Poll Question : I have
Choice Votes Statistics
  Total 139 100%
Guests can't see poll choices and poll results. Try login or register. Guests can't vote. Try login or register.
2 Pages12>
Offline Piggy
#1 Posted : 30 January 2011 14:19:49(UTC)
Piggy
I been thinking how other members here on the forum run electric locos and units. Personaly I would prefer run
my trains with pantos up, but I don't in most cases. Afraid of breaking them, especialy the modern single arm types.
I would interessting to hear your comments.
The last option "secured" refers to locking below the wires to protect the pantos.
Edited by moderator 30 January 2011 22:45:11(UTC)  | Reason: Not specified
Kenneth
Offline tiono
#2 Posted : 30 January 2011 14:55:49(UTC)
tiono
Yes. I use catenary powered for digital usage.
Running Re4/4 II loc with single-arm pantograph pulling passenger coaches and SBB Restaurant-car with single-arm pantograph.
Offline Western Pacific
#3 Posted : 30 January 2011 15:02:42(UTC)
Western Pacific
I took the liberty of answering in the way I plan to run my layout - not connected, pantos up.
I had a layout together with my brother (he has it now) which was analogue and there we had operating catenary and it looks so much better when electric locos run with their pantos up and with a properly built catenary the cost of replacing broken pantos "won't kill you", since it doesn't happen very often. Based on this I plan on having a catenary on all visible sections and at all not visible at places with low clearance.
#4 Posted : 30 January 2011 15:10:29(UTC)
I run Electric loco but dont have catenary, Maybe I will get catenary in the future.
Offline Ranjit
#5 Posted : 30 January 2011 15:19:58(UTC)
Ranjit
Hi Kenneth,
I have never user catenary, but like Stephen I might get it in the future.
Ranjit
#Get Vaccinated
#6 Posted : 30 January 2011 17:26:14(UTC)
you missed one category:
Catenary poles but no wires
My intention was to install catenery using Sommerfeld. I installed the first run of it too.
http://layout.mixmox.com/1/Sommerfeld-catenary
Then later I realized that it is going to be a major nuisance - obstructing access to the track, and if ever it is bumped, it gets dented/bent and than looks awful. So I decided that I will erect all the poles but not the wires.
If you look at photographs of prototype electric trains, taken from a distance corresponding to how we view our models, most times you see the poles but not the wires.
Offline Piggy
#7 Posted : 30 January 2011 17:59:31(UTC)
Piggy
Good point, Dale. I didn't think of thatBlushing . Can this be added to the poll? please. I think this very common for Z scalers.
Kenneth
Offline Ian555
#8 Posted : 30 January 2011 18:54:16(UTC)
Ian555
I have a double track of catenary on my analog section of the layout.
Ian.
Offline jcrtrains
#9 Posted : 30 January 2011 19:24:38(UTC)
jcrtrains
It's possibly the next big project for me. The realism it adds is tremendous and I have spent time at a local store experimenting with the Viessmann system and it doesn't seem that difficult.
Offline ozzman
#10 Posted : 30 January 2011 19:29:36(UTC)
ozzman
I tried out Dale's idea on my Z scale layout, but the poles still got in the way of track cleaning, loco and wagon re-railing etc. Be aware that if you want to go down this path you have to modify the poles by cutting off the bottom retaining wire. If you don't the pantos foul them - don't know how it is with HO, but with Z scale electric locos the pantos can only be fully up or down. You also have to modify multi-track wire spans by cutting off the lower part. In the end I decided to do without catenary altogether.
Gary
Z Scale
Offline rschaffr
#11 Posted : 30 January 2011 21:04:03(UTC)
rschaffr
I use the Viessmann system in my visible areas. I had originally built my layout with continuous powered catenary, using the Noch tunnel catenary in the hidden areas, but the upkeep got to be just too much, so I switched the power feed on my e-loks back to track and removed the hidden portions, adding catch and release sections when the track entered the hidden areas. True there is a bit of upkeep for the catenary, but I feel it is worth it for the realism imparted. One thing you have to be careful of, is to make sure that you have sufficient clearance in your hidden areas for the fully extended pantos. In a few areas, I took the metal bands from the Noch catenary and turned it on it's side and attached it to the overhead in the hidden areas to allow the pantos to pass some obstructions.
-Ron
Offline dan67millie
#12 Posted : 30 January 2011 21:07:20(UTC)
dan67millie
Hi I did not think you could run Marklin digital of the overhead wires!!
#13 Posted : 30 January 2011 21:22:38(UTC)
You can even run a mixed digital/analog layout by having digital in the catenary and analog on the tracks or vice versa...
Offline rhobson1968
#14 Posted : 30 January 2011 21:38:54(UTC)
rhobson1968
I have half of my layout on catenary. I debating to either make the rest or sell off the catenary that I have. My problem is everytime I expand I also need more catenary... It is just so crazy expensive to put in and I never have enough... Cursing Cursing Cursing
Never quit building.
