Offline Joseph Meiring
#1 Posted : 31 March 2011 12:47:43(UTC)
Joseph Meiring
Does anyone know what track pieces are needed to make a wye..."Y"...in the smallest possible space for C track?
thanx!
Joe
Offline tiono
#2 Posted : 31 March 2011 13:21:59(UTC)
tiono
thanx!
Joe
How about 24630 + 24977
Offline Elukka
#3 Posted : 31 March 2011 13:27:31(UTC)
Elukka
This would be so much easier if we had a symmetric turnout to work with... The 3-way switch would work but it'd look a bit silly.
Here's what I came up with. The geometry isn't perfect and it's probably possible to do better, but if you have the parts handy you could try this. No guarantee that it actually fits together!
Count | Description
2 | Märklin C-Track 24077 Straight 77.5mm
2 | Märklin C-Track 24130 Curved R1=360mm 30°
3 | Märklin C-Track 24206 Curved R2=437.5mm 5.7°
2 | Märklin C-Track 24236 Straight 236.0mm
1 | Märklin C-Track 24430 Curved R4=579.3mm 30°
2 | Märklin C-Track 24611 Left Turnout 188.3mm R2=437.5mm 24.3°
1 | Märklin C-Track 24612 Right Turnout 188.3mm R2=437.5mm 24.3°
thanks 1 user liked this useful post by Elukka
#4 Posted : 31 March 2011 14:37:35(UTC)
Joseph Meiring
Count | Description
Thanx - will try it; pity I can't view your image!
Joe
#5 Posted : 31 March 2011 14:40:03(UTC)
Joseph Meiring
thanx!
Joe
....mmmmmmmmm....not quite!!!
Offline Elukka
#6 Posted : 31 March 2011 15:41:42(UTC)
Elukka
That's odd. Here's a link to the pic in case that makes it show: http://img138.imageshack.us/img138/8131/wye.png
Here's an alternative using the three-way turnout. It's a bit more compact and the geometry is exact, but it perhaps doesn't look as natural. The little spur is only good for storing a single short wagon.
image link
Count | Description
1 | Märklin C-Track 24071 Straight 70.8mm
1 | Märklin C-Track 24115 Curved R1=360mm 15°
2 | Märklin C-Track 24188 Straight 188.3mm
4 | Märklin C-Track 24206 Curved R2=437.5mm 5.7°
1 | Märklin C-Track 24611 Left Turnout 188.3mm R2=437.5mm 24.3°
1 | Märklin C-Track 24630 3-way Turnout 188.3mm R2=437.5mm 24.3°
1 | Märklin C-Track 24977 Bumper 77.5mm
Offline tiono
#7 Posted : 31 March 2011 16:14:07(UTC)
tiono
as I said before........ the smallest "wye" in C-track can only be achieved using three-way 24630 + 24977 Smile
A compromise between compact-space and natural-look.
Offline kbvrod
#8 Posted : 31 March 2011 18:53:03(UTC)
kbvrod
Wye's are very rare in Europe,...
Dr D
Offline Writhdar
#9 Posted : 31 March 2011 20:15:00(UTC)
Writhdar
this is my wye - the 24624 can be replaced by a 3rd 24611. I'm sure you could also use 3 24612's instead of the 24611's
thanks 2 users liked this useful post by Writhdar
#10 Posted : 31 March 2011 22:01:03(UTC)
Dan's solution (post immediately befor this one) appears to be the same as Marklin's, which shows up in many of their track or layout manuals as below. Dan has one entrance as a double slip, but the geometry is the same as a 24611 turnout.
I have tried this set and it works well, it still requires a reasonable amount of space. I guess a turntable would take up similar, though more expensive.
#11 Posted : 01 April 2011 19:42:26(UTC)
Joseph Meiring
Thanx Dan n Kimball - just what I was looking for! I know it takes up space, but it cuts out having to have big reverse loops over the board, and having to spend $$$$$ on a t/table!
