Offline Skjalg
#1 Posted : 27 March 2011 14:55:40(UTC)
Skjalg
Hi all!
In order to enable me to run locomotives from the Mac, I intended to write a small program to listen for messages from the CS2, or at least to use an existing program such as he WinDigiPet to work. I am using a Mac, and the firewall is set up to allow incoming messages.
The connection between the mac and the CS2 works per se, I can connect to the CS2 using the broswer, to take screen shots.
The Central Station 2 is Software version 1.5.2(1) and HW version 3.4, as cen been seen from the following screen shot:
In this later version the set up for IP has changed slightly from previous versions.
It has a
IP address (I understand this)
IP Network Template (I understand this)
IP Gateway (As far as I remember, this used to state Start Gateway, and the purpose was to enable CS2 to broadcast messages, and not only listen), however I do no know what this should be now... Also the DNS Server, when should it be used, and how?
The CAN configuration I assume I have done correctly, but so far I did not manage the computer to receive any messages.
I tried to use WinDiPet demo version through Parallels on the Mac, but I did not get it to work, it claimed the CS2 was not correctly set up. Any ideas on what I need to change on the CS2 side?
Skjalg
Offline nelson77
#2 Posted : 27 March 2011 18:55:48(UTC)
nelson77
Hello Skjals.
Thanks for the great information. I just purchased a CS2 (60214). I noticed that you have Software Version- 1.5.1 (1). Last week I up graded my CS2 from the Marklin Web site and got Version 1.4.0 (0). Can I ask where you got your Software from.
Nelson77
Westminster, Md
#3 Posted : 27 March 2011 18:59:53(UTC)
Have you tried with the firewall turned off?
Offline Skjalg
#4 Posted : 27 March 2011 19:20:01(UTC)
Skjalg
Originally Posted by: nelson77 Go to Quoted Post
Hello Skjals.
Nelson77
Westminster, Md
Well, as you may know, there are 2 ways to update your CS2 software. Either from the "USB stick", or "internal" directly from the CS2, if this is connected to internet. I did the latter. I do not remember the date, but it must have been some weeks ago. I assume that Märklin has not made this version available for "USB stick" upgrade. The documentation (as available if you type in the IP address of the CS2 in your web browser, is outdated, and refers to the old set up of IP.
As a side note, you can retrieve screenshots from your CS2, by navigating to the IP address as well. In my case, where the address of the CS2 is 10.0.1.10, by pointing the browser to:
http://10.0.1.10/cgi-bin/screenshot.sh.png
_Skjalg
Offline Skjalg
#5 Posted : 27 March 2011 19:46:01(UTC)
Skjalg
Yes, the firewall was turned off (under OSX), but under Windows it was on, turning it off did not make a difference. As for WinDigiPet, I realized that when runnin Windows on the Mac, it gets its own IP address on a different subnet.
C:\Program Files\Microsoft Visual Studio 10.0\VC>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 10.211.55.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.211.55.1
On the same physical machine, but under OSX I get IP address 10.0.1.9:
> ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::223:32ff:fea0:a67e%en0 prefixlen 64 scopeid 0x4
inet 10.0.1.9 netmask 0xffffff00 broadcast 10.0.1.255
ether 00:23:32:a0:a6:7e
media: autoselect (1000baseT <full-duplex,flow-control>) status: active
supported media: autoselect 10baseT/UTP <half-duplex> 10baseT/UTP <full-duplex> 10baseT/UTP <full-duplex,hw-loopback> 10baseT/UTP <full-duplex,flow-control> 100baseTX <half-duplex> 100baseTX <full-duplex> 100baseTX <full-duplex,hw-loopback> 100baseTX <full-duplex,flow-control> 1000baseT <full-duplex> 1000baseT <full-duplex,hw-loopback> 1000baseT <full-duplex,flow-control> none
fw0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 4078
lladdr 00:23:32:ff:fe:2d:5b:7c
media: autoselect <full-duplex> status: inactive
supported media: autoselect <full-duplex>
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 00:1b:63:c1:e9:75
media: autoselect (<unknown type>) status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::21c:42ff:fe00:1%en3 prefixlen 64 scopeid 0x7
inet 10.211.55.2 netmask 0xffffff00 broadcast 10.211.55.255
ether 00:1c:42:00:00:01
media: autoselect status: active
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::21c:42ff:fe00:0%en2 prefixlen 64 scopeid 0x8
inet 10.37.129.2 netmask 0xffffff00 broadcast 10.37.129.255
ether 00:1c:42:00:00:00
So if I should get WinDigiPet to work, I might need to change something...?