Offline Piggy
#15 Posted : 30 January 2011 22:11:36(UTC)
Piggy
You are right, catenary cost alot. I only have it on my main lines, but not for branch lines. Not only for cost reasons, but because I feel that is more protypical for my layout, and justifies the use of diesel and steam locos.
Kenneth
#16 Posted : 30 January 2011 22:20:14(UTC)
One quick comment regarding catenary. It is called a "mast" and not a "poll".
@Tiono, the pantograph on the SBB (and other restaurants) is not used when the train is in motion, but to provide a power source for the kitchen when the train is not connected to a lok in station or prior to being shunted into the station for departure.
My catenary set up on my test oval is designed to be switchable between AC and DC, so that I can optionally run DC Electric loks on my Maerklin tracks.
Offline Dreadnought
#17 Posted : 30 January 2011 22:35:37(UTC)
Dreadnought
My M track is about 80% wired with catenary. I only power restaurant cars from it. All the locomotives are digital, so there is no need to run them from the catenary.
In my analog days I ran all the electrics from the catenary.I liked seeing the sparks produced by the catenary in a darkend room.
#18 Posted : 30 January 2011 22:41:20(UTC)
I've lost count of the number of single arm pantographs I've munted through running them backwards. At the moment, I run locos with pantos down, but when I do run them with pantos up, I only run the single arm pantos forwards, never backwards.
I don't have the catenary powered, but I have put feeder wires in, in the event I decide I want to power it.
#19 Posted : 30 January 2011 22:43:35(UTC)
Marklin do not recommend this because of the small contact patch between the overheads wires and the pantographs, but many members here have tried it and run it without issues.
#20 Posted : 30 January 2011 22:45:57(UTC)
Done!
Offline Piggy
#21 Posted : 30 January 2011 22:51:19(UTC)
Piggy
Done!
Thanks David
Kenneth
#22 Posted : 30 January 2011 23:07:42(UTC)
I run complete catenary system with pantos up on a digital layout, but the catenary is not powered.
It is for show only.
There is no choice for me in the poll.
Offline Nilkram
#23 Posted : 30 January 2011 23:08:19(UTC)
Nilkram
I use a full operational catenary, digital, self made in the invisible part of my layout, including the shadow stations. Add it to the poll, please.
Jan
Offline rschaffr
#24 Posted : 30 January 2011 23:11:29(UTC)
rschaffr
I ran my digital loks for years through the catenary without issue. The ONLY reason I changed was to eliminate the upkeep on the catenary in the hidden areas. I agree that it is not necessary with digital, since you can address each lok individually, but I had decided to power it because I had spent so much money on it I wanted it to work for me! Cool
-Ron
Offline Piggy
#25 Posted : 30 January 2011 23:14:19(UTC)
Piggy
I would say this statement will fit your case, Kimball: "Catenary not connected, I run with pantos up"
Kenneth
thanks 1 user liked this useful post by Piggy
Offline Jeremy Palmer
#26 Posted : 30 January 2011 23:23:32(UTC)
Jeremy Palmer
Barbados
Thanks Kenneth,
Fascinating topic, I have learnt more about catenary in these posts than in 7 years.
Jeremy.
Jeremy.
Offline hennabm
#27 Posted : 30 January 2011 23:32:04(UTC)
hennabm
When I was a lad the slipper on my only engine (E44) broke and so it left me no choice but to always use the catenary.
Nowadays, I always use the overhead powered but do mainly stick to mainline and limited sidings, thus justifying diesel and steam, like others.
1957 - 1985 era
What's digital?
Offline GG1 Fan
#28 Posted : 31 January 2011 02:41:10(UTC)
GG1 Fan
My 2 Cents:
Catenary adds a lot of realism but at the cost of...cost and time/aggrivation. Cat looks cool in the dark too, especially with the passanger coaches that light up too.
I have a 4 year old, so after really wanting to put up Cat, I opted out this year for fear he would touch it and get a shock.
On another note: Did you know that old 'Electrotren' Catenary fits and works on Marklin just fine??? Run the Cat along the track, hook up the feeder wires to the Marklin transformer and.....you've got it. ThumpUp
Paul
#29 Posted : 31 January 2011 05:04:16(UTC)
Hi Kenneth,
Thankyou, I have voted.
Perhaps you could change the word "connected" to "connected/powered". I think I understood the word "connected" to mean "installed". So in that light, "not connected" might mean "not installed".
#30 Posted : 31 January 2011 05:12:10(UTC)
Hi Kenneth,
My situation is similar.
I have the catenary on a double track main line, one siding loop, and on two storage sidings.
