#1 Posted : 21 August 2011 17:07:32(UTC)
I had an announcement: template for sound slots is available for download.
I din't take much notice of it in the first place but now the loco I'm converting for a client
has awoken me to this addition.
What it is all about, your sound decoder can be extended with sound slots, such as Station announcement or any other additional sound which is not present in your selected loco.
for instance the DB BR 18 has 9 sound slots and I've just extended it to 18.
The process is really easy, all you have to do is download your BR 18 sound file go under sound (providing you've downloaded your templates for extra sounds) select on the right hand side window which function you like to add,select the sound slot on your right handside and click the arrow on your right hand side window, this will automatically add the additional sound so your sound slots. go to write sound decoder and the sound files will be down loaded via your lok programmer with your loco on the connected track.
When the download is finished, select decoder, go to Function mapping and you will see under the section @Sound@ your additional sound slots have been added.
All you have to do is activate the sound slots for each function by clicking the field window and again clicking the sound slot in the same line as the function number.
Isn't it great, your own selections of sound slots and this doesn't restrict you to German locos only it has a wider application for other countries as well.
regards.,
Offline jeehring
#2 Posted : 21 August 2011 19:05:41(UTC)
jeehring
Sure, it looks great, I just wonder what is downloading a "template".
For this service the user has to buy a Lok programmer.
Offline ricky
#3 Posted : 21 August 2011 21:14:39(UTC)
ricky
Hi John,
that's great! Could you please post a video of the whole operation, or maybe more detailed instructions?
Thanks!
Ricky Smile
Offline GSRR
#4 Posted : 22 August 2011 03:45:11(UTC)
GSRR
Views messages in topic : 1,339
Thanks John, nice discovery. Is it possible to add sound files not in the ESU database? For example if you wanted to add an Austrian station announcement to your OBB lok?
r/Thomas
#5 Posted : 22 August 2011 03:45:31(UTC)
For whatever reason ESU produced a lok programmer, I couldn't be without one and to be honest I had my money worth of programming done with it.
As you most probably know, I have an ECoS as well but don't use it for programming at all except downloading my own loco pictures or any updates.
The template itself is an addition of sounds you can add to your existing sound file, e.g. DB BR 18 has 8 different sound files with the template I have been able to increase it to 18, furthermore you can personalize the soundslots to your liking, e.g. German station announcements (5) and there are others available in other languages, conductor whistle, curve squealing, track sounds and many more.
It is not for modelers who buy a loco off the shelf and leave it on the shelf or for a modeler who buys it and is satisfied the sound slots it provides.
A lokprogrammer is more than just being able to download an extra template for sound slots.
It is a tool for modellers who like to have an extensive option of programming a decoder including the Lenz railcom plus addition, dimmable lights, smart fire box light, the brightness of lights, the functionality of lights with a consist of locos, switchable headlightsfrom low to high and visa versa, all of these CV's can be changed via a lokprogrammer or you use your command station and try to do it and this is not an option for me, trying to figure out the bits, multiplying it by 4 or 8 or 16, adding it up and the mathematical nightmare goes on and on, I gave up in the end.
I'm a member of the ESU ECoS forum, although they have a good team of expert who can help you with problems and this particular member took time out to explain to me including a chart, which he had developed to program a long address, I just didnt get it, the lokprogrammer did it for me automatically.
Now e have Lenz railcom plus and the decoder is automatically recognized by the ECoS, again it does it for you.
So this is my 2 cents why I prefer to own a lokprogrammer.
regards.,
#6 Posted : 22 August 2011 04:06:10(UTC)
r/Thomas
Yes you can, In my previous post I've mentioned 5 different German Station Announcements but it also has it for Austrian Stations and other languages.
The template itself, looking at it while I was downloading some individual sound slots, to me it looks like all the sound slots are available ESU has ever produced or has added to a specific loco, I think I can say with confidence it is a type of database for all sound slots.
The question can arise, how come ESU hasn't included these sound slots in a loco in the first place or will it be from now on any new sound file will incorporate more sound slots, e.g. curve squealing and the track sound for instance, it may also had something to do with sound file capacity from earlier sound decoders.
