Of course, price is a factor  ! Anyway, can you elaborate on its features: 1 - Is AUX1 always direction dependent, or can one bypass that? 2 - What's the current rating for AUX3 and AUX4, after amplification? 3 - Considering there are next to none decoders with AUX3 and AUX4 in the market and absolutely none with 21-pole plug AND AUX3/AUX4, can one reroute AUX1 and AUX2 to the amplifier circuits instead? That would be of more practical use now. BTW, if the price is right, maybe even some dealers will carry your product.... Luis
Great job, Bert! Worthwhile to make it available as a Marklin-users.net exclusive outsider product   I would be willing to order quite a few. |
*Bart |
Quote:[size=1" face="Verdana" id="quote]quote: Originally posted by laalves<br />Ah! Are you going to sell these? Because if you do, I will get two for now, and definitely more in the future. Of course, price is a factor  ! The idea was to keep some for my own use and that of a collegue who collaborated in this project (30), and sell the rest to a local dealer (70). I cannot give an exact price because we don't know yet how much we will charge the dealer (and how much he will then charge his customers). I can tell you however that the PCB is not the big cost, but the components are, especially the 21 pin connector is relatively expensive. Maybe after this batch is sold (and tested!) I will make a new one, exclusively for users of this site. I can also reverse the question: how much would you be willing to pay for a PCB like this, and should all necessary components for assembly be included? There is also a (small) downside on this PCB, you need to have some good soldering skills/equipement before attempting to assemble it. It has some 0603 parts and for the ICs some flux is nice. Quote:[size=1" face="Verdana" id="quote]quote: 1 - Is AUX1 always direction dependent, or can one bypass that?
You can bypass that by soldering 0R resistors on the right places. Quote:[size=1" face="Verdana" id="quote]quote: 2 - What's the current rating for AUX3 and AUX4, after amplification?
Uhm... plenty  . I think it depends more on the total power the decoder is able to deliver than on the functions themselves. The mosfets used can deliver up to 2.4Amps continuous power. Quote:[size=1" face="Verdana" id="quote]quote: 3 - Considering there are next to none decoders with AUX3 and AUX4 in the market and absolutely none with 21-pole plug AND AUX3/AUX4, can one reroute AUX1 and AUX2 to the amplifier circuits instead? That would be of more practical use now.
This adapter is tailored for ESU type decoders. In my experience they have already an amplified AUX1 and AUX2 onboard, and just TTL logic outputs for AUX3 and AUX4. Thus it makes no sense I think to amplify AUX1/2. You can bypass amplification of the AUX3/4 in case new decoders come out that have 4 fully functional AUX outputs. With function mapping you should also be able to switch AUX3/4 with F1/2 if you like. Bert
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by Guus
Is the 21 pin plug available in electronic shops?
I ordered it through my employer at digikey. It is a Samtec header. I would have to look up the exact ordering code but I think I already posted it in another topic somewhere here. If you find a cheaper alternative, please let me know. (be carefull, you need the 'high' type and not the more common lower type) Bert
Thank you Bert. Quote:[size=1" face="Verdana" id="quote]quote:...I can also reverse the question: how much would you be willing to pay for a PCB like this, and should all necessary components for assembly be included?
To give you some reference,the HAG board costs 21CHF aprox. 14Euros. Kind regards Guus |
Once again very impressive, Bert. Thanks  Kind regards Guus |
Now I get it. You mean that with your PCB one actually is able to use AUX3 and AUX4 from a normal Lokpilot with 21 pole plug. Now that's nice! That's a nice set of features. I think you should establish two prices: one assembled, one disassembled. Say 15€/20€? Luis
I used the pcb from the V160 (AUX1, AUX2, no additional amplifiers) for €4.81, and the one from the BR03 (AUX1, AUX2, additional AUX4 amplifier) as Lutz mentioned, for €7.06 Thanks for suggesting #611868, Lutz! |
*Bart |
Lutz, Could you share that info with us? I had started a similar thing was already at.... 6 different references! A bit far off 44 references  . Luis
*Bart |
Thanks all for the insight  With my PCB I tried to do something more than just have an 21 pole connection so it does not really compare directly to the marklin PCBs I think. Expecially the old NEM socket caused some headaches as the pinning is completely different from 21 pole one. This all had to fit on a small PCB (16mm*25mm, much smaller than those of marklin) and routable on just 2 layers to keep costs down. I also had to obey certain designrules for the PCB to have it manufactured on a cheap process. There are also some drawbacks to this PCB. There is space to solder the inductors for the motor, but those only fit well if you use the nem652 socket. The PCB itself is 1.6mm thick, which is too much for such a small pcb, but one has to keep costs down. It can very well be that I will give the people on this forum the opportunity to buy some of these PCBs, not assembled but with components, as they might be too complex (small) to sell to a dealer. Ofcourse I have to test the PCB fully first myself, which I haven't done yet. I will let you know if that happens. Bert
Very nice Bert! Congratulations! BTW, I have read somewhere that the 21 connector is already existing in industry . IT's the reason why ESU&Marklin have choosen it. As a current connector it was cheaper for them,instead of developping a new one.
Thank you.
I haven't been able to test all functionality of the pcb yet. For some reason my dealer has sold me a lokpilot mfx instead of a lokpilot v3, and I don't know how to program the functions an mfx decoder with my ecos. The PCB looks nice though in the tender of my BR55 from piko (old loc converted to AC). Will post some pictures later.
Bert
Joined: 16/10/2001(UTC) Posts: 793 Location: Pittsburgh,
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by DasBert33 <br />
Bert
I would like to upgrade some of my locos (mainly DC conversion wity NEM 652 pin) to the lokPilot mfx. Any experience? Would it be easy to program/control with the CS? My intention is to leave rarely used locos on the lokPilot 3.0 that I have and only upgrade the heavy usage ones. I am exceeding the 80 addresses any way so I should only look at mfx from now on. Thanks |
Joined: 30/01/2006(UTC) Posts: 1,894 Location: Keene, NH
Bert:
I am curious as to how the final testing has gone and if this is now available for sale?
Thanks!
r/mark |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by mmervine <br />Bert:
Thanks!
r/mark
Hi Mark, I actually missed your question before. Well it works  . Final testing is OK, I use the PCBs in a lot of locos now (mostly with lokpilot 3.0s, 2 with loksounds). Downside is that it takes some space (pcb should be 0.8mm thick in place of 1.6mm), and the inductor placement is not possible in combination with mtc21 decoders. I also discovered that only lokpilots have 4 aux function outputs, that you can amplify with my PCB. Loksounds have just 2. I can sell a few to assemble/solder yourself, but you need to have the correct tools to do that. Bert