I also have another double track mainline and most of my sidings with no catenary, so this is where the steam and diesel engines roam. Sometimes they use the electrified routes, but the electric engines are unable to use the no-catenary routes.
I agree, the cost was high. I could power it, but many newer Marklin digital engines don't have the switch to run off the catenary.
#31 Posted : 31 January 2011 07:00:15(UTC)
99% of my masts and about 60% of my overhead wires are Electrotren. Unfortunately, you can no longer get the old style wires from Electrotren, but the masts are still available, about $1.50 USD each.
#32 Posted : 31 January 2011 10:59:27(UTC)
I have masts and wires installed in all visible areas. (my layout is still under construction)
I use semi-old Märklin masts (before the Viessmann franchise) -also masts form Electrotren.
I use Aneste wires.
It is not powered, but I run with pantos up. I have done as Ron also describes; in hidden areas some "catch" wires are installed to negotiate obstructions.
My WHOLE layout is equipped with catanary, except for two small industrial zones, 3 tracks for classification of freight waggons, and the BW area with turntable.
Offline husson73
#33 Posted : 31 January 2011 12:40:28(UTC)
husson73
Electroten old wires were Marklin under licence and cheaper than oriiginal MarklinRollEyes
3 rails HO OO O I, DC and AC, analogic and digital.
Offline rrf
#34 Posted : 31 January 2011 16:23:05(UTC)
rrf
I've been wanting to add catenary to my layout for ages. It seems that 2011 might be the year where I can scrape togther some funding for this project. Though I still have no idea how I should engineer it: powered or unpowerd, only on the visiable sections, etc. I've been planning to seek advice from you all ... perhaps now's the time Smile
Rob
Mackenrode Wende Bahn
#35 Posted : 31 January 2011 21:44:01(UTC)
Hi Rob,
You say
This year I completed the overhead wiring on my C track layout, using new Marklin components. It was not cheap, but I must say it has not given me any grief. Overall there is about 30 metres of wire.
I followed Marklin instructions pretty carefully, used their jigs and guides. I didn't find the installation easy, quite time consuming. I used more masts on curves than recommended, so that gave less room for error in the wire being misplaced over the track. For example, on Radius 5 they say you can use 70253 wire, but I used 70228 (also 70253 in some places). I allowed for plenty of 70231 (the adaptor wire that allows you to make a custom length). There was always adjustments required to mast arms (a couple needed bending so as not to foul the panto), but once done, the engines run perfectly with panto up. My layout is digital, so I did not need to power the catenary.
In my tunnels (about 5 metres), I also used the Marklin stuff, as it was easier for me than designing and building my own, supposedly cheaper solution.
I hope my experience might be of help to someone.
#36 Posted : 31 January 2011 21:57:20(UTC)
As I have said many times during the years of the forum - My old local dealer (RIP) gave me a great tip, use long pieces of cheap flex N-track upside down in the hidden areas for powering from above...
Works fine and does not entangle the pantographs unexpectedly in hidden areas...
Offline dan67millie
#37 Posted : 31 January 2011 22:15:52(UTC)
dan67millie
Drool This topic is very usefull, Can you run your layout with digital wires and the track All at the same time!! is it possible i mean! cheers DanBigGrin
Offline tom becker
#38 Posted : 31 January 2011 22:33:17(UTC)
tom becker
I like the realism of having catenary on my layout, but must admit it was a bitch to install, but looks very realistic. I found the single pantographs are especially touchy and easily get caught in the wiring. The old style pantographs work very well, and I will concentrate on that. I also learned that in any hidden areas you can easily dispense with catenary (provided you allow adequate clearance height for your electric loco's to extend the full height of their catenary. My catenary wiring is for display use only, with none powered; this of course works very well with digital control.
Tom, a loyal fan from Vancouver
#39 Posted : 01 February 2011 00:23:09(UTC)
Yes you can. You could feed both track and catenary from the same controller, or from different controllers. If using different controllers, just make sure that there is no way the catenary wire can come into contact with the centre rail of the track - either through a deliberate permanent connection, or an accidental one such as a live catenary wire knocked or dropped onto the track.
Offline TrainIride
#40 Posted : 01 February 2011 09:14:56(UTC)
TrainIride
My layout is partially equipped with catenary.
As it was not planned at the beginning, it was not
possible to cover all the tracks with.
I woud have to modify the height of my top level,
rework the tunnels, change the slope of the track leading
to the underground...
So I finally only equipped the top part.
The catenary stops at the train station
which makes the correspondence with the "non-electrified" part.
The catenary is analog powered and is used to control
a Marklin E69 model pulling a few coaches. The funny game is to drive it when
the ground powered automatic trains are moving around, and to avoid colliding - I never collide ...
I psychologically cannot run an electric loco (with pantographs) without catenary Huh .
The catenary is the Marklin previous ones which needs to be curved in the turns.
A great reliability but tends to become oxidized when not used for a time.