Thanks everyone.....Joe
Offline Writhdar
#12 Posted : 01 April 2011 23:08:45(UTC)
Writhdar
likewise in the real world. Turntables are a lot more expensive & involved than a simple wye. However, in mountainous terrain with limited suitable track terrain, a turntable may be the way (e.g., the Silverton Railroad in Colorado USA had the Guston Turntable - also referred to as the Corkscrew Gulch Turntable - below Red Mountain Pass).
On my layout, I have a narrow mining "spur" and the wye is perfect there - makes for a lot of operational fun.
thanks 1 user liked this useful post by Writhdar
#13 Posted : 01 April 2011 23:26:13(UTC)
"Wye" not? BigGrin - if you have the space, they are a cool feature, there are a few in NZ & Australia and add interest to the operations
I prefer the curved one best.
Oz
#14 Posted : 02 April 2011 12:52:39(UTC)
Joseph Meiring
Oz
There was one at the bottom of the old Steam Loco Shed yard in Cape Town many years ago - I remember how "huge" it was; was quite awesome seeing the locos coming down the line, with the fireman leaping out to change the points in time before the driver went hurtling off without him!
Dunno if I will have the space tho....mmmmmm......about that room in the roof???
Thanx, Joe
#15 Posted : 04 April 2011 10:16:58(UTC)
Try our member weichen-walter.de he'll does it for you.
http://www.weichen-walter.de/
Offline klarinettmeister
#16 Posted : 28 May 2011 10:13:51(UTC)
klarinettmeister
This is what I did yesterday.
It´s not small but maybe serves as inspiration. It´s a double track wye with right-hand traffic. Because of the complicated track work, signals should be added to allow only 1 train at a time. This wye is quite big though (1800*1150). BTW, I pass a single-track wye almost every day. I havent´t seen one elsewhere in Sweden but here.
Link to the wye
If you click on "karta" you can see the map instead of the satelite-picture.
thanks 1 user liked this useful post by klarinettmeister
#17 Posted : 28 May 2011 18:28:32(UTC)
Dr D
A "wye" in German is a Gleisdreieck. They can be found near many terminal stations. Check maps.google.com for Kassel, Germany, Zuerich, Switzerland and Frankfurt (Main) (both multiple wyes), Stuttgart (Stuttgart Nord), just to name a few. Any time you have a "Kopfbahnhof" with departing tracks going off in more than one direction, it creates in effect a "gleisdreieck". More modern installations might not have the connecting line away from the Bahnhof, which means it can no longer be used as a wye.
Offline Darren W
#18 Posted : 28 May 2011 19:22:00(UTC)
Darren W
Thanks for pointing out those sites Mike. Does anyone know if the elevated wye at Zurich end across the river or is that a tunnel? I can't tell from the top down picture. It would make an interesting model subject with the tracks elevating and then crossing the river.
Darren
#19 Posted : 29 May 2011 01:46:22(UTC)
Darren,
if you look on maps.google.com for Pfingsweidstrasse, Zuerich, Switzerland, the camera car actually went under the wye and you can pan left or right to see more details. That line continues north over the river and then into a tunnel heading to Zuerich Oerlikon station. The other wye branches off to the left, heading in direction of Wiedikon, Enge and Thalwil and the main lines connecting to Chur and Zug/Arth Goldau and Luzern.
Offline mighty1
#20 Posted : 30 May 2011 10:47:41(UTC)
mighty1
BigGrin Joe, get yourself a wintrak cd and it will make your life heaps easier.
also, in oodnadatta, which was a station on the old "Ghan" route, is wye and it was great. National Rail had a stock yard at the end of it, and it was also used in floods to turn the Ghan around.
I worked there for a short period in my younger years. nothing like seeing a loko from both sides and watching all its mechanics on show in such a short space.
hope yours is as much fun.
LOL
This page was generated in 0.599 seconds.
