Offline Chris6382chris
#1 Posted : 02 March 2011 07:34:48(UTC)
Chris6382chris
I am installing a delta 66032 chip into an engine and wanted to replace the light bulb that came with the engine with an LED. What is the voltage coming out of the gray and yellow wires that feed the lights? I was thinking of going to Radio Shack and grabbing a couple LED's and was wondering what I should get. Also will I need to add a resistor as well, between the chip and the LED? If so what would be a good combination of LED and Resistor, looking for the lowest draw while still being somewhat bright.
Chris
Offline perz
#2 Posted : 02 March 2011 08:35:41(UTC)
perz
I think this newer version of the Delta decoder has a steady 20 V lamp voltage (older versions had a voltage that varied with motor speed). You will always need a resistor in series with the LED. A LED typically draws 10 - 20 mA and the voltage over it is approximately 3 V (in case of a white LED). This would give 17 V over the resistor, and if you aim at 10 mA this means a 1.7 kOhm resistor. Nearest standard values are 1.5 kOhm and 1.8 kOhm. The power rating of the resistor can be calculated as U*U/R where U is the voltage and R is the resistance. Assume you have a 1.8 kOhm resistor: 17 V * 17 V / 1.8 kOhm gives 160 mW, so 160 mW is the minimum power rating for the resistor. Add some margin to that to be safe.
#3 Posted : 02 March 2011 09:44:31(UTC)
Hi, Chris!
You need something that limits the current through the LED - and a resistor is a simple way to achieve that.
You can have several LEDs (of the same type) in series. You'll need a smaller resistor and you'll get more light (and less heating) frome the same current.
#4 Posted : 02 March 2011 17:26:47(UTC)
Chris6382chris
Thanks to both of you for your answer. So I will look for a 160-170 mW rated resistor and wire it in series to my 3 volt LED.
Chris
#5 Posted : 02 March 2011 17:38:25(UTC)
The standard type of resistors has 0.25 W (250 mW)
Offline frankie
#6 Posted : 02 March 2011 17:53:29(UTC)
frankie
I'm noy into electronics, but I have already used this solution, the resistor must be soldered on one of the pin of the LED, is there a way to figure out on which one? Because it works only on one of the two...
Alessandro
I have a CS1 Reloaded!
Offline perz
#7 Posted : 02 March 2011 19:29:46(UTC)
perz
The resistor can be on either side of the LED, but the LED always needs to have the correct polarity. Probably when you only got it to work one way, you had the LED flipped as well.
#8 Posted : 02 March 2011 21:53:32(UTC)
Might be worth to mention that the decoder polarity is not what many expect: the common wire (orange with M* decoders, blue with NMRA standard (e. g. ESU)) is plus, decoder function outputs (yellow and grey with M* decoders) are minus.
Offline Dave Banks
#9 Posted : 02 March 2011 22:57:26(UTC)
Dave Banks
Chris also you can modify this chip to have a function for your light. http://www.bogobit.de/decoder/66032.html
D.A.Banks
This page was generated in 0.815 seconds.
