Offline salem
#1 Posted : 10 April 2011 15:04:14(UTC)
salem
I got today an old set of Marklin (analogue HO format) and like to use Arduino to control it like forward, backward, speed? Any ideas? Thnx a lot
saw this in youtube and wonder how he did it! the one in the video is analogue, right?
salem attached the following image(s):
Offline tiono
#2 Posted : 11 April 2011 02:26:50(UTC)
tiono
The video on youtube showing Marklin Z, which is using DC analogue. While Marklin HO 3-rail is using AC (and drawing higher current than Z-scale). If your Marklin HO is the old 2-rail DC, then you may be able to control using Arduino easily by connecting its PWM output to a power transistor as switch, plus a capacitor to smoothen the voltage.
But if your Marklin HO is 3-rail AC, then it will be complicated since you have to generate 50/60Hz AC voltage to drive the train.
thanks 1 user liked this useful post by tiono
#3 Posted : 11 April 2011 16:52:03(UTC)
That depends on the loco. The old stuff with mechanical reverse units (MRU) has AC/DC motors that will run fine on AC or DC (even with PWM).
Reversing voltage will be a problem. MRU can be replaced by two diodes for DC operation.
Many decoders won't support DC PWM operation. But a typical "old analogue set" has no decoders.
Offline salem
#4 Posted : 12 April 2011 19:15:12(UTC)
salem
I have updated the message with a couple of pictures. So I think it is a 3--rail analogue system. The Transformer indicates that AC alternative to be used only!
Offline salem
#5 Posted : 12 April 2011 19:41:19(UTC)
salem
I was advised to use a MOSFET to make this happen but need to see a circuit so I don't burn anything!
Was looking at this circuit ..
MOSFET Circuit with Arduino
Also read that The AC 3-rail would also work with DC ( from Battery or Arduin PWM ), Is this true.
Thanks for your participation in this discussion
Offline tiono
#6 Posted : 13 April 2011 01:29:12(UTC)
tiono
You have to test whether your locomotive really can work with DC.
If it really work with DC, then put a power-switching circuit after the PWM output. The circuit can be something like this:
http://www.picotech.com/applications/pwm_drivers/#chap7
This page was generated in 0.418 seconds.