To give you an example:
Locomotive motors from Australia, Belgium, France, Germany, Switzerland and USA.
Station Announcements from Austria, Belgium, France, Germany, Spain and Switzerland
Air pumps: from a BR 01, BR 03, BR 64 or BR 99, US diverse airpumps or for heavy steamers,
Air horns from the USA: 30 different air horns for different locos.
and list goes on.
Others may know if there is the possibility to download these sound slots into a different loco sound decoder other than ESU.
I hope this helps,
regards.,
#7 Posted : 22 August 2011 04:08:00(UTC)
Originally Posted by: ricky Go to Quoted Post
Hi John,
Thanks!
Ricky Smile
Ricky,
What digital command station have you got ?
regards.,
Offline GSRR
#8 Posted : 22 August 2011 04:18:22(UTC)
GSRR
What I'm wondering can I create my own custom sound file, not from the ESU database, and then use the lokprogrammer to load said custom file into an ESU sound decoder?
#9 Posted : 22 August 2011 04:37:59(UTC)
Thomas,
This I do not know, I can cope with basic tasks so long they are in front of me or guide me to it.
I've come a long way to be able to operate a computer as I had no formal training but as I said before with all the bits and pieces the computer or digital world talks about it, my mind goes blank.
On the surface I would say no, the reason for it, ESU most probably likes to protect their own programs so a data base link from another source may be asking too much but you never know, I'm not the person who has such expertise.
regards.,
Offline Chris6382chris
#10 Posted : 22 August 2011 05:21:02(UTC)
Chris6382chris
John, is there a website that has all this info and can anyone view it or do you have to buy the loksound sound decoder first? Also I just want to be clear, you can do the programming with the Ecos 2 correct?
Offline jeehring
#11 Posted : 22 August 2011 11:00:01(UTC)
jeehring
...yes you can.
You can do it only with Loksound decoders. Not with that special range of ESU sound decoders....I don't remember the name presently...
...More specially you need to be experienced in computing and in the handling of sound files with your PC.
First you have to register your own sound and to put it as a digital sound file in your PC through the correct protocole of course !
For instance : I know that some train-spotters have registered themselves the sound of some french railcars at different places...(station, when starting or arriving, in the open countryside, on loops in both directions up & down, etc, etc ...).
Those railcars were made as a model from Electrotren without digital equipment.
There are few dealers selling this service : they know how to implement their own sound files on a Locksound decoder, then they install it on the railcar model, so you can get this railcar model with sound for a certain price + with a sound that doesn't exist in ESU database...
The Lokprogrammer itself is quite an old stuff....Began years 2000 it was existing already....they have made it available at the same time as the sound decoders.
In the beginning it didn't work very well.People often had to wait next software version release, it was not always easy to get a connection with ESU database....... Today I'm not experienced myself, I think (& I hope) that they have improved the whole system , it seems to work. As John really tested it, he can confirm...
theory and practise ..
#12 Posted : 22 August 2011 11:37:35(UTC)
Chris,
As I said I'm not that great programming it with the ECoS but there is no reasons why you shouldn't.
You have all the tools to do it but for me to work out all the bits and CV's, multiply it and dividing it and subtracting it and adding it, is a nightmare for me.
The ECoS can do all this with your help of understanding the digital world of "bits"
Sofar Loksound decoders are concerned, yes you would have to buy them to get all the information or you would have to ask someone who has the instruction booklet in English.
I'm not sure if they've publsihed the Version 4 in English.
ou can see all the information about ESU on their website: http://www.esu.eu/
I hope this helps.
regards.,
#13 Posted : 22 August 2011 11:42:51(UTC)
...yes you can.
I must have been one of the first buyers of the lokprogrammer and I never had any problems with it, so mine is the first version they've bought out.
Again I can''t tell whether or not, for no reasons at all, some of my earlier loksound decoders stopped working when trying to update them but received new ones for an exchange of the faulty ones.
regards.,
This page was generated in 0.642 seconds.
