Offline Kevin Weis
#1 Posted : 30 March 2011 02:48:18(UTC)
Kevin Weis
All the information I've seen on the 67025 control is that it is typicaly powered by an 18 volt transformer. So my question is can this controller be powered by something other than a 18v transformer. I thought about trying to power one with a standard 32v marklin transformer. Is this compatable or will it overload it? I know nothing about this controller and can find very little information on it.
Regards, Kevin
#2 Posted : 30 March 2011 04:19:43(UTC)
the 32 V Marklin Transformer is a 32 VA transformer. 17.2 Volts and 1.8/1.9 Amps.
NN
#3 Posted : 30 March 2011 20:42:32(UTC)
Hi, Kevin!
This thingy runs on 18 V DC normally. I don't know if a transformer with 16 V AC could also be used (manual says: never use anything else).
You won't get more power even if it should work.
Offline Kevin Weis
#4 Posted : 31 March 2011 01:40:39(UTC)
Kevin Weis
Ok, I thought all Marklin ran on an output of 17v - 18v AC. Is this control designed to operate with certain types of digital locomotives like maybe only ones with DC motors? How would the accessories operate off a DC transformer? Maybe with the accessories it dosen't matter. Dosen't sound like it was meant to be hooked up to an exsisting AC layout. Any thoughts or knowlege on this appreciated.
#5 Posted : 31 March 2011 23:08:13(UTC)
Current Märklin either runs on 16 V AC or on 18/19 V DC (that is the power supplied to the controller).
Modern digital controllers require exclusive power supplies - you don't hook any accessories onto the same power supply.
Märklin locos either have DC motors or AC/DC motors. When running digital, there always is an alternating polarity on the track.
The 67025 can run locos. It can't even change the address of locos, so when you buy locos make sure they use one of the four main Delta addresses (24, 60, 72, or 78).
The cheapo IR controller can change addresses. With an MS2 you can change more than just the addresses.
This page was generated in 0.401 seconds.