I have not used WinDigiPe before, and I downloaded the German version, but I will try the English version later. Either way, here is the configuration for CS2:
and here is the message I get when I start the program:
basically saying that the CS2 does not respond, and that the digital system must be re initialized (meaning configured I guess).
#6 Posted : 27 March 2011 21:23:19(UTC)
I have no expertise with Macs, but with Virtual PC under Windows there are several ways to set-up the network connection. My VPCs normally get an IP address directly from the main DHCP (in your case this would be an 10.0.1.x address). This would place the CS2 and the virtual PC in the same subnet.
#7 Posted : 27 March 2011 21:52:31(UTC)
What Tom says, is that you should set up (if possible) the "network properties" of Parallells as a "bridging" network connection, not as a separate "Network Address Translation" (NAT) network as it seem to default to.
The CS2 broadcasts the CAN bus UDP traffic to all your 10.0.1.xxx adresses, but not to the 10.211.xxx.xxx adresses since these are not within the network scope of the broadcast. At least that's how I understand it.
Since I only know "something" about Virtual PC & VMWare, I cannot really give advice on the Parallells setup...
Offline Skjalg
#8 Posted : 27 March 2011 23:09:04(UTC)
Skjalg
Thanks to both of you. I will have a look into how (if) I can do this and report back my findings, hopefully by tomrorrow. So far it is logical that it does not work.
However, I am still unsure if the IP Gateway has the correct value.
_Skjalg
Offline frankie
#9 Posted : 28 March 2011 11:55:08(UTC)
frankie
Since the CS2 is a Linux box, make sure you connect the cables before starting it, may seem obvious, but just in case...
This holds true for the CS1/CS1R, not sure for the CS2 since I don't have one.
Alessandro
I have a CS1 Reloaded!
Offline GSRR
#10 Posted : 28 March 2011 17:56:39(UTC)
GSRR
You have been a member since:: 01/03/2009(UTC)
thanks 1 user liked this useful post by GSRR
Offline Skjalg
#11 Posted : 28 March 2011 21:00:35(UTC)
Skjalg
Thanks Thomas, for the iTrain link. I have not seen this before, but since it is cross platform, I will certainly try it out. For my own use, it seems well suited. The reason for my efforts with the WinDigiPet is simply that it is already being used in a club where I am about to become a member, so I thought I better learn how to operate it, as well as having an informed opinion about its abilities compared to other alternatives.
_Skjalg
Offline Skjalg
#12 Posted : 28 March 2011 21:26:41(UTC)
Skjalg
Thanks for the tip, however the connection with the CS2 works fine, as I somewhat clumsy described in my initial posting:
The assumption thus far is that there is a mismatch/misconfiguration between the CS2 and the Windows running in Parallel on the Mac. I will have a look at that now.
_Skjalg
#13 Posted : 28 March 2011 21:58:02(UTC)
The windows stuff has to be on the same network address range as the Mac & CS2 as Tom and myself mentioned - Have you found any network settings in Parallells that can support that scenario?
Offline Skjalg
#14 Posted : 28 March 2011 23:03:54(UTC)
Skjalg
I did. There is a network option at the startup:
Pressing the network link I changed this to a Bridged ethernet connection, using the same port as for the OSX.
In addition under Settings -> Network under OSX, I put the Windows address to 10.0.1.11. (The mac had 10.0.1.9 and the CS2 10.0.1.10).
After that the IPCONFIG command under windows dow window yields:
Connection-specific DNS Suffix . : ...
IP Address. . . . . . . . . . . . : 10.0.1.11
Default Gateway . . . . . . . . . : 10.0.1.1
However, everything else is the same, i.e. the WinDigiPet reports the same error, regardsless of restarting Windows.
