Joined: 29/06/2011(UTC) Posts: 129 Location: Hanoi - VietNam
I want to know the difference between the central station 60213, 60214, 60215? thank
Joined: 16/02/2004(UTC) Posts: 15,466 Location: DE-NW
All 60215 and late 60214 have galvanic insulation (like the new 60174 booster). All 60213 and early 60214 have no galvanic insulation (like the 60173 booster). One device without galvanic insulation can be used without problems.
It seems that early 60213 had different throttles and switches (for function keys).
Track output is 2.4 A for 60213/4 (3 A possible with a trick) and 5 A for 60215.
They all use the same software and have the same software features. |
Joined: 03/06/2008(UTC) Posts: 1,256 Location: Sydney, NSW
Originally Posted by: H0  Track output is 2.4 A for 60213/4 (3 A possible with a trick) and 5 A for 60215.
Hi Tom, thanks for the detail response (as usual)  , however, can you tell us the trick to produce 3 A on the 60214? Regards Greg |
Originally Posted by: youngagain  however, can you tell us the trick to produce 3 A on the 60214? Connect programming track and main track in parallel (this is described in the CS2 on-line help, but M* recommend this for I gauge only; install a switch so you can use the programming track when you need it). |
Originally Posted by: H0  Originally Posted by: youngagain  however, can you tell us the trick to produce 3 A on the 60214? Connect programming track and main track in parallel (this is described in the CS2 on-line help, but M* recommend this for I gauge only; install a switch so you can use the programming track when you need it). Just so that I understand you correctly Tom. I take the red wire from the programming track and connect it to the red wire for the layout - the same for the brown wire. Now how do I connect the programming track with a switch? I told you before that I was dumb. . . . Regards Greg |
Hello, the latest 60214 with galvanic insulation will go for 5A too. Hardware version 4.33 rgds Stephan