I hav resolved this problem with a catenary cleaner car - see my layout topic.
Joël
#41 Posted : 01 February 2011 21:50:54(UTC)
Yes Juhan, I agree, I have noted it before as an excellent idea.
However, I could never figure on an easy suitable system to suspend it over the track, and my hidden spaces are curved track as well.
Perhaps in some layouts, the framework for the hidden areas might offer suitable attachment points.
Offline Darren W
#42 Posted : 07 February 2011 03:57:27(UTC)
Darren W
I bought this book from ebay and found a section about building your own catenary.
The book talks about making you own system using a HO or N scale rail suspended upside down. The author built single masts and larger ones to cross multiple lines. Here is an example of what he built.
There is plenty of pictures and ideas about transitioning to regular catenary and how to power it all.
Cheers...
Darren
Offline Elukka
#43 Posted : 07 February 2011 06:13:58(UTC)
Elukka
I don't have catenary, don't run electric locomotives and don't have any near-term plans for either, but I do try to build my layout to have space for catenary if at one time I decide to set some up.
#44 Posted : 07 February 2011 06:36:50(UTC)
Kimball, here's a couple of pictures showing what I've done in my hidden areas where I've put catenary. I've since started using gas welding rods for the catenary wires, as they come in straight lengths.
Offline SINCrazee
#45 Posted : 07 February 2011 07:39:19(UTC)
SINCrazee
I am thinking of getting catenary soon because I find it 's more realistic with catenary.
C-track carpetbahn, R1 ,R2,R3 with MS2 and a CS2 plus Marklin and HAG trains..
Offline Mark5
#46 Posted : 12 February 2013 23:08:30(UTC)
Mark5
Long live live catenary!
- Mark
#47 Posted : 12 February 2013 23:33:36(UTC)
Wiring live catenary is an unnecessary complication in a digital environment. The locos look the same whether the current comes from above or below.
However, if you enjoy doing it, then go ahead and knock yourself out! BigGrin
Offline kc6uvm_George
#48 Posted : 13 February 2013 01:42:08(UTC)
kc6uvm_George
Views messages in topic : 131
As I resurrect the old layout into something new, I plan on putting up catenary along the main lines and sidings. I probably won't power it up as it adds extra wiring head aches for me while playing in analog mode. As finances allow, I plan on converting over to digital.
Other issue is most of my masts and catenary is put away somewhere and I haven't found all of it yet... Cursing
George,
73 de kc6uvm
NMRA life member
Lancaster, CA
Offline Janne75
#49 Posted : 13 February 2013 01:57:31(UTC)
Janne75
I dont have catenary yet, but I have so many electric locos that I just have to buy and install it soon for my parallel main lines and one siding. As wroted before in digital layout it dont have to be in use (operating electrically) and only for looks and realism if wanted.
But by installing powered catenary I could then run all of my nice analog electric locos without to have convert them into digital (as I dont even want to convert many of them to digital). How the new Märklin catenary and older pantographs work together (Typ 6 = like in 3015, 3018, 3019, 3024... or Typ 7 = like in 3035 and other 1960 => with chromed pantograph slider part but red plastic "feets")? I would really like more from grey catenary masts than green. I have Märklin My World signals also because of this. Digital signals are also much more expensive, but I like also more the looks of Märklin My World grey signals.
I have not made much scenery yet as I know that I have to install first the catenary (masts supports goes under C-track). Therefore no track ballast near tracks yet. I have also started to install some backdrops. I have three walls where they come. One is ready and two other will be attached soon when I go and buy more double-sided tape (that's right, I dont attach them like usually is done as it is not possible with my layout been built to this stage). This way with double sided tape I get almost as good results and with much less time and effort ThumpUp .
If I would install catenary first it would be difficult to install backdrops. So this is good order to do these things.
I would need some advices how to install catenary over my four quite long bridges that are installed close to each other? Each bridge has two of those longer 360 mm lenght sections and in the end of each bridge there is higher and then lower wall straight 180 mm lenght sections. So every of my four bridges are 1440 mm (144 cm) long and run as close to each other than they can. The last bridge (closest to wall) runs very close to wall, but maybe some masts can be installed. Any good ideas are very welcome! Thanks in advance very much from any help with this one ThumpUp .
Janne
Offline Mark5
#50 Posted : 13 February 2013 02:36:16(UTC)
Mark5
Hi Ray,
I'm planning to run Digital off the rails and Analog for the catenary or visa versa.
Crazy complication perhaps, but I want to give it a try.
Two isolated systems with the same ground wire.
Also, I love having actual catenary running electricity,
for me its more than the aesthetics, its a concept and makes me think more about what they are actually doing when in prototype.
We shall see if it makes sense when actually running.
Testing this soon.
- Mark
2 Pages12>
This page was generated in 1.209 seconds.
