Offline marklinologos
#1 Posted : 06 October 2011 11:27:30(UTC)
marklinologos
I have an cs1 with esu reloaded software last version 4.3.2
I connect marklin s88 and in set up menu of s88 looks to work normal (the boxes going black when i trigger the contact track 24994 ).
The problem start when I plan an route and connect it in menu with one contact, the train pass and nothing activated. When I come back to route menu in s88 and port position write "no module selected" like I never select a contact from s88.
I cannot understand why cancel my selection of s88 port.Cursing
Thanking in advance for your help.
Keep Marklin away from China
Offline supermoee
#2 Posted : 06 October 2011 11:37:16(UTC)
supermoee
if I remember correctly somewhere in the setup of the CS1 you have to define how much s88 modules you have physically connected to the CS. If you do not do this, you cannot assign a port to a route, since for the CS1 there is no S88 module.
This was on the Märklin version. On the ESU reloaded I do not know.
rgds
Stephan
#3 Posted : 06 October 2011 11:48:29(UTC)
marklinologos
I have allready actvate the s88 module from cs menu and there is the boxes which I can check if works normal. In s88 menu looks ok, the problem is that do not activate the route and in route menu I choose s88 module and port but is like not save my choice and when I come back to route menu write "no module selected"
Offline supermoee
#4 Posted : 06 October 2011 11:54:06(UTC)
supermoee
ok, than maybe the memory of your CS1 is full?
have you checked in the ESU forum if someone had similar problems?
You can ask for a solution there.
The ESU community is very closed, since ESU do not want that problems becomes known on a larger scale. They prefer to discuss in a closer group
rgds
Stephan
#5 Posted : 06 October 2011 12:54:27(UTC)
marklinologos
I am not use so many items to reach the limit of memory (12 turnouts - 4 signals - 4 routes - 1 shuttle train route
). I have allready ask in ESU forum and I am waiting for reply. Hope to work finally...Confused I have started with turnouts and viessmann signals but I have problems with marklin signals programming and routes activation by s88 contacts...... Hope to find a solution because otherwise I have to change all the wiring of layout...Crying
#6 Posted : 06 October 2011 19:36:45(UTC)
marklinologos
Is it good idea to go back to previous software version...??? I am thinking that is my last chance to work the signal and routes..Confused
I can t think any other solution..but I don t believe that this is the problem...Blushing
This page was generated in 0.369 seconds.
