Offline jonas_sthlm
#1 Posted : 25 May 2011 20:30:07(UTC)
jonas_sthlm
It must be a way to reset this device because I will go crazy soon Cursing
Once it has burn up and now it doesn’t save the settings when shutdown or restart.
Offline supermoee
#2 Posted : 26 May 2011 11:09:11(UTC)
supermoee
just go under restore a backup and choose reset.tgz as restore file.
rgds
Stephan
#3 Posted : 26 May 2011 11:17:33(UTC)
I do not have a CS2 but the Cs1 Ecos and MS1 had a configuration setting to restore to Factory defaults. Should that also be in the CS2????????
NN
Offline jonas_sthlm
#4 Posted : 26 May 2011 11:33:56(UTC)
jonas_sthlm
Originally Posted by: supermoee Go to Quoted Post
reset.tgz
I did try that, and it reset device and get back standard layouts and four locomotives, if I then remove all four locomotive shutdown or restart the locomotive is back again.
restore to Factory
CS2 doesn’t have a button to restore like the previse CS1
I live on the fourth floor so it can quickly fly out of the window soon Mad
#5 Posted : 26 May 2011 11:52:07(UTC)
reset.tgz
restore to Factory
I think you , unfortunately have a faulty CS2. Back to dealer and get replaced or repaired my M. It is the only way.Love
Nev
Offline Coola_Daffy
#6 Posted : 26 May 2011 11:55:14(UTC)
Coola_Daffy
Give FV Elektro AB in Forserum (a SE dealer) -a call. I've learned that they are skilled in such matters.
Google is your friend for phone nr.
Best of luck.
Offline supermoee
#7 Posted : 26 May 2011 11:58:26(UTC)
supermoee
do you save the loc deletion through the blue arrow button?
rgds
Stephan
Offline jonas_sthlm
#8 Posted : 26 May 2011 12:08:32(UTC)
jonas_sthlm
blue arrow button?
I don’t see any blue arrow under locomotive configuration Confused
The arrow is only shows up under setup or layout memory.....
Offline supermoee
#9 Posted : 27 May 2011 12:00:24(UTC)
supermoee
you told about deleting locs. Locs cannot be deleted in the loc configuration screen, but in the loco selection screen.
But I think there is no blue arrow neither. Have to check on my CS this evening
rgds
Stephan
Offline jonas_sthlm
#10 Posted : 27 May 2011 17:41:40(UTC)
jonas_sthlm
Two days with no response from M service Crying
This page was generated in 0.418 seconds.
