Offline Ian555
#1 Posted : 27 September 2011 13:11:29(UTC)
Ian555
Looking for a bit help in registering Set 26830 on the Central Station.
I just typed in 26830 and this registered the snowplough section and all the functions work ok, but nothing from the Loco BR52 3321....do I need to register it seperately, I did try that, but that just takes me back to Set 26830.
I've not yet opened the Loco to see if it is set at 69, thought I'd see first if any members can point me in the right direction.
Thanks.
Ian.
#2 Posted : 27 September 2011 13:53:23(UTC)
Hi, Ian,
Is there an entry like 26830a in the database? If so, try this.
Offline Ian555
#3 Posted : 27 September 2011 14:50:04(UTC)
Ian555
Hi Tom,
Can't say I noticed that, but I'll go and have another look.
Thanks for your help. ThumpUp
Ian.
Offline Hemmerich
#4 Posted : 27 September 2011 16:52:20(UTC)
Hemmerich
You won't see anything like mentioned above - but lots of "b" entries. BigGrin
For the loco just take the/a known or suitable alternative.
Offline Ian555
#5 Posted : 27 September 2011 17:36:24(UTC)
Ian555
Well I've got it all set up and working Ok. Smile ThumpUp
This is how I did it....
From database...set 26830...address code 69, and then manual address code 68 for BR52 3321.
It does mean that I have to select them seperately on the CS2, maybe that's how it should be done.Smile
Thanks again Tom, it was your idea that prompted me to try and load them seperately.
Ian.
Offline Hemmerich
#6 Posted : 28 September 2011 00:18:07(UTC)
Hemmerich
Quite weird approach. It's much easier to simply select a model from the loco DB with the same functions as supplied with this BR52.
This page was generated in 0.438 seconds.