I did also try the iTrain on the Mac, and it claimed to have connected with the CS2, but nothing more.
_Skjalg
Offline GSRR
#15 Posted : 28 March 2011 23:39:37(UTC)
GSRR
_Skjalg
Skjalg,
Just to confirm you installed the Mac OS version of iTrain, and you also downloaded the user manual?
You could also post on the iTrain forum about iTrain - CS2 connection.
http://berros.eu/itrain/forum/
Can you post screenshots of the iTrain connection?
r/Thomas
Offline Skjalg
#16 Posted : 28 March 2011 23:58:59(UTC)
Skjalg
Here you see 2 pictures, my definition of CS2 for iTrain, and the Control panel, showing the CS2 as online. The user manual I did not discover, but I doubt if it will help, but I will look at it. A possible way forward would be to downgrade to whatever version is offered as a USB stick upgrade/downgrade. At least then I could rule out that as a possible problem.
#17 Posted : 29 March 2011 00:04:19(UTC)
Have you tried to ping the CS2 from the Windows partition? If the Windows machine can't see the CS2, then WDP won't either..
Are you using WinDigiPet 2009 - earlier versions don't work with the CS2? The English Demo version is at http://www.windigipet.de/cgi-bin/download/download.pl?setup_demo_2009_e
Offline Skjalg
#18 Posted : 29 March 2011 00:10:13(UTC)
Skjalg
Originally Posted by: GSRR Go to Quoted Post
Skjalg,
r/Thomas
This is how I defined the train (in iTrain):
and the corresponding address as shown on the CS2:
Offline Skjalg
#19 Posted : 29 March 2011 00:14:22(UTC)
Skjalg
Yes, I had.
C:>ping 10.0.1.10
Pinging 10.0.1.10 with 32 bytes of data:
Reply from 10.0.1.10: bytes=32 time=1ms TTL=64
Reply from 10.0.1.10: bytes=32 time=2ms TTL=64
Reply from 10.0.1.10: bytes=32 time<1ms TTL=64
Ping statistics for 10.0.1.10:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 2ms, Average = 1ms
Offline Skjalg
#20 Posted : 29 March 2011 00:22:09(UTC)
Skjalg
I used the German version, latest of the greatest.
I'm running out of energy for tonight. Tomorrow I will try to downgrade the CS2.
_Skjalg
Offline Skjalg
#21 Posted : 29 March 2011 21:56:06(UTC)
Skjalg
OK, so time for a little update.
I downgraded my version of the CS2 software, using the USB stick approach.
I did the setup of the Network:
I then started up the iTrain software running under the Mac OSX, and as can be observed on the below image, this gave a better result.
The Go and Stop button works, but so far I did not manage to control the locomotive, but I have only tried a few minutes so far. Maybe time to read the documentation... I will also try the WinDigiPet software, and give you an update later (not sure if I manage today).
But based on my findings thus far, stay with the 1.4 USB upgrade if you want to control your trains from software.
_Skjalg
Offline Skjalg
#22 Posted : 29 March 2011 23:56:41(UTC)
Skjalg
_Skjalg
OK an update on using the iTrain. Reading the manual was of help, quite a good one in fact. When identifying an MFX locomotive, I had to fill in 0 in the address field.
Next change the direction of the train on the CS2, and the address is then detected in connection with a broadcast.
After this I could operate the train just fine. All functions where displayed as expected.
_Skjalg
#23 Posted : 30 March 2011 00:13:44(UTC)
Interesting, even though I dont have neither a Mac nor a CS2
Offline Skjalg
#24 Posted : 30 March 2011 18:42:38(UTC)
Skjalg
So today, I did an upgrade again, so I'm back with the version 1.5.2(1). And today, it worked! I´m officially out of trouble, and running the latest version of CS2 software.
I did not have time to test with WinDigiPet yet, but iTrain worked, and former should work as well. Below you can see the configuration that worked for 1.5.2(1):
_Skjalg
Offline GSRR
#25 Posted : 08 April 2011 10:26:32(UTC)
GSRR
Skjalg,
glad to see you got it all working, thanks for the pictures.
r/Thomas
This page was generated in 1.364 seconds.
